Knives Out UHD
VeryWittyName
Re: Knives Out UHD
#31 Post by VeryWittyName » Mon Mar 30, 2020 11:34 am
Submitted the UK release dump.
jonghotti
Re: Knives Out UHD
#32 Post by jonghotti » Mon Mar 30, 2020 1:25 pm
jonghotti wrote: Wed Mar 25, 2020 5:16 am No problems here with full disc backup of this movie.
This statement was incorrect, my apologies.
Re: Knives Out UHD
#33 Post by SamuriHL » Mon Mar 30, 2020 6:46 pm
jonghotti wrote: Mon Mar 30, 2020 1:25 pm
Right, a full backup requires the jars on the disc to be patched so that the menu points to the correct playlist when AACS encryption is removed. Currently, afaik, MakeMKV does not alter full backups except for AACS removal (both AACS 2 and AACS 2.1). Therefore a full backup of a screen pass protected disc will not work correctly.
jonghotti
Re: Knives Out UHD
#34 Post by jonghotti » Wed Apr 01, 2020 10:12 pm
SamuriHL wrote: Mon Mar 30, 2020 6:46 pm
So has a case been opened for that?
Re: Knives Out UHD
#35 Post by SamuriHL » Wed Apr 01, 2020 10:53 pm
jonghotti wrote: Wed Apr 01, 2020 10:12 pm
I'm not sure what you mean by a case? A request to Mike, you mean? I don't know. I've never asked for it. I deal with screen pass in other ways.
figrin_dan
Re: Knives Out UHD
#36 Post by figrin_dan » Mon Apr 13, 2020 5:45 pm
This disc has ruined my weekend.
Makemkv starts as normal and recognises it but starts making some nasty noises and warns that it can't read it. So I cleaned the disc then makmkv wouldn't even recognise it was inserted (or any other UHD or BD I tried), even after reboots. I assumed my drive was broken.
The next day I tried again with exactly the same results.
Today I tried a different UHD and all was fine. I'm scared to try Knives Out again but all else appears ok.
Just that disc seems to temporarily kill my drive. Weird.
mrmbaa
Re: Knives Out UHD
#37 Post by mrmbaa » Thu Apr 16, 2020 5:57 pm
Has anyone managed to rip the UK version? I'm still getting "The volume key is unknown for this disc - video can't be decrypted" and submitted the dump last Friday
Chipless
Re: Knives Out UHD
#38 Post by Chipless » Thu May 07, 2020 6:21 pm
SamuriHL wrote: Wed Apr 01, 2020 10:53 pm
How do you deal with screen pass discs? My full backup of the UHD Knives Out doesn't play via my Oppo, but just sits at a black screen and never populates the menu loading screen. Display on the Oppo reads zeroes for chapter, time, etc. Sounds like this is a known issue, but hoping for a work around.
Chipless
Re: Knives Out UHD
#39 Post by Chipless » Thu May 07, 2020 6:26 pm
speeddemon wrote: Thu Mar 05, 2020 7:09 am Is there eventually going to be a fix in MakeMKV to enable us to perform full backups of these films while removing ScreenPass?
My issue is that the I want to be able to backup my movies so I can play them back on my Oppo BDP-203, but I don't want to lose Dolby Vision in the process.
If I have to just backup Playlist 945 in this case to an MKV file then I lose the ability to playback Dolby Vision and also run into the Oppo's "issues" with Dolby Atmos tracks in MKV files.
I'm in the exact same boat. Hoping for an update on this issue.
Chipless
Re: Knives Out UHD
#40 Post by Chipless » Tue May 12, 2020 1:54 am
Anyone have a status update regarding this UHD disc and full backups? Or have any alternative suggestions in general?
msl0426
Re: Knives Out UHD
#41 Post by msl0426 » Tue May 26, 2020 5:50 pm
Chipless wrote: Thu May 07, 2020 6:26 pm
Just wanted to give this a bump. I'm trying other methods but I can't seem to figure out how to deal with screen pass when playing back on an Oppo 203.
xmenw
Re: Knives Out UHD
#42 Post by xmenw » Sun Jun 14, 2020 5:34 am
Mike,
We'd definitely appreciate if you would look into this.
Thank you.
ictbydesign
Re: Knives Out UHD
#43 Post by ictbydesign » Mon Jun 15, 2020 7:23 pm
I have the Zavvi Steelbook version and have the same issue.
colgate2004
Re: Knives Out UHD
#44 Post by colgate2004 » Thu Jul 09, 2020 4:35 pm
FWIW, the Netflix disc I got does not have a 945.mpls. Goes from 00942 to 00950.
Re: Knives Out UHD
#45 Post by shawnc22 » Thu Jul 09, 2020 7:33 pm
colgate2004 wrote: Thu Jul 09, 2020 4:35 pm FWIW, the Netflix disc I got does not have a 945.mpls. Goes from 00942 to 00950.
since when did netflix start offering uhd discs?
