Trujax
#2356 Post by Trujax » Wed May 06, 2020 12:14 pm
darrrkmanxxx wrote: Wed May 06, 2020 9:59 am Please tell me wehere can I get the latest Yusesope's tool version or any version :)
https://www.makemkv.com/forum/viewtopic ... 335#p85413
darrrkmanxxx
#2357 Post by darrrkmanxxx » Wed May 06, 2020 12:21 pm
This is how I tried to use yusesope's tool on macos, version 0.0.2 is the only I found:
python /Volumes/Data/bl_el_rpu_builder_temp_version_revision_2.py -bl /Volumes/Data/bl.hevc -el /Volumes/Data/el.hevc -of /Volumes/Data/full.hevc
this is what I get:
Traceback (most recent call last):
  File "/Volumes/Data/bl_el_rpu_builder_temp_version_revision_2.py", line 6, in <module>
    import queue
ImportError: No module named queu
Any Idea why?
When I try to install queue:
 pip install queue
I get this:
DEPRECATION: Python 2.7 reached the end of its life on January 1st, 2020. Please upgrade your Python as Python 2.7 is no longer maintained. pip 21.0 will drop support for Python 2.7 in January 2021. More details about Python 2 support in pip, can be found at https://pip.pypa.io/en/latest/development/release-process/#python-2-support
ERROR: Could not find a version that satisfies the requirement queue (from versions: none)
ERROR: No matching distribution found for queue
Can somebody help me?
darrrkmanxxx
#2358 Post by darrrkmanxxx » Wed May 06, 2020 3:28 pm
Trujax wrote: Wed May 06, 2020 12:14 pm
thanks man, still having this bug on macos:
ImportError: No module named queue
#2359 Post by shawnc22 » Wed May 06, 2020 3:56 pm
You're on the wrong version of python
yusesope wrote: Wed Mar 04, 2020 3:36 pm For those who want to use the command line (on Windows, MacOS and Linux), you can use your version of Python (with python >= 3) but you must first install "bitstring"
pip install bitstring
shroomM
#2360 Post by shroomM » Wed May 06, 2020 4:02 pm
Great tool, @yusesope, thank you!
I have a question - would it be possible (and not too complicated) to reverse what it does?
For example, if I have a final.hevc file with BL+EL+RPU, it would be awesome if it could split it into two (BL.hevc, EL.hevc) or even three (BL.hevc, EL.hevc, RPU) files.
darrrkmanxxx
#2361 Post by darrrkmanxxx » Wed May 06, 2020 4:17 pm
shawnc22 wrote: Wed May 06, 2020 3:56 pm You're on the wrong version of python
Thank you so much it's working now!
ATD555
#2362 Post by ATD555 » Wed May 06, 2020 9:01 pm
shroomM wrote: Wed May 06, 2020 4:02 pm Great tool, @yusesope, thank you!
Why not just keep the BL.hevc and EL.hevc which you would need to use the tool anyway? BL is the first video layer and EL is the second layer, you get them by demuxing the .m2ts file
mulucy
#2363 Post by mulucy » Wed May 06, 2020 10:13 pm
New Android TV device with DV/Atmos support from Tivo - looks pretty good https://www.tivo.com/products/stream-4k
Grencola
#2364 Post by Grencola » Thu May 07, 2020 12:02 am
mulucy wrote: Wed May 06, 2020 10:13 pm New Android TV device with DV/Atmos support from Tivo - looks pretty good https://www.tivo.com/products/stream-4k
same old song and dance.. no ethernet, no usb ports, low ram, and no hd-audio
TickTock
#2365 Post by TickTock » Thu May 07, 2020 2:42 am
Grencola wrote: Thu May 07, 2020 12:02 am
It has a micro USB port and a USB C port. I'm guessing the micro USB port is for power which leaves the USB C port for an ethernet adapter/USB C to USB 3 micro b cable (external hard drive) or a hub with both ethernet and USB ports.
Would running Android mean it may be possible for app developers to work out a way to pass through HD audio to an AVR/soundbar?
Grencola
#2366 Post by Grencola » Thu May 07, 2020 2:50 am
TickTock wrote: Thu May 07, 2020 2:42 am
Yea, it's basically just like the firestick 4k. it has an ethernet adapter that works the same way. but it's only 10/100mbps so not gigabit. and no, again like the firestick, if hd-audio isn't supported in the firmware, it's not going to be able to passthrough anything more than dd+.
TickTock
#2367 Post by TickTock » Thu May 07, 2020 3:06 am
Grencola wrote: Thu May 07, 2020 2:50 am
USB C gigabit ethernet adapters should be able to be used (providing they are compatible with Android). Ah, so the only way to get HD audio passthrough would be with custom firmware, which there may be more of a possibility happening than say with the Firestick, given the device is running Android, but it probably won't happen.
darrrkmanxxx
#2368 Post by darrrkmanxxx » Thu May 07, 2020 7:46 am
darrrkmanxxx wrote: Wed May 06, 2020 4:17 pm
unfortunately Yusesope's tool didn't helped for my setup, since it only makes dvhe.08.06, BL+RPU and dvhe.06.06, BL+EL+RPU
what I need is dvhe.05.06, BL+RPU
Does anyone know how gat I get this profile ino a ts container or how can I demux that from an mp4?
shroomM
#2369 Post by shroomM » Thu May 07, 2020 9:17 am
ATD555 wrote: Wed May 06, 2020 9:01 pm
This is assuming I'm coming from a blu-ray m2ts.
I have a couple of already merged files with BL+EL+RPU and some with BL+RPU.
It'd be interesting to "split" them into separate layers. Maybe see if we can use the RPU with x265's RPU option, though I don't know if that would even work.
Grencola
#2370 Post by Grencola » Fri May 08, 2020 1:48 am
check this out, in Kodi 18 no less! this is on the Ugoos AM6 Plus, ff to around 5m15s: https://drive.google.com/file/d/1cpBJSM ... Wt_2A/view
