#2341 Post by shawnc22 » Fri May 01, 2020 6:05 pm
rosavanwinkle wrote: Fri May 01, 2020 5:45 pm but my tv does support atmos. i checked the site...this is so confusing xD
For a TV to be able to passthrough TrueHD Atmos lossless audio through HDMI, it needs e-ARC. That TV only has ARC (on HDMI input 2) and will be limited to at best passing through Dolby Digital+ Atmos lossy audio (those found in streaming apps).
rosavanwinkle
#2342 Post by rosavanwinkle » Fri May 01, 2020 6:50 pm
shawnc22 wrote: Fri May 01, 2020 6:05 pm
oh well,i accept that fate and will just use the underlaying ac3 audio core that comes with it. :/ its better then nothing
unless i find a solution
Mediaplayer: Nvidia Shield TV Pro
TV: LG 55SK7900PLA
Soundbar: LG SK8 (not LG SK8Y)
plex pass user
Discord:Rosa#1111
tr000
#2343 Post by tr000 » Sun May 03, 2020 4:04 am
darrrkmanxxx wrote: Fri May 01, 2020 4:28 pm Hey guys, how can I get dvhe.05.06, BL+RPU in a .ts container? With MakeMKV I can only get dvhe.06.06, BL+EL+RPU, which MX Player just won't recognise as Dolby Vision?
It is also strange, that MediaInfo shows HDR10 / HDR10 if video is dvhe.06.06, BL+EL+RPU and Dolby Vision / HDR10 if video is dvhe.05.06, BL+RPU.
For this to work, I had to use the .hevc generated with Yusesope's tool in Mode 1, then mux it with MP4Muxer in Profile 5, then put that into TSMuxer. Here are some MediaInfos. https://www.makemkv.com/forum/viewtopic ... 534#p88534
Angryunibrow
#2344 Post by Angryunibrow » Sun May 03, 2020 4:35 am
tr000 wrote: Sun May 03, 2020 4:04 am
Skip a step, use mode -2 then add to tsmuxer. You shouldn't need mp4muxer
TickTock
#2345 Post by TickTock » Sun May 03, 2020 5:25 am
shawnc22 wrote: Wed Apr 29, 2020 6:52 am
TickTock wrote: Wed Apr 29, 2020 6:19 am The clip @shawnc22 posted here:
https://www.makemkv.com/forum/viewtopic ... 613#p88613
works on my TV but when I attempted to create the same film it plays with a black screen and sound. The strange thing is both the clip and the film I created have exactly the same HDR format info:
HDR format: Dolby Vision, Version 1.0, dvhe.04.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
I'm trying to work out why my TV plays the clip but not the film.
My clip was made with yusecope's tool in the default mode. You may want to give that another try if you're using the video track from makemkv. I'm honestly not sure which version of tsmuxer will work correctly with the video tracks that makemkv is now generating. Even though all the mediainfo have looked good, sometimes the video track is just not getting picked up on playback. I thought I had the issue narrowed down to HDR10+ and recent versions of tsmuxer, but there've been so many reports of other films that I've just gone back to the old method (yusecope's tool) of making my TS remuxes. I've never had an issue with the video track not being picked up with yusecope's tool and any versions of tsmuxer. Most of my testing have been done on the shield, so I can't really speak to what should and shouldn't work on a TV's internal player.
Thanks for your response.
I used yusecope's tool in its default mode on the same film and it now works :). I tried working out the issue by creating the film with no sound, with sound (ac3) and with Dolby TrueHD Atmos. All files work but the file with Dolby TrueHD Atmost plays without audio because my TV only supports DD+ Atmos. I'm not sure why the file didn't work at first.
I tried a few more films and had problems with:
Earth One Amazing Day - The file starts with sound and the Dolby Vision logo is displayed but the film then freezes
Sicario Day of the Soldado - Black screen with sound and no Dolby Vision logo
Every film I created using MakeMKV doesn't work on the internal player of my TV. Hopefully future versions will resolve the problem. I plan on buying a Firestick 4K and I may purchase a Nvidia Shield in a few months.
TickTock
#2346 Post by TickTock » Sun May 03, 2020 5:27 am
badrobot wrote: Wed Apr 29, 2020 12:25 pm
badrobot wrote: Tue Apr 28, 2020 10:50 am
you got dhve 06.06 because you used mode 1 of yusesope's tool, and the new version of tsmuxer.
It seems that you download the wrong file ? I have tested the link. the date of tsmuxer.exe must be 2020-03-30.
mode 1 of yusesope's tool ——>BL+EL+RPU ——> dhve 04.06(old version of temuxer, I posted the link) or 06.06(new version of tsmuxer)
mode 2 of yusesope's tool ——>BL+RPU ——> dhve 05.06(old version of temuxer , I posted the link) or 08.06(new version of tsmuxer)
Oh, I used MakeMKV and tsMuxeR to create the file, I had tried yusesope's tool on a couple of films with mode 1 but they didn't work. I tried yusesope's tool with mode set as 2 and then used tsMuxeR and the film works perfectly, with the version of tsMuxeR you linked to (dvhe.05.06, BL+RPU) and the latest version (dvhe.08.06, BL+RPU). This is the first time I've been able to create a full playable Dolby Vision film. Thank you for your response and help :).
Do you know of a method to create working Dolby Vision films with?:
you need dhve 04.06? follow this:
1/ use ffmpeg to extract the BL to BL.hevc, EL+RPU to EL_RPU.hevc.
ffmpeg.exe -i d:\your_input_file.m2ts -map 0:0 -c copy d:\BL.hevc -map 0:1 -c copy d:\EL_RPU.hevc
2/ use mode 1 of yusesope's tool to mix BL.hevc and EL+RPU.hevc. example output file name FULL.hevc
python BL_EL_RPU_BUILDER.py -bl d:\BL.hevc -el d:\EL_RPU.hevc -of d:\FULL.hevc
3/ use old version of tsmuxer to remux FULL.hevc and sound track from m2ts(or other video file)
Bingo!
I managed to create working files by demuxing with tsMuxeR 2020-03-30 nightly and then using yusecope's tool in the default mode :). Thanks for telling me another method to achieve the same result, it's useful because for some reason files don't always work.
tr000
#2347 Post by tr000 » Sun May 03, 2020 7:38 am
Angryunibrow wrote: Sun May 03, 2020 4:35 am
If you read the post that was quoted in the post I quoted in the post that you quoted, you'll see that mode 2 was actually what caused problems for me. It would always give me a Profile 7 or 8 when put into TSMuxer, which my TV refused. Only mode 1 with MP4Muxer gave me a proper profile 5. Maybe it was just the particular movie.
Grencola
#2348 Post by Grencola » Sun May 03, 2020 8:15 pm
hepe9 wrote: Thu Mar 12, 2020 2:31 am I can't understand how is possible we don't have any windows player than can play DV
Only in Android
is this a thing? https://www.microsoft.com/en-us/p/app/9 ... verviewtab maybe mpc-be or microsoft's new fancy edge browser can use this extension?
#2349 Post by RESET_9999 » Sun May 03, 2020 8:50 pm
Grencola wrote: Sun May 03, 2020 8:15 pm is this a thing? https://www.microsoft.com/en-us/p/app/9 ... verviewtab maybe mpc-be or microsoft's new fancy edge browser can use this extension?
I tried that and I try again every Windows update but it doesn't trigger DV on my end using the movies and tv app.
On Netflix, using the app or edge; when I press ctrl + alt + SHIFT + d, the stats say Dolby Vision HEVC but the tv doesn't trigger DV.
I think it's just missing a Dolby vision slidder in display setting like there is for HDR10. Maybe a future Windows update.
Angryunibrow
#2350 Post by Angryunibrow » Sun May 03, 2020 10:26 pm
tr000 wrote: Sun May 03, 2020 7:38 am
Maybe tsmuxer was changed again to go back to profile 8, I still use an older build that makes -mode 2 files profile 5 and works great on the ATV4K. ATV4K will not play profile 8 so it looks like I won't be upgrading tsmuxer
darrrkmanxxx
#2351 Post by darrrkmanxxx » Mon May 04, 2020 7:26 am
where can I get the latest version of Yusesope's tool and is there a guide on how to use it?
crazydave
#2352 Post by crazydave » Mon May 04, 2020 8:53 pm
RESET_9999 wrote: Sun May 03, 2020 8:50 pm
Yeah, this is a thing - but only if you have a licensed PC (I think mostly some Lenovo and Dell laptops). This lets MS Edge, the Netflix and Windows TV/Movies app play single layer DV. It's enforced by loading a custom monitor ICC profile that matches against certain strings in the system BIOS, otherwise it throws up an error message when playing if you have that profile loaded but not a matching system.
It would be great if they let us buy this functionality like Atmos for Headphones (/insert obligatory "shut up and take my money" meme here) but for whatever reason they don't. Maybe someone handy with a hex editor can poke around to see how this works...
Arbigator
#2353 Post by Arbigator » Tue May 05, 2020 4:26 am
Has anyone had some profile 5 movies just not play on the shield? I've made a few profile 5 movies lately, which have worked great, and others do nothing. The ones that don't work trigger dolby vision on the TV, but the plex video player is just in a paused state. I can skip forward, but then it just sits there at that frame and refuses to play, no audio either. An example with this behavior is Mission Impossible Fallout, and Saving Private Ryan. Not sure what's going wrong, everything seems fine in tsMuxer and yusesope's tool.
mulucy
#2354 Post by mulucy » Tue May 05, 2020 10:16 am
Arbigator wrote: Tue May 05, 2020 4:26 am Has anyone had some profile 5 movies just not play on the shield? I've made a few profile 5 movies lately, which have worked great, and others do nothing. The ones that don't work trigger dolby vision on the TV, but the plex video player is just in a paused state. I can skip forward, but then it just sits there at that frame and refuses to play, no audio either. An example with this behavior is Mission Impossible Fallout, and Saving Private Ryan. Not sure what's going wrong, everything seems fine in tsMuxer and yusesope's tool.
I have encountered this behavior with Plex on Fire TV 4K Stick with profile 5 videos, profile 6 works fine. Don't own the Shield yet, but profile 5 also works on Apple TV 4K. I guess it has to do with Plex itself. I have given up submitting problems to Plex, they don't care tbh
ATD555
#2355 Post by ATD555 » Tue May 05, 2020 5:53 pm
I am having the following issue on the Sony UBP-X700, if I play a DV dual layer Profile 7 .TS file and then hit the 'Stop' button or 'Home' button the screen does this:
If I go to play another video (DV, non-DV, or 1080p) same thing. The menus on the player work fine. This is happening with both my own as well as my friend's X700
