Grencola
Post by Grencola » Thu May 07, 2020 12:02 am
mulucy wrote:
Wed May 06, 2020 10:13 pm
New Android TV device with DV/Atmos support from Tivo - looks pretty good https://www.tivo.com/products/stream-4k
same old song and dance.. no ethernet, no usb ports, low ram, and no hd-audio
zalman
Post by zalman » Thu May 07, 2020 12:41 am
I use this in my LG B8 TV. USB 3.0 to Gigabit Ethernet Adapter
TickTock
Post by TickTock » Thu May 07, 2020 2:42 am
It has a micro USB port and a USB C port. I'm guessing the micro USB port is for power which leaves the USB C port for an ethernet adapter/USB C to USB 3 micro b cable (external hard drive) or a hub with both ethernet and USB ports.
Would running Android mean it may be possible for app developers to work out a way to pass through HD audio to an AVR/soundbar?
Grencola
Post by Grencola » Thu May 07, 2020 2:50 am
Yea, it's basically just like the firestick 4k. it has an ethernet adapter that works the same way. but it's only 10/100mbps so not gigabit. and no, again like the firestick, if hd-audio isn't supported in the firmware, it's not going to be able to passthrough anything more than dd+.
TickTock
Post by TickTock » Thu May 07, 2020 3:06 am
USB C gigabit ethernet adapters should be able to be used (providing they are compatible with Android). Ah, so the only way to get HD audio passthrough would be with custom firmware, which there may be more of a possibility happening than say with the Firestick, given the device is running Android, but it probably won't happen.
darrrkmanxxx
Post by darrrkmanxxx » Thu May 07, 2020 7:46 am
darrrkmanxxx wrote:
Wed May 06, 2020 4:17 pm
shawnc22 wrote:
Wed May 06, 2020 3:56 pm
You're on the wrong version of python
yusesope wrote:
Wed Mar 04, 2020 3:36 pm
For those who want to use the command line (on Windows, MacOS and Linux), you can use your version of Python (with python >= 3) but you must first install "bitstring"
pip install bitstring
Thank you so much it's working now!
unfortunately Yusesope's tool didn't helped for my setup, since it only makes dvhe.08.06, BL+RPU and dvhe.06.06, BL+EL+RPU
what I need is dvhe.05.06, BL+RPU
Does anyone know how gat I get this profile ino a ts container or how can I demux that from an mp4?
shroomM
Post by shroomM » Thu May 07, 2020 9:17 am
ATD555 wrote:
Wed May 06, 2020 9:01 pm
shroomM wrote:
Wed May 06, 2020 4:02 pm
Great tool, @yusesope, thank you!
I have a question - would it be possible (and not too complicated) to reverse what it does?
For example, if I have a final.hevc file with BL+EL+RPU, it would be awesome if it could split it into two (BL.hevc, EL.hevc) or even three (BL.hevc, EL.hevc, RPU) files.
Why not just keep the BL.hevc and EL.hevc which you would need to use the tool anyway? BL is the first video layer and EL is the second layer, you get them by demuxing the .m2ts file
This is assuming I'm coming from a blu-ray m2ts.
I have a couple of already merged files with BL+EL+RPU and some with BL+RPU.
It'd be interesting to "split" them into separate layers. Maybe see if we can use the RPU with x265's RPU option, though I don't know if that would even work.
Grencola
Post by Grencola » Fri May 08, 2020 1:48 am
check this out, in Kodi 18 no less! this is on the Ugoos AM6 Plus, ff to around 5m15s: https://drive.google.com/file/d/1cpBJSM ... Wt_2A/view
mulucy
Post by mulucy » Fri May 08, 2020 2:14 am
I noticed he said "Single Layer", any idea what profile he is talking about?
Grencola
Post by Grencola » Fri May 08, 2020 2:43 am
not sure, but judging by the mp4 and pcm audio I'm guessing profile 7.
Also, the guy who sent me this video said profile 5 dv rips work in kodi 19 on his shield. can anyone with a shield verify that?
Post by shawnc22 » Fri May 08, 2020 5:13 am
Looks like it. Installed the nightly version of kodi 19 and went through a bunch of sample files I had. The only one that worked was a profile 5 mp4 that I made with yusecope's tool in mode 2 and mp4muxer. All the other profile 4/7 mp4s/ts files played in just hdr. Same file also refused to play on kodi 18.
Jman5150
Post by Jman5150 » Fri May 08, 2020 7:16 am
I googled mp4mux and had problems knowing which was the right site. Before i go further does it work on mac? Or is it pc only?
lexyz
Post by lexyz » Fri May 08, 2020 7:38 am
Spears & Munsil UHD HDR Benchmark.
I tried to convert "Dolby Vision MEL demo" (20001.m2ts) to ts via 1.15.1 and tsmuxer (nightly 03.30), and seems DV was lost in result.
Dolby Vision MEL demo (20001.m2ts):
Video #1
HDR format                               : SMPTE ST 2086, HDR10 compatible
Duration                                 : 7 min 45 s
Mastering display color primaries        : BT.2020
Mastering display luminance              : min: 0.0050 cd/m2, max: 10000 cd/m2
Maximum Content Light Level              : 10000 cd/m2
Maximum Frame-Average Light Level        : 1676 cd/m2
Video #2
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Dolby Vision MEL demo (mkv-to-ts):
Video
Bit rate                                 : 73.3 Mb/s
Bits/(Pixel*Frame)                       : 0.369
Stream size                              : 3.97 GiB (94%)
FEL demo converted with DV, but sadly Plex player on Shield TV stop play it at some timemarks (first one is around 1:25)
Dolby Vision FEL demo (20000.m2ts):
Video #1
Video #2
Dolby Vision FEL demo (mkv-to-ts):
Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.04.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Bit rate                                 : 78.2 Mb/s
Bits/(Pixel*Frame)                       : 0.393
Stream size                              : 4.24 GiB (94%)
Kolci
Post by Kolci » Fri May 08, 2020 11:52 am
Hi, I converted the iso to Dolby Vision mp4, when I turn on the subtitles the video starts to stutter. Where could the problem be? My TV is TCL ep680.
box4m
Post by box4m » Fri May 08, 2020 12:20 pm
Forgive me but, profile 7 is dual layer or no?
