yes, it's a known issue with the x700... You can only play 1 TS DV file without rebooting the player.
It's weird that some are working perfectly in profile 5 for me. Is there a version of tsMuxer that makes a profile 6 file? If not, how are you making them?mulucy wrote: ↑Tue May 05, 2020 10:16 amI have encountered this behavior with Plex on Fire TV 4K Stick with profile 5 videos, profile 6 works fine. Don't own the Shield yet, but profile 5 also works on Apple TV 4K. I guess it has to do with Plex itself. I have given up submitting problems to Plex, they don't care tbhArbigator wrote: ↑Tue May 05, 2020 4:26 amHas anyone had some profile 5 movies just not play on the shield? I've made a few profile 5 movies lately, which have worked great, and others do nothing. The ones that don't work trigger dolby vision on the TV, but the plex video player is just in a paused state. I can skip forward, but then it just sits there at that frame and refuses to play, no audio either. An example with this behavior is Mission Impossible Fallout, and Saving Private Ryan. Not sure what's going wrong, everything seems fine in tsMuxer and yusesope's tool.
darrrkmanxxx
Please tell me wehere can I get the latest Yusesope's tool version or any version
https://www.makemkv.com/forum/viewtopic ... 335#p85413darrrkmanxxx wrote: ↑Wed May 06, 2020 9:59 amPlease tell me wehere can I get the latest Yusesope's tool version or any version![]()
darrrkmanxxx
This is how I tried to use yusesope's tool on macos, version 0.0.2 is the only I found:
this is what I get:
Any Idea why?
When I try to install queue:
I get this:
Can somebody help me?
python /Volumes/Data/bl_el_rpu_builder_temp_version_revision_2.py -bl /Volumes/Data/bl.hevc -el /Volumes/Data/el.hevc -of /Volumes/Data/full.hevc Code: Select all
Traceback (most recent call last):
File "/Volumes/Data/bl_el_rpu_builder_temp_version_revision_2.py", line 6, in <module>
import queue
ImportError: No module named queuWhen I try to install queue:
pip install queue Code: Select all
DEPRECATION: Python 2.7 reached the end of its life on January 1st, 2020. Please upgrade your Python as Python 2.7 is no longer maintained. pip 21.0 will drop support for Python 2.7 in January 2021. More details about Python 2 support in pip, can be found at https://pip.pypa.io/en/latest/development/release-process/#python-2-support
ERROR: Could not find a version that satisfies the requirement queue (from versions: none)
ERROR: No matching distribution found for queue-
darrrkmanxxx
thanks man, still having this bug on macos:Trujax wrote: ↑Wed May 06, 2020 12:14 pmhttps://www.makemkv.com/forum/viewtopic ... 335#p85413darrrkmanxxx wrote: ↑Wed May 06, 2020 9:59 amPlease tell me wehere can I get the latest Yusesope's tool version or any version![]()
ImportError: No module named queueRe: Dolby Vision now possible through MP4 Mux.
You're on the wrong version of python
yusesope wrote: ↑Wed Mar 04, 2020 3:36 pmFor those who want to use the command line (on Windows, MacOS and Linux), you can use your version of Python (with python >= 3) but you must first install "bitstring"Code: Select all
pip install bitstring
Great tool, @yusesope, thank you!
I have a question - would it be possible (and not too complicated) to reverse what it does?
For example, if I have a final.hevc file with BL+EL+RPU, it would be awesome if it could split it into two (BL.hevc, EL.hevc) or even three (BL.hevc, EL.hevc, RPU) files.
darrrkmanxxx
Thank you so much it's working now!shawnc22 wrote: ↑Wed May 06, 2020 3:56 pmYou're on the wrong version of pythonyusesope wrote: ↑Wed Mar 04, 2020 3:36 pmFor those who want to use the command line (on Windows, MacOS and Linux), you can use your version of Python (with python >= 3) but you must first install "bitstring"Code: Select all
Why not just keep the BL.hevc and EL.hevc which you would need to use the tool anyway? BL is the first video layer and EL is the second layer, you get them by demuxing the .m2ts fileshroomM wrote: ↑Wed May 06, 2020 4:02 pmGreat tool, @yusesope, thank you!
New Android TV device with DV/Atmos support from Tivo - looks pretty good https://www.tivo.com/products/stream-4k
same old song and dance.. no ethernet, no usb ports, low ram, and no hd-audiomulucy wrote: ↑Wed May 06, 2020 10:13 pmNew Android TV device with DV/Atmos support from Tivo - looks pretty good https://www.tivo.com/products/stream-4k
It has a micro USB port and a USB C port. I'm guessing the micro USB port is for power which leaves the USB C port for an ethernet adapter/USB C to USB 3 micro b cable (external hard drive) or a hub with both ethernet and USB ports.Grencola wrote: ↑Thu May 07, 2020 12:02 amsame old song and dance.. no ethernet, no usb ports, low ram, and no hd-audiomulucy wrote: ↑Wed May 06, 2020 10:13 pmNew Android TV device with DV/Atmos support from Tivo - looks pretty good https://www.tivo.com/products/stream-4k
Would running Android mean it may be possible for app developers to work out a way to pass through HD audio to an AVR/soundbar?
Yea, it's basically just like the firestick 4k. it has an ethernet adapter that works the same way. but it's only 10/100mbps so not gigabit. and no, again like the firestick, if hd-audio isn't supported in the firmware, it's not going to be able to passthrough anything more than dd+.TickTock wrote: ↑Thu May 07, 2020 2:42 amIt has a micro USB port and a USB C port. I'm guessing the micro USB port is for power which leaves the USB C port for an ethernet adapter/USB C to USB 3 micro b cable (external hard drive) or a hub with both ethernet and USB ports.Grencola wrote: ↑Thu May 07, 2020 12:02 amsame old song and dance.. no ethernet, no usb ports, low ram, and no hd-audiomulucy wrote: ↑Wed May 06, 2020 10:13 pmNew Android TV device with DV/Atmos support from Tivo - looks pretty good https://www.tivo.com/products/stream-4k
USB C gigabit ethernet adapters should be able to be used (providing they are compatible with Android). Ah, so the only way to get HD audio passthrough would be with custom firmware, which there may be more of a possibility happening than say with the Firestick, given the device is running Android, but it probably won't happen.Grencola wrote: ↑Thu May 07, 2020 2:50 amYea, it's basically just like the firestick 4k. it has an ethernet adapter that works the same way. but it's only 10/100mbps so not gigabit. and no, again like the firestick, if hd-audio isn't supported in the firmware, it's not going to be able to passthrough anything more than dd+.TickTock wrote: ↑Thu May 07, 2020 2:42 amIt has a micro USB port and a USB C port. I'm guessing the micro USB port is for power which leaves the USB C port for an ethernet adapter/USB C to USB 3 micro b cable (external hard drive) or a hub with both ethernet and USB ports.
