unfortunately Yusesope's tool didn't helped for my setup, since it only makes dvhe.08.06, BL+RPU and dvhe.06.06, BL+EL+RPUdarrrkmanxxx wrote: Wed May 06, 2020 4:17 pmThank you so much it's working now!shawnc22 wrote: Wed May 06, 2020 3:56 pm You're on the wrong version of pythonyusesope wrote: Wed Mar 04, 2020 3:36 pm For those who want to use the command line (on Windows, MacOS and Linux), you can use your version of Python (with python >= 3) but you must first install "bitstring"Code: Select all
pip install bitstring
what I need is dvhe.05.06, BL+RPU
Does anyone know how gat I get this profile ino a ts container or how can I demux that from an mp4?
