uhd friendly drives not being uhd friendly
Jman5150
#1 Post by Jman5150 » Thu May 07, 2020 6:16 am
i have both newly gotten ...
ASUS BW-16D1HT
and
LG WH16NS40
both are ejecting uhd right away....is this normal?
I was on the understanding these two drives cold transfer data from uhd even though they aren't uhd burners...was i misinformed?
could the case its in make a difference? getting frustrated.
thanks in advanced
st4evr
Re: uhd friendly drives not being uhd friendly
#2 Post by st4evr » Thu May 07, 2020 9:05 pm
Gonna have to provide more details so that someone can better advise if possible. Help us help you. Being vague and/or simply saying “they don’t work” is not enough to help in an online forum.
Have you read the guide?
https://www.makemkv.com/forum/viewtopic ... 16&t=19634
Did you already flash your drives with the correct required (or any) firmware to make them UHD Friendly?
If so, which one?
When you open MakeMKV it will report drive information in a similar fashion to how it’s posted here by another forum member:
https://www.makemkv.com/forum/viewtopic ... 19&t=21793
So, what is the drive information as returned by MakeMKV for those drives?
How old are these drives? Recently purchased or years old?
BlueMac77
#3 Post by BlueMac77 » Fri May 08, 2020 5:53 pm
Jman5150 wrote: Thu May 07, 2020 6:16 am i have both newly gotten ...
ASUS BW-16D1HT
and
LG WH16NS40
thanks in advanced
Your drives ejecting 4K UHD discs, it’s probable your ASUS BW-16D1HT and LG WH16NS40 don’t have the correct firmware to read and rip 4K UHD discs. I have a ASUS BW-16D1HT drive and rips 4K UHD in Mac OS High Sierra or Mojave.
jayb3369
#4 Post by jayb3369 » Sun May 10, 2020 1:44 am
BlueMac77 wrote: Fri May 08, 2020 5:53 pm
ASUS BW-16D1HT
and
LG WH16NS40
thanks in advanced
BlueMac77,
How do You flash the firmware using a Mac? Considering purchasing the same drive and enclosure on Amazon, but won’t until I know it’s Mac compatible
Thanks.
BlueMac77
#5 Post by BlueMac77 » Sat May 16, 2020 3:08 pm
jayb3369 wrote: Sun May 10, 2020 1:44 am
ASUS BW-16D1HT
and
LG WH16NS40
thanks in advanced
BlueMac77,
Thanks.
Hi. Sorry for the late reply. The flashing needs to be performed in a Windows OS. Cannot be done in a Mac OS. There's a complete guide on flashing in this Link, check it out. Some members here are offering flashing services like Jonghotti, BillyCar,MartyMcNuts, ASCom. Good Luck
jonghotti
#6 Post by jonghotti » Sun May 17, 2020 1:34 pm
ASUS BW-16D1HT
and
LG WH16NS40
thanks in advanced
BlueMac77,
Thanks.
If all you have is a Mac and need to flash a drive please contact me to simply purchase a pre-flashed solution and you'l be all set. <BlueMac77> and now jman <5150> are happy customers and wonderful muman beings as well!
