With the new version of the user interface there came new bugs. It seems as no UI related issue was improved.
# wrong font size of the menu bar
# file open dialogue doesn't work anymore
# mkv now needs more hard disk space without any benefit in return
Tested in Windows XP.
new bugs in 1.15.x
Username1267
new bugs in 1.15.x
- file open.png (4.87 KiB) Viewed 10493 times
- menu.png (3.8 KiB) Viewed 10493 times
Re: new bugs in 1.15.x
I've been seeing a different UI issue - the Properties portion of the program window is missing in 1.15.1 on both of my systems, which makes it impossible to work with.
- Menu after opening disk with 1.14.7
- mkv1147menu.png (62.15 KiB) Viewed 10492 times
- Menu after opening disk with 1.15.1
- mkv1151menu.png (76.5 KiB) Viewed 10492 times
Good thread to gather bugs in one place.
Previously posted erroneous AV sync error messages: viewtopic.php?f=1&t=22082
@Username1267
In Win10 the font size of the menu bar is correct and the file open dialogue is functional.
Maybe you should edit the compatibility settings of the MakeMKV-Link or update your Windows.
- Contact:
Preferences - expert mode?Woodstock wrote: Sat May 02, 2020 3:21 pm I've been seeing a different UI issue - the Properties portion of the program window is missing in 1.15.1 on both of my systems, which makes it impossible to work with.
Yes, expert mode. At least the 1.14.7 install had it checked, but the 1.15.1 install had it unchecked.
This is the first time in years I've seen the install ignore the previous version's setting.
Edited to add: I figured out why it was off. I'd done some testing on whether or not Expert mode was required for disabling CC subtitles, and didn't reset the v1.14.7 install until AFTER I'd put a copy of 1.15.1 in... PEBCAK all the way.
