Why not just keep the BL.hevc and EL.hevc which you would need to use the tool anyway? BL is the first video layer and EL is the second layer, you get them by demuxing the .m2ts fileshroomM wrote: ↑Wed May 06, 2020 4:02 pmGreat tool, @yusesope, thank you!
I have a question - would it be possible (and not too complicated) to reverse what it does?
For example, if I have a final.hevc file with BL+EL+RPU, it would be awesome if it could split it into two (BL.hevc, EL.hevc) or even three (BL.hevc, EL.hevc, RPU) files.
New Android TV device with DV/Atmos support from Tivo - looks pretty good https://www.tivo.com/products/stream-4k
same old song and dance.. no ethernet, no usb ports, low ram, and no hd-audiomulucy wrote: ↑Wed May 06, 2020 10:13 pmNew Android TV device with DV/Atmos support from Tivo - looks pretty good https://www.tivo.com/products/stream-4k
I use this in my LG B8 TV. USB 3.0 to Gigabit Ethernet AdapterGrencola wrote: ↑Thu May 07, 2020 12:02 amsame old song and dance.. no ethernet, no usb ports, low ram, and no hd-audiomulucy wrote: ↑Wed May 06, 2020 10:13 pmNew Android TV device with DV/Atmos support from Tivo - looks pretty good https://www.tivo.com/products/stream-4k
It has a micro USB port and a USB C port. I'm guessing the micro USB port is for power which leaves the USB C port for an ethernet adapter/USB C to USB 3 micro b cable (external hard drive) or a hub with both ethernet and USB ports.Grencola wrote: ↑Thu May 07, 2020 12:02 amsame old song and dance.. no ethernet, no usb ports, low ram, and no hd-audiomulucy wrote: ↑Wed May 06, 2020 10:13 pmNew Android TV device with DV/Atmos support from Tivo - looks pretty good https://www.tivo.com/products/stream-4k
Would running Android mean it may be possible for app developers to work out a way to pass through HD audio to an AVR/soundbar?
Yea, it's basically just like the firestick 4k. it has an ethernet adapter that works the same way. but it's only 10/100mbps so not gigabit. and no, again like the firestick, if hd-audio isn't supported in the firmware, it's not going to be able to passthrough anything more than dd+.TickTock wrote: ↑Thu May 07, 2020 2:42 amIt has a micro USB port and a USB C port. I'm guessing the micro USB port is for power which leaves the USB C port for an ethernet adapter/USB C to USB 3 micro b cable (external hard drive) or a hub with both ethernet and USB ports.Grencola wrote: ↑Thu May 07, 2020 12:02 amsame old song and dance.. no ethernet, no usb ports, low ram, and no hd-audiomulucy wrote: ↑Wed May 06, 2020 10:13 pmNew Android TV device with DV/Atmos support from Tivo - looks pretty good https://www.tivo.com/products/stream-4k
USB C gigabit ethernet adapters should be able to be used (providing they are compatible with Android). Ah, so the only way to get HD audio passthrough would be with custom firmware, which there may be more of a possibility happening than say with the Firestick, given the device is running Android, but it probably won't happen.Grencola wrote: ↑Thu May 07, 2020 2:50 amYea, it's basically just like the firestick 4k. it has an ethernet adapter that works the same way. but it's only 10/100mbps so not gigabit. and no, again like the firestick, if hd-audio isn't supported in the firmware, it's not going to be able to passthrough anything more than dd+.TickTock wrote: ↑Thu May 07, 2020 2:42 amIt has a micro USB port and a USB C port. I'm guessing the micro USB port is for power which leaves the USB C port for an ethernet adapter/USB C to USB 3 micro b cable (external hard drive) or a hub with both ethernet and USB ports.
unfortunately Yusesope's tool didn't helped for my setup, since it only makes dvhe.08.06, BL+RPU and dvhe.06.06, BL+EL+RPUdarrrkmanxxx wrote: ↑Wed May 06, 2020 4:17 pmThank you so much it's working now!shawnc22 wrote: ↑Wed May 06, 2020 3:56 pmYou're on the wrong version of pythonyusesope wrote: ↑Wed Mar 04, 2020 3:36 pmFor those who want to use the command line (on Windows, MacOS and Linux), you can use your version of Python (with python >= 3) but you must first install "bitstring"Code: Select all
pip install bitstring
what I need is dvhe.05.06, BL+RPU
Does anyone know how gat I get this profile ino a ts container or how can I demux that from an mp4?
This is assuming I'm coming from a blu-ray m2ts.ATD555 wrote: ↑Wed May 06, 2020 9:01 pmWhy not just keep the BL.hevc and EL.hevc which you would need to use the tool anyway? BL is the first video layer and EL is the second layer, you get them by demuxing the .m2ts fileshroomM wrote: ↑Wed May 06, 2020 4:02 pmGreat tool, @yusesope, thank you!
I have a couple of already merged files with BL+EL+RPU and some with BL+RPU.
It'd be interesting to "split" them into separate layers. Maybe see if we can use the RPU with x265's RPU option, though I don't know if that would even work.
check this out, in Kodi 18 no less! this is on the Ugoos AM6 Plus, ff to around 5m15s: https://drive.google.com/file/d/1cpBJSM ... Wt_2A/view
I noticed he said "Single Layer", any idea what profile he is talking about?Grencola wrote: ↑Fri May 08, 2020 1:48 amcheck this out, in Kodi 18 no less! this is on the Ugoos AM6 Plus, ff to around 5m15s: https://drive.google.com/file/d/1cpBJSM ... Wt_2A/view
not sure, but judging by the mp4 and pcm audio I'm guessing profile 7.
Also, the guy who sent me this video said profile 5 dv rips work in kodi 19 on his shield. can anyone with a shield verify that?
Looks like it. Installed the nightly version of kodi 19 and went through a bunch of sample files I had. The only one that worked was a profile 5 mp4 that I made with yusecope's tool in mode 2 and mp4muxer. All the other profile 4/7 mp4s/ts files played in just hdr. Same file also refused to play on kodi 18.
I googled mp4mux and had problems knowing which was the right site. Before i go further does it work on mac? Or is it pc only?
Spears & Munsil UHD HDR Benchmark.
I tried to convert "Dolby Vision MEL demo" (20001.m2ts) to ts via 1.15.1 and tsmuxer (nightly 03.30), and seems DV was lost in result.
Dolby Vision MEL demo (20001.m2ts):
Dolby Vision MEL demo (mkv-to-ts):
FEL demo converted with DV, but sadly Plex player on Shield TV stop play it at some timemarks (first one is around 1:25)
Dolby Vision FEL demo (20000.m2ts):
Dolby Vision FEL demo (mkv-to-ts):
Video #1
Menu ID : 1 (0x1)
Format : HEVC
HDR format : SMPTE ST 2086, HDR10 compatible
Codec ID : 36
Duration : 7 min 45 s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display color primaries : BT.2020
Mastering display luminance : min: 0.0050 cd/m2, max: 10000 cd/m2
Maximum Content Light Level : 10000 cd/m2
Maximum Frame-Average Light Level : 1676 cd/m2
Video #2
Menu ID : 1 (0x1)
Format : HEVC
Codec ID : 36
Width : 1 920 pixels
Height : 1 080 pixels
Color space : YUV
Bit depth : 10 bits
Video
Menu ID : 1 (0x1)
Format : HEVC
Codec ID : 36
Bit rate : 73.3 Mb/s
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.369
Stream size : 3.97 GiB (94%)
Language : English
Video #1
Menu ID : 1 (0x1)
Format : HEVC
Codec ID : 36
Color space : YUV
Bit depth : 10 bits
Video #2
Menu ID : 1 (0x1)
Format : HEVC
Codec ID : 36
Color space : YUV
Bit depth : 10 bits
Video
Menu ID : 1 (0x1)
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.04.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Codec ID : 36
Bit rate : 78.2 Mb/s
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.393
Stream size : 4.24 GiB (94%)
Language : English
