Post by shawnc22 » Fri May 01, 2020 1:04 am
rosavanwinkle wrote: Thu Apr 30, 2020 9:49 pm hmmm i got a dolby atmos soundbar from LG along with a LG TV but i still need a AGC probably for it no?
Sorry I'm not really sure what AGC is. But moving past the fact that you can't really get real atmos sound out of a soundbar, if your set up is shield ->(hdmi) soundbar ->(hdmi) TV, you should at least be play to play files with atmos on your shield without getting an error, because an "atmos" soundbar is technically capable of decoding an atmos signal. If that's your configuration and things are still not working, please try playing an mkv with an atmos track and see if that's at least playing.
rosavanwinkle
Post by rosavanwinkle » Fri May 01, 2020 3:17 pm
shawnc22 wrote: Fri May 01, 2020 1:04 am
first off i wrote AGC instead of AVR that is on me (sorry)
second i'll try to find a atmos file (with hdr or something) and see if my soundbar pops up saying "dolby atmos"
my setup atm is: this pic basicly
Shield has a cat7 cable direct too the modem with a fiber connection
EDIT: updated the pic cause i'm a dumbasss
Mediaplayer: Nvidia Shield TV Pro
TV: LG 55SK7900PLA
Soundbar: LG SK8 (not LG SK8Y)
plex pass user
Discord:Rosa#1111
Post by shawnc22 » Fri May 01, 2020 3:30 pm
rosavanwinkle wrote: Fri May 01, 2020 3:17 pm first off i wrote AGC instead of AVR that is on me (sorry)
Yeah that’s not going to work. Your TV cannot passthrough the lossless atmos signal to your soundbar. You have to plug the shield directly into the soundbar.
rosavanwinkle
Post by rosavanwinkle » Fri May 01, 2020 3:38 pm
shawnc22 wrote: Fri May 01, 2020 3:30 pm
aight lets give that a shot one moment...
TV: LG 55SK7900PLA
plex pass user
Discord:Rosa#1111
Post by shawnc22 » Fri May 01, 2020 3:55 pm
rosavanwinkle wrote: Fri May 01, 2020 3:38 pm
Just looked at the specs of the SK6Y, and it doesn't look like it's capable of decoding an atmos signal. Unfortunately even with the correct connectivity, it's not going to work with your current equipment.
rosavanwinkle
Post by rosavanwinkle » Fri May 01, 2020 4:12 pm
i'm getting a lot of contradicting info on my soundbar from google i'm gonna check the box for a sec....
TV: LG 55SK7900PLA
plex pass user
Discord:Rosa#1111
rosavanwinkle
Post by rosavanwinkle » Fri May 01, 2020 4:20 pm
Alrighty...so i went to the basement found my box....
it is a SK8
this one has truehd and dolby atmos... i just have to figure out how to connect this badboy to the shield tv pro
it has a hdmi out (tv arc) , hdmi in,optical and ethernet port.
TV: LG 55SK7900PLA
plex pass user
Discord:Rosa#1111
darrrkmanxxx
Post by darrrkmanxxx » Fri May 01, 2020 4:28 pm
Hey guys, how can I get dvhe.05.06, BL+RPU in a .ts container? With MakeMKV I can only get dvhe.06.06, BL+EL+RPU, which MX Player just won't recognise as Dolby Vision?
It is also strange, that MediaInfo shows HDR10 / HDR10 if video is dvhe.06.06, BL+EL+RPU and Dolby Vision / HDR10 if video is dvhe.05.06, BL+RPU.
Post by shawnc22 » Fri May 01, 2020 4:31 pm
rosavanwinkle wrote: Fri May 01, 2020 4:20 pm Alrighty...so i went to the basement found my box....
it is a SK8
Then my previous statement still stands. shield pro into hdmi in of soundbar and then hdmi out from soundbar to tv.
rosavanwinkle
Post by rosavanwinkle » Fri May 01, 2020 5:07 pm
shawnc22 wrote: Fri May 01, 2020 4:31 pm
it is a SK8
good news and bad news
connected it as you said and yay i got dolby atmos sound! the soundbar switched (it gives a popup) and played truhd + atmos audio movies xD
now for the bad news,not sure if this is a cable issue,or if i'm wrong somewhere,but my shield suddenly switched to 1080P wtf...
https://i.imgur.com/eyKyQsH.png
EDIT: please don't tell me its because my soundbar doesn't have more modern hdmi ports....
would a splitter fix this?
TV: LG 55SK7900PLA
plex pass user
Discord:Rosa#1111
Post by shawnc22 » Fri May 01, 2020 5:22 pm
rosavanwinkle wrote: Fri May 01, 2020 5:07 pm
it is a SK8
Well unfortunately there lies your dilemma. Your TV can't passthrough truehd atmos and your soundbar can't passthrough a 4k/HDR signal. You might get away with using a splitter that has multiple outputs to go from your shield to the tv and shield to the soundbar simultaneously, but I honestly wouldn't bother. Getting a soundbar to process an atmos signal is not worth all this trouble imho. Plug the shield into the TV and call it a day.
rosavanwinkle
Post by rosavanwinkle » Fri May 01, 2020 5:45 pm
shawnc22 wrote: Fri May 01, 2020 5:22 pm
but my tv does support atmos. i checked the site...this is so confusing xD
TV: LG 55SK7900PLA
plex pass user
Discord:Rosa#1111
Post by shawnc22 » Fri May 01, 2020 6:05 pm
rosavanwinkle wrote: Fri May 01, 2020 5:45 pm but my tv does support atmos. i checked the site...this is so confusing xD
For a TV to be able to passthrough TrueHD Atmos lossless audio through HDMI, it needs e-ARC. That TV only has ARC (on HDMI input 2) and will be limited to at best passing through Dolby Digital+ Atmos lossy audio (those found in streaming apps).
rosavanwinkle
Post by rosavanwinkle » Fri May 01, 2020 6:50 pm
shawnc22 wrote: Fri May 01, 2020 6:05 pm
oh well,i accept that fate and will just use the underlaying ac3 audio core that comes with it. :/ its better then nothing
unless i find a solution
TV: LG 55SK7900PLA
plex pass user
Discord:Rosa#1111
tr000
Post by tr000 » Sun May 03, 2020 4:04 am
darrrkmanxxx wrote: Fri May 01, 2020 4:28 pm Hey guys, how can I get dvhe.05.06, BL+RPU in a .ts container? With MakeMKV I can only get dvhe.06.06, BL+EL+RPU, which MX Player just won't recognise as Dolby Vision?
For this to work, I had to use the .hevc generated with Yusesope's tool in Mode 1, then mux it with MP4Muxer in Profile 5, then put that into TSMuxer. Here are some MediaInfos. https://www.makemkv.com/forum/viewtopic ... 534#p88534
