WH14NS40 reads UHD, makes backup but...
The_AVB
#1 Post by The_AVB » Thu May 07, 2020 5:19 pm
I have this drive and it is from 2015. It has never been updated and does read UHD discs and makes a backup. I used MakeMKV 1.15.1 to make the backup. However, when I use Open files on the discatt.dat file it reads the file (Opening files on harddrive at F:/To Video File/Dark Phoenix (4K MKV) but fails to open disc.
Since I don't get a Volume key error and the disc is old enough to have a Volume key by now and it is a LibreDrive I'm at a loss of why I can't open the backup and rip it. Any thoughts?
OS device name: I:
Product: BD-RE WH14NS40
Revision: 1.00
Serial number: SIK9MF9HJ091
Firmware date: 2115-08-18 09:40
Highest AACS version: 70
Firmware version: 1.00
jonghotti
Re: WH14NS40 reads UHD, makes backup but...
#2 Post by jonghotti » Thu May 07, 2020 5:22 pm
MT1959 hardware running 1.00 are notoriously flaky. This is one of those that most likely won't accept a firmware update. All bets are off with this drive based my experiences with 3 others.
The_AVB
#3 Post by The_AVB » Thu May 07, 2020 10:08 pm
Thank you for the reply. If I was feeling brave or stupid enough what should I upgrade it to?
jonghotti
#4 Post by jonghotti » Fri May 08, 2020 4:45 am
1.02 has traditionally been the stable, original UHD friendly firmware. It may not take a flash though. I got no love from either of the 1.00s I had, nothing but trouble.
The_AVB
#5 Post by The_AVB » Sat May 09, 2020 4:48 pm
Since it already makes a backup copy with no errors shown, are you saying that the really are errors in the backup that only appear when trying to open the discatt.day file?
The_AVB
#6 Post by The_AVB » Sun May 10, 2020 12:50 pm
Well I did get it to flash to 1.03 now I have to borrow another 4K disk to see if that changed anything.
#7 Post by Billycar11 » Sun May 10, 2020 3:09 pm
The_AVB wrote: Sun May 10, 2020 12:50 pm Well I did get it to flash to 1.03 now I have to borrow another 4K disk to see if that changed anything.
1.03 from LG or 1.03mk?
The_AVB
#8 Post by The_AVB » Sun May 10, 2020 6:28 pm
1.03 from LG.
#9 Post by Billycar11 » Sun May 10, 2020 7:51 pm
The_AVB wrote: Sun May 10, 2020 6:28 pm1.03 from LG.
yeah it wont read UHD anymore now
The_AVB
#10 Post by The_AVB » Sun May 10, 2020 8:46 pm
Will it take a reflash to a mk 1.02 or 1.03?
#11 Post by Billycar11 » Sun May 10, 2020 9:05 pm
The_AVB wrote: Sun May 10, 2020 8:46 pm Will it take a reflash to a mk 1.02 or 1.03?
yeah but i recommend WH16NS60 1.02mk
jonghotti
#12 Post by jonghotti » Sun May 10, 2020 9:56 pm
Cross yer fingers!!
The_AVB
#13 Post by The_AVB » Mon May 11, 2020 2:05 pm
Well it did flash to WH16NS60 1.02 so now I have to get a disc to test it with. Thanks everybody for the help.
