darrrkmanxxx
#2371 Post by darrrkmanxxx » Thu May 07, 2020 7:46 am
darrrkmanxxx wrote:
Wed May 06, 2020 4:17 pm
shawnc22 wrote:
Wed May 06, 2020 3:56 pm
You're on the wrong version of python
yusesope wrote:
Wed Mar 04, 2020 3:36 pm
For those who want to use the command line (on Windows, MacOS and Linux), you can use your version of Python (with python >= 3) but you must first install "bitstring"
pip install bitstring
Thank you so much it's working now!
unfortunately Yusesope's tool didn't helped for my setup, since it only makes dvhe.08.06, BL+RPU and dvhe.06.06, BL+EL+RPU
what I need is dvhe.05.06, BL+RPU
Does anyone know how gat I get this profile ino a ts container or how can I demux that from an mp4?
shroomM
#2372 Post by shroomM » Thu May 07, 2020 9:17 am
ATD555 wrote:
Wed May 06, 2020 9:01 pm
shroomM wrote:
Wed May 06, 2020 4:02 pm
Great tool, @yusesope, thank you!
I have a question - would it be possible (and not too complicated) to reverse what it does?
For example, if I have a final.hevc file with BL+EL+RPU, it would be awesome if it could split it into two (BL.hevc, EL.hevc) or even three (BL.hevc, EL.hevc, RPU) files.
Why not just keep the BL.hevc and EL.hevc which you would need to use the tool anyway? BL is the first video layer and EL is the second layer, you get them by demuxing the .m2ts file
This is assuming I'm coming from a blu-ray m2ts.
I have a couple of already merged files with BL+EL+RPU and some with BL+RPU.
It'd be interesting to "split" them into separate layers. Maybe see if we can use the RPU with x265's RPU option, though I don't know if that would even work.
Grencola
#2373 Post by Grencola » Fri May 08, 2020 1:48 am
check this out, in Kodi 18 no less! this is on the Ugoos AM6 Plus, ff to around 5m15s: https://drive.google.com/file/d/1cpBJSM ... Wt_2A/view
mulucy
#2374 Post by mulucy » Fri May 08, 2020 2:14 am
I noticed he said "Single Layer", any idea what profile he is talking about?
Grencola
#2375 Post by Grencola » Fri May 08, 2020 2:43 am
not sure, but judging by the mp4 and pcm audio I'm guessing profile 7.
Also, the guy who sent me this video said profile 5 dv rips work in kodi 19 on his shield. can anyone with a shield verify that?
#2376 Post by shawnc22 » Fri May 08, 2020 5:13 am
Looks like it. Installed the nightly version of kodi 19 and went through a bunch of sample files I had. The only one that worked was a profile 5 mp4 that I made with yusecope's tool in mode 2 and mp4muxer. All the other profile 4/7 mp4s/ts files played in just hdr. Same file also refused to play on kodi 18.
Jman5150
#2377 Post by Jman5150 » Fri May 08, 2020 7:16 am
I googled mp4mux and had problems knowing which was the right site. Before i go further does it work on mac? Or is it pc only?
lexyz
#2378 Post by lexyz » Fri May 08, 2020 7:38 am
Spears & Munsil UHD HDR Benchmark.
I tried to convert "Dolby Vision MEL demo" (20001.m2ts) to ts via 1.15.1 and tsmuxer (nightly 03.30), and seems DV was lost in result.
Dolby Vision MEL demo (20001.m2ts):
Video #1
HDR format                               : SMPTE ST 2086, HDR10 compatible
Duration                                 : 7 min 45 s
Mastering display color primaries        : BT.2020
Mastering display luminance              : min: 0.0050 cd/m2, max: 10000 cd/m2
Maximum Content Light Level              : 10000 cd/m2
Maximum Frame-Average Light Level        : 1676 cd/m2
Video #2
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Dolby Vision MEL demo (mkv-to-ts):
Video
Bit rate                                 : 73.3 Mb/s
Bits/(Pixel*Frame)                       : 0.369
Stream size                              : 3.97 GiB (94%)
FEL demo converted with DV, but sadly Plex player on Shield TV stop play it at some timemarks (first one is around 1:25)
Dolby Vision FEL demo (20000.m2ts):
Video #1
Video #2
Dolby Vision FEL demo (mkv-to-ts):
Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.04.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Bit rate                                 : 78.2 Mb/s
Bits/(Pixel*Frame)                       : 0.393
Stream size                              : 4.24 GiB (94%)
Kolci
#2379 Post by Kolci » Fri May 08, 2020 11:52 am
Hi, I converted the iso to Dolby Vision mp4, when I turn on the subtitles the video starts to stutter. Where could the problem be? My TV is TCL ep680.
box4m
#2380 Post by box4m » Fri May 08, 2020 12:20 pm
Forgive me but, profile 7 is dual layer or no?
mrhollywood
#2381 Post by mrhollywood » Fri May 08, 2020 12:37 pm
This? https://github.com/DolbyLaboratories/dlb_mp4base
Grencola
#2382 Post by Grencola » Fri May 08, 2020 1:19 pm
yep
MastaG
#2383 Post by MastaG » Fri May 08, 2020 3:33 pm
I'm trying the latest python version of yusesope 0.0.3 rev1 on Westworld Season 1 disc 1.
And it seems to hang at 100%... it doesn't get to the point where you can press some key to close.
Any ideas?
kazuma
#2384 Post by kazuma » Fri May 08, 2020 3:50 pm
the command program suddenly stopped working with birds of prey. anyone the same issue? the DV file is continue 0kb. anyone the same?
kws53
#2385 Post by kws53 » Fri May 08, 2020 7:25 pm
Have just created an ATMOS/DV for Gemini Man and have a few questions for the group. My process is simple: Clean ISO -> MPLS -> TSMuxer->TS or M2TS. Questions:
1) Why is the M2TS file 1.5GB larger? The same source file was used for both results - I simply used a different muxing option (TS vs M2TS) in TSMuxer and the TS file is 78,662,097 KB vs M2TS is 80,364,042 KB. Seems like an awful lot of overhead for M2TS. MediaInfo shows that the Overall/Maximum bit rate is 91.8/35.5 Mb/s for the TS, whereas for the M2TS file they are 93.7/35.5. Curious?
2) What is the advantage to using M2TS? My setup is NAS->X700->DV/ATMOS AVR->4K TV. It seems that the X700 has pause/FF/RW issues with TS files - same issue with M2TS?
3) MediaInfo tells me that neither file has the THD track (but MKV Toolnix disagrees, must be bug in MediaInfo). Although clearly not the case, MediaInfo audio shows:
Compression mode : Lossy
Stream size : 536 MiB (1%)
4) Both files show: Dolby Vision, Version 1.0, dvhe.07.07, EL+RPU, 8 compatible / SMPTE ST 2086, HDR10 compatible. Is this compatible with correct profile.level for usage in X700? (What is level exactly?)
Thanks in advance...
