Script for no subtitles, other languages?
oatmeal769
#1 Post by oatmeal769 » Fri May 01, 2020 1:53 pm
I know. "search for the answer." I have, and I'm sure it's here somewhere, but after 45 minutes and these threads among others:
https://www.makemkv.com/forum/viewtopic.php?t=7706
https://www.makemkv.com/forum/viewtopic.php?t=7990
https://www.makemkv.com/forum/viewtopic.php?t=9519
https://www.makemkv.com/forum/viewtopic.php?t=19777
https://www.makemkv.com/forum/viewtopic.php?f=10&t=4386
I can't find what I need, so here's the question.
When the program first analyzes the disk, every file is selected. I have to go through and unselect subtitles and foreign languages.
This is the (default) script I have:
-sel:all,+sel:(favlang|nolang),-sel:mvcvideo,=100:all,-10:favlang
I'd like to know how to un-select all subtitles, and languages other than English. Can someone point me to the thread with that script listed?
Grauhaar
Re: Script for no subtitles, other languages?
#2 Post by Grauhaar » Fri May 01, 2020 2:31 pm
Did you set the "Preferred Language" (this is related to the "Favlang") in the MakeMKV settings? The default is "Nolang", so everything is selected.
Good Luck :)
oatmeal769
#3 Post by oatmeal769 » Fri May 01, 2020 2:58 pm
I thought I had but hadn't. I just did so now.
The new script reads:
"-sel:all,+sel:(favlang|nolang),-sel:mvcvideo,=100:all,-10:favlang"
And all of the non-English boxes are now un-selected, so that's 2/3 of the problem solved. Thank you!
Now, English Subtitles are all that is left. Is there a way to un-select all subtitles regardless of what language?
Grauhaar
#4 Post by Grauhaar » Fri May 01, 2020 3:20 pm
Doc of the selection options: https://www.makemkv.com/forum/viewtopic.php?f=10&t=4386
This selects (I hope) all Audio "Favlang" (ENG in your case) and "NOLANG" (some tracks are wrong specified) tracks. All subtitle tracks remains still deselected with the "-sel:all"
"-sel:all,+sel:audio(favlang|nolang),-sel:mvcvideo,=100:all,-10:favlang"
Good Luck :)
oatmeal769
#5 Post by oatmeal769 » Fri May 01, 2020 4:05 pm
Grauhaar wrote: Fri May 01, 2020 3:20 pm"-sel:all,+sel:audio(favlang|nolang),-sel:mvcvideo,=100:all,-10:favlang"
That causes no audio and no subtitles selected at all.
If you don't feel like working on it, it's totally cool, You've already been super helpful! I can live with having just the English subtitles available. Who knows, I may lose the rest of my hearing someday ;)
Grauhaar
#6 Post by Grauhaar » Fri May 01, 2020 4:22 pm
Next try, the syntax is a little bit tricky :D
-sel:all,+sel:(audio&(favlang|nolang)),-sel:mvcvideo,=100:all,-10:favlang
Good Luck :)
oatmeal769
#7 Post by oatmeal769 » Fri May 01, 2020 5:19 pm
Grauhaar wrote: Fri May 01, 2020 4:22 pmNext try, the syntax is a little bit tricky :D
Yes, especially for me who knows little about how.
That worked! I SO appreciate it!!
I'll try it on a few discs, but it looks like it worked on a DVD I just ripped! Again, THANK YOU!
