I have a Blu Ray disc that contains 9 TV episodes. When played in a player (PS3 is my main player) the EP are on titles 4-12. Each with 6 chapters. Chapter 1 being the opener, 2 being the first part of the show, 3 being the second part, 4 being the ending, chapter 5 being the next EP preview, and 6 being the English language credits.
My problem is when I put the disc into my computer (Both windows and mac versions of MakeMKV) it shows the first 9 titles being the 9 Episodes, all out of order. On top of that they only have 4 chapters, with only 3 accessible. Now this is where I am going to have a hard time explaining things.
Each of the 9 titles MakeMKV shows say they have the first 4 chapters, but really they only have the first 3, when it reaches the point of the 4th it loops back to the opening instead of the ending using Windows Media Player (everything up to date). Also when i try to remux these MKV files mkvtoolnix(latest version) just chops that part off saying there is a sync error.
In addition to these 9 titles containing the first 3 chapters, there are 9 other titles that contain the 6th chapter which is the English language credits. So basically everything is broken up and for some reason I can't access chapter 4 or 5th chapter. It looks like this
Title 1: EP 1 Chapters 1-4 (But only really 1 through 3)
Title 2: EP 3 Chapters 1-4 (But only really 1 through 3)
Title 3: EP 6Chapters 1-4 (But only really 1 through 3)
Title 9: EP 2 Chapters 1-4 (But only really 1 through 3)
Title 10: EP 1 Chapter 6
Title 11: EP 3 Chapter 6
Title 12: EP 6 Chapter 6
Title 18: EP 2 Chapters 6
The content is also 1080i VC1, which I thought was the problem as first till I realized thing where looping back on themselves. So far I have been able to extract chapter 1-3 (The opening and the EP content) and watch that fine using windows media player or after sending it through MEGUI for h264 transcoding and decombing using VLC. Anyway help would be great. Thanks in advance. Btw just in case, it is a legit retail Blu-Ray bought and paid for from a major online distributor. The back up is for personal use only.
Titles showing up differntly in player than MMKV (Blu)
setarip_old
Re: Titles showing up differntly in player than MMKV (Blu)
Hi!
I'd suggest you turn on the "Debug" function, re-rip your original Blu-ray disc using ONLY MakeMKV (no need for DVDfab, AnyDVD, etc. - and they may cause conflict with MakeMKV) and then submit the log.
You did use ONLY MakeMKV, didn't you?
I used only makemkv
Sorry I did not provide logs before, they didn't throw any errors during the disc being scanned or ripped the first time through didn't know there was a debug mode.
Here the debug log for the scan
Here is the rip it's self which isn't throwing anything at all.
For good measure the error log from mkvtoolnix I get when I try to remux the mkv from makemkv
Also I have played the disc all the way through on my Blu-ray player and it works perfectly on it.
Just extracted the Audio from the main title on its own and it has chapters 1-5 in it so there is just some issue with the video
The video is also there, I just installed Perian and Flip4Mac to play the VC content and the MKV in Quicktime, and it plays all the way through but all messed up since its 1080i and Flip4Mac can't handle 1080i VC.
Also tried encoding it directly with out remuxing with MEGUI last night using WMP9 as the decoder doesn't make it past the first chapter before it cuts off, and when I rip the video and then put it back into an MKV (which does not seem to trunkcate it for some reason unlike the one step remux) that is when it loops back around to the start
Debug log started at Mon Nov 8 17:36:28 2010 , written by MakeMKV v1.6.2 darwin(x86-release)
001003:0020 DEBUG: Code 6012928 at %a(hQ[u}Mej6J/Dkv"A#(:":213130007
001005:0000 MakeMKV v1.6.2 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/rover/MakeMKV_log.txt
002010:0000 Optical drive "DVD+R-DL HL-DT-ST DVD-RW GH61N PA03" opened in OS access mode.
002010:0000 Optical drive "BD-RE HL-DT-ST BD-RE WH10LS30 1.00" opened in OS access mode.
DISCID=F65DC658832F366EF6450D448EB4321252C3AB50
003307:0000 File 00008.mpls was added as title #0
003307:0000 File 00007.mpls was added as title #1
003307:0000 File 00006.mpls was added as title #2
003307:0000 File 00005.mpls was added as title #3
003307:0000 File 00004.mpls was added as title #4
003307:0000 File 00012.mpls was added as title #5
003307:0000 File 00009.mpls was added as title #6
003307:0000 File 00011.mpls was added as title #7
003307:0000 File 00010.mpls was added as title #8
003307:0000 File 00021.m2ts was added as title #9
003307:0000 File 00019.m2ts was added as title #10
003307:0000 File 00017.m2ts was added as title #11
003307:0000 File 00015.m2ts was added as title #12
003307:0000 File 00013.m2ts was added as title #13
003307:0000 File 00011.m2ts was added as title #14
003307:0000 File 00009.m2ts was added as title #15
003307:0000 File 00007.m2ts was added as title #16
003307:0000 File 00005.m2ts was added as title #17
003025:0000 Title #00003.m2ts has length of 7 seconds which is less than minimum title length of 20 seconds and was therefore skipped
003307:0000 File 00002.m2ts was added as title #18
003025:0000 Title #00001.m2ts has length of 0 seconds which is less than minimum title length of 20 seconds and was therefore skipped
003025:0000 Title #00000.m2ts has length of 0 seconds which is less than minimum title length of 20 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory /Volumes/Macintosh HD/From Green/Blu-Ray
004001:0000 Forced subtitles track #6 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #8 turned out to be empty and was removed from output file
005005:0080 1 titles saved
005036:0104 Copy complete. 1 titles saved.Code: Select all
mkvmerge v4.4.0 ('Die Wiederkehr') built on Oct 31 2010 21:52:48
'I:\From Green\Blu-Ray\title00.mkv': Using the Matroska demultiplexer.
'I:\From Green\Blu-Ray\title00.mkv' track 1: Using the video output module.
'I:\From Green\Blu-Ray\title00.mkv' track 2: Using the DTS output module.
'I:\From Green\Blu-Ray\title00.mkv' track 3: Using the DTS output module.
'I:\From Green\Blu-Ray\title00.mkv' track 4: Using the DTS output module.
'I:\From Green\Blu-Ray\title00.mkv' track 5: Using the DTS output module.
'I:\From Green\Blu-Ray\title00.mkv' track 6: Using the PGS output module.
'I:\From Green\Blu-Ray\title00.mkv' track 8: Using the PGS output module.
The file 'C:\Users\Rover\Desktop\NextDayTest.mkv' has been opened for writing.
Progress: 0%Progress: 1%Progress: 2%Progress: 3%Progress: 4%Progress: 5%Progress: 6%Progress: 7%Progress: 8%Progress: 9%Progress: 10%Progress: 11%Progress: 12%Progress: 13%Progress: 14%Progress: 15%Progress: 16%Progress: 17%Progress: 18%Progress: 19%Progress: 20%Progress: 21%Progress: 22%Progress: 23%Progress: 24%Progress: 25%Progress: 26%Progress: 27%Progress: 28%Progress: 29%Progress: 30%Progress: 31%Progress: 32%Progress: 33%Progress: 34%Progress: 35%Progress: 36%Progress: 37%Progress: 38%Progress: 39%Progress: 40%Progress: 41%Progress: 42%Progress: 43%Progress: 44%Progress: 45%Progress: 46%Progress: 47%Progress: 48%Progress: 49%Progress: 50%Progress: 51%Progress: 52%Progress: 53%Progress: 54%Progress: 55%Progress: 56%Progress: 57%Progress: 58%Progress: 59%Progress: 60%Progress: 61%Progress: 62%Progress: 63%Progress: 64%Progress: 65%Progress: 66%Progress: 67%Progress: 68%Progress: 69%Progress: 70%Progress: 71%Progress: 72%Progress: 73%Progress: 74%Progress: 75%Progress: 76%Progress: 77%Progress: 78%Progress: 79%Progress: 80%Progress: 81%Progress: 82%Progress: 83%Progress: 84%Progress: 85%Progress: 86%Progress: 87%Progress: 88%Progress: 89%Progress: 90%Progress: 91%I:\From Green\Blu-Ray\title00.mkv: Error in the Matroska file structure at position 4295497721. Resyncing to the next level 1 element.
Resyncing successful at position 4295617244.
Progress: 0%Progress: 1%Progress: 2%Progress: 3%Progress: 4%Progress: 5%Progress: 6%Progress: 100%
The cue entries (the index) are being written...
Muxing took 157 seconds.
- Contact:
Please send all CLPI/MPLS files and log to support@makemkv.com per instructions at http://www.makemkv.com/faq/item/8 . Be sure to reference this topic.
It has been made so. Thanks sorry for not doing that before.
Ignore this please its whited out for a reason: Sorry to bump this but this has to be the weirdest silliest thing ever. I disabled direct access mode for an unrelated reason, and then ripped the video out alone. I got all the video.... plays fine in WMP so I should be able to interlace it with MEGUI now and then all I have to do is remux the audio and the video together. Going to try to rip the whole thing from direct access denied mode and see if that works and then going to try just ripping the video in direct access mode. Hope that helps.
Edit 1: Ignore this please its whited out for a reason: Figured it out its the audio not the video or direct access mode thats the problem now going to try testing each audio track. I should have done this approach before. The audio is cutting out early, and thats why the video was having trouble also when I was trying to do anything with them combined.
Edit 2: Its the lossless DTS audio track thats throwing WMP for a loop. The lossless is also not being played by VLC correctly either. I guess I will just have to pass on lossless for this one which is fine all things considered.
