where can I get the latest version of Yusesope's tool and is there a guide on how to use it?Angryunibrow wrote: ↑Sun May 03, 2020 4:35 amSkip a step, use mode -2 then add to tsmuxer. You shouldn't need mp4muxertr000 wrote: ↑Sun May 03, 2020 4:04 amFor this to work, I had to use the .hevc generated with Yusesope's tool in Mode 1, then mux it with MP4Muxer in Profile 5, then put that into TSMuxer. Here are some MediaInfos. https://www.makemkv.com/forum/viewtopic ... 534#p88534darrrkmanxxx wrote: ↑Fri May 01, 2020 4:28 pmHey guys, how can I get dvhe.05.06, BL+RPU in a .ts container? With MakeMKV I can only get dvhe.06.06, BL+EL+RPU, which MX Player just won't recognise as Dolby Vision?
It is also strange, that MediaInfo shows HDR10 / HDR10 if video is dvhe.06.06, BL+EL+RPU and Dolby Vision / HDR10 if video is dvhe.05.06, BL+RPU.
Yeah, this is a thing - but only if you have a licensed PC (I think mostly some Lenovo and Dell laptops). This lets MS Edge, the Netflix and Windows TV/Movies app play single layer DV. It's enforced by loading a custom monitor ICC profile that matches against certain strings in the system BIOS, otherwise it throws up an error message when playing if you have that profile loaded but not a matching system.RESET_9999 wrote: ↑Sun May 03, 2020 8:50 pmI tried that and I try again every Windows update but it doesn't trigger DV on my end using the movies and tv app.Grencola wrote: ↑Sun May 03, 2020 8:15 pmis this a thing? https://www.microsoft.com/en-us/p/app/9 ... verviewtab maybe mpc-be or microsoft's new fancy edge browser can use this extension?
On Netflix, using the app or edge; when I press ctrl + alt + SHIFT + d, the stats say Dolby Vision HEVC but the tv doesn't trigger DV.
I think it's just missing a Dolby vision slidder in display setting like there is for HDR10. Maybe a future Windows update.
It would be great if they let us buy this functionality like Atmos for Headphones (/insert obligatory "shut up and take my money" meme here) but for whatever reason they don't. Maybe someone handy with a hex editor can poke around to see how this works...
Has anyone had some profile 5 movies just not play on the shield? I've made a few profile 5 movies lately, which have worked great, and others do nothing. The ones that don't work trigger dolby vision on the TV, but the plex video player is just in a paused state. I can skip forward, but then it just sits there at that frame and refuses to play, no audio either. An example with this behavior is Mission Impossible Fallout, and Saving Private Ryan. Not sure what's going wrong, everything seems fine in tsMuxer and yusesope's tool.
I have encountered this behavior with Plex on Fire TV 4K Stick with profile 5 videos, profile 6 works fine. Don't own the Shield yet, but profile 5 also works on Apple TV 4K. I guess it has to do with Plex itself. I have given up submitting problems to Plex, they don't care tbhArbigator wrote: ↑Tue May 05, 2020 4:26 amHas anyone had some profile 5 movies just not play on the shield? I've made a few profile 5 movies lately, which have worked great, and others do nothing. The ones that don't work trigger dolby vision on the TV, but the plex video player is just in a paused state. I can skip forward, but then it just sits there at that frame and refuses to play, no audio either. An example with this behavior is Mission Impossible Fallout, and Saving Private Ryan. Not sure what's going wrong, everything seems fine in tsMuxer and yusesope's tool.
I am having the following issue on the Sony UBP-X700, if I play a DV dual layer Profile 7 .TS file and then hit the 'Stop' button or 'Home' button the screen does this:
If I go to play another video (DV, non-DV, or 1080p) same thing. The menus on the player work fine. This is happening with both my own as well as my friend's X700
yes, it's a known issue with the x700... You can only play 1 TS DV file without rebooting the player.
It's weird that some are working perfectly in profile 5 for me. Is there a version of tsMuxer that makes a profile 6 file? If not, how are you making them?mulucy wrote: ↑Tue May 05, 2020 10:16 amI have encountered this behavior with Plex on Fire TV 4K Stick with profile 5 videos, profile 6 works fine. Don't own the Shield yet, but profile 5 also works on Apple TV 4K. I guess it has to do with Plex itself. I have given up submitting problems to Plex, they don't care tbhArbigator wrote: ↑Tue May 05, 2020 4:26 amHas anyone had some profile 5 movies just not play on the shield? I've made a few profile 5 movies lately, which have worked great, and others do nothing. The ones that don't work trigger dolby vision on the TV, but the plex video player is just in a paused state. I can skip forward, but then it just sits there at that frame and refuses to play, no audio either. An example with this behavior is Mission Impossible Fallout, and Saving Private Ryan. Not sure what's going wrong, everything seems fine in tsMuxer and yusesope's tool.
Please tell me wehere can I get the latest Yusesope's tool version or any version
https://www.makemkv.com/forum/viewtopic ... 335#p85413darrrkmanxxx wrote: ↑Wed May 06, 2020 9:59 amPlease tell me wehere can I get the latest Yusesope's tool version or any version![]()
This is how I tried to use yusesope's tool on macos, version 0.0.2 is the only I found:
this is what I get:
Any Idea why?
When I try to install queue:
I get this:
Can somebody help me?
python /Volumes/Data/bl_el_rpu_builder_temp_version_revision_2.py -bl /Volumes/Data/bl.hevc -el /Volumes/Data/el.hevc -of /Volumes/Data/full.hevc
Traceback (most recent call last):
File "/Volumes/Data/bl_el_rpu_builder_temp_version_revision_2.py", line 6, in <module>
import queue
ImportError: No module named queu
pip install queue
DEPRECATION: Python 2.7 reached the end of its life on January 1st, 2020. Please upgrade your Python as Python 2.7 is no longer maintained. pip 21.0 will drop support for Python 2.7 in January 2021. More details about Python 2 support in pip, can be found at https://pip.pypa.io/en/latest/development/release-process/#python-2-support
ERROR: Could not find a version that satisfies the requirement queue (from versions: none)
ERROR: No matching distribution found for queue
thanks man, still having this bug on macos:Trujax wrote: ↑Wed May 06, 2020 12:14 pmhttps://www.makemkv.com/forum/viewtopic ... 335#p85413darrrkmanxxx wrote: ↑Wed May 06, 2020 9:59 amPlease tell me wehere can I get the latest Yusesope's tool version or any version![]()
ImportError: No module named queue
You're on the wrong version of python
yusesope wrote: ↑Wed Mar 04, 2020 3:36 pmFor those who want to use the command line (on Windows, MacOS and Linux), you can use your version of Python (with python >= 3) but you must first install "bitstring"Code: Select all
pip install bitstring
Great tool, @yusesope, thank you!
I have a question - would it be possible (and not too complicated) to reverse what it does?
For example, if I have a final.hevc file with BL+EL+RPU, it would be awesome if it could split it into two (BL.hevc, EL.hevc) or even three (BL.hevc, EL.hevc, RPU) files.
Thank you so much it's working now!shawnc22 wrote: ↑Wed May 06, 2020 3:56 pmYou're on the wrong version of pythonyusesope wrote: ↑Wed Mar 04, 2020 3:36 pmFor those who want to use the command line (on Windows, MacOS and Linux), you can use your version of Python (with python >= 3) but you must first install "bitstring"Code: Select all
Why not just keep the BL.hevc and EL.hevc which you would need to use the tool anyway? BL is the first video layer and EL is the second layer, you get them by demuxing the .m2ts fileshroomM wrote: ↑Wed May 06, 2020 4:02 pmGreat tool, @yusesope, thank you!
