Dolby Vision and 1.15.1
Re: Dolby Vision and 1.15.1
Hi guys, can of you who successfully created a working .ts with DV preserved share it please ?
So we can test it against our current hardware/software setup.
Preferably the one generated from the sample ISO, that is one minute long (:
Yes you are right... I just noticed this when I tried to play the main m2ts file from the first Jumanji (though I distinctly remember activating dolby vision with other m2ts files). I "guess" the header information to activate Dolby Vision is not uniformly present in all the m2ts files.
Maybe you had the player's HDR Mode set to "Dolby Vision" rather than "Auto"? In that case it would output Dolby Vision, but obtain it by converting the HDR10 track on the fly rather than actually using the second video layer.
djanvi2020
Ok,
So i have an LG 96 series TV and i have tried everything to rip and keep the DV profile via mkvtoolnix and tsmuxer to play on the LG to no avail, im a Mac user and obviously the other programs to make the DV profiled MKV doesn't exist yet?
is there a better step by step guide atm or since im a Mac user i have to wait a little longer??
mmm, I just gave you a link hours ago... This work with the x700 (dual-layer DV + Atmos + Subs) and another user at the doom9 forum is reporting that it works on the oppo as well.
https://www.makemkv.com/forum/viewtopic ... 240#p88873
oldirtydog
please ,i have a problem on step 1. I have downloaded a complete UHD movies with m2ts file in BDMV folder,but how i can rip this file to MKV with Makemkv.....with eac3togui i choise the truehd+ac3 sound i have tsmuxer to create the final steps but number 1 is imposible for me.... i dont have a original blu ray ISO UHD disc.....
DaMacFunkin
Hi, as I have said before use the playlist file incase it is multiple m2ts files.darrrkmanxxx wrote: ↑Thu Apr 30, 2020 8:11 amGuys, can't we just take the .m2ts file from STREAM folder and do all with tsmusxer? If so, which version I should use?
DaMacFunkin
Mkv toolnix doesn’t work.djanvi2020 wrote: ↑Thu Apr 30, 2020 10:39 pmOk,
As you do t need HD audio on the LG just get DVDfab for MAC?
Sgt Hartman
Guys,
Probably a silly question, but why to add the eac3to step in the procedure? Once obtained the mkv file isn't easier to put it in tsMuxer together with the original m2ts and selecting only the audio track needed?
I'm getting Dolby Vision & Atmos without issues in this way...
So you'd prefer to rip your disc twice? once to a folder to get the m2ts, and the other to make an mkv? if you write a quick script that extracts thd and adds ac3 to it then your only steps are run makemkv, click your .bat file, run tsmuxer.Sgt Hartman wrote: ↑Fri May 01, 2020 12:52 pmGuys,
Sgt Hartman
I mean, this is the current suggested procedure:Grencola wrote: ↑Fri May 01, 2020 1:24 pmSo you'd prefer to rip your disc twice? once to a folder to get the m2ts, and the other to make an mkv? if you write a quick script that extracts thd and adds ac3 to it then your only steps are run makemkv, click your .bat file, run tsmuxer.Sgt Hartman wrote: ↑Fri May 01, 2020 12:52 pmGuys,
1) Rip to MKV with MakeMKV
4) Remux to TS
From my side I get my mkv in point 1, then I go straight forward to point 3 adding in tsMuxer the .mkv file and original m2ts (or the mpls if multiple files), I pick only the audio trace that I want removing the rest and I get my .ts file which will have both DV and DA.
For you, who already have a decrypted folder back up, sure you can skip step 2. But if you’re someone who’s starting from scratch with the original physical disc, to do what you’re talking about, you’d have to rip it once to a decrypted folder back up and then rip it again to an mkv. The above steps allow you to go straight from the disc to an mkv without needing to do the full folder rip.Sgt Hartman wrote: ↑Fri May 01, 2020 1:51 pmI mean, this is the current suggested procedure:Grencola wrote: ↑Fri May 01, 2020 1:24 pmSo you'd prefer to rip your disc twice? once to a folder to get the m2ts, and the other to make an mkv? if you write a quick script that extracts thd and adds ac3 to it then your only steps are run makemkv, click your .bat file, run tsmuxer.Sgt Hartman wrote: ↑Fri May 01, 2020 12:52 pmGuys,
4) Remux to TS
Sgt Hartman
OK, I see it now, sorry I gave as implied that the disk was already backed up and decrypted, thanks.shawnc22 wrote: ↑Fri May 01, 2020 1:58 pmFor you, who already have a decrypted folder back up, sure you can skip step 2. But if you’re someone who’s starting from scratch with the original physical disc, to do what you’re talking about, you’d have to rip it once to a decrypted folder back up and then rip it again to an mkv. The above steps allow you to go straight from the disc to an mkv without needing to do the full folder rip.Sgt Hartman wrote: ↑Fri May 01, 2020 1:51 pmI mean, this is the current suggested procedure:
4) Remux to TS
Even using your preferred version of TsMuxer, if I feed it the playlist file and mux to a TS then my Oppo 203 can't play the resulting file. It recognises it as Dolby Vision, triggers the TV to switch modes, and displays the first frame correctly, but then the video just freezes.RESET_9999 wrote: ↑Fri May 01, 2020 12:28 amThis work with the x700 (dual-layer DV + Atmos + Subs) and another user at the doom9 forum is reporting that it works on the oppo as well.
