SOLVED - Streaming: files mapped to incorrect files??
knobbi
#1 Post by knobbi » Mon Nov 08, 2010 2:37 am
I'm a makemkv (registered) newbie - here's my problem:
I'm trying to stream "Rattatouille" like this: (Mythbuntu 10.04)
makemkvcon stream disc:0 --cache=128 --minlength=4800
So it scans through the many files on the disc, selecting four of them that are > 4800 seconds (80 minutes):
MakeMKV v1.6.2 linux(x86-release) started
Title #00082.m2ts has length of 312 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00080.m2ts has length of 357 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00144.m2ts has length of 358 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00149.m2ts has length of 765 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00044.mpls has length of 834 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00046.mpls has length of 676 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00049.mpls has length of 357 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00051.mpls has length of 312 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00061.mpls has length of 54 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00062.mpls has length of 18 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00063.mpls has length of 22 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00064.mpls has length of 18 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00065.mpls has length of 120 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00066.mpls has length of 113 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00067.mpls has length of 120 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00068.mpls has length of 120 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00122.mpls has length of 358 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00127.mpls has length of 765 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00005.mpls has length of 54 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00006.mpls has length of 54 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00060.mpls has length of 56 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00047.mpls has length of 301 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00157.mpls has length of 301 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00158.mpls has length of 301 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
File 00001.mpls (angle 1) was added as title #0
File 00001.mpls (angle 2) was added as title #1
File 00143.mpls (angle 1) was added as title #2
File 00143.mpls (angle 2) was added as title #3
Title #00066.m2ts has length of 74 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00067.m2ts has length of 111 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00068.m2ts has length of 7 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00069.m2ts has length of 101 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00070.m2ts has length of 7 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00072.m2ts has length of 153 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00075.m2ts has length of 834 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00076.m2ts has length of 109 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00077.m2ts has length of 676 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00079.m2ts has length of 10 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00081.m2ts has length of 236 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00083.m2ts has length of 206 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00084.m2ts has length of 68 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00085.m2ts has length of 57 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00086.m2ts has length of 64 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00087.m2ts has length of 35 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00088.m2ts has length of 20 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00089.m2ts has length of 4 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00090.m2ts has length of 54 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00091.m2ts has length of 18 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00092.m2ts has length of 22 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00093.m2ts has length of 18 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00094.m2ts has length of 60 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00095.m2ts has length of 56 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00096.m2ts has length of 60 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00097.m2ts has length of 60 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00098.m2ts has length of 31 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00099.m2ts has length of 6 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00100.m2ts has length of 7 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00101.m2ts has length of 11 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00103.m2ts has length of 0 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00108.m2ts has length of 45 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00130.m2ts has length of 54 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00131.m2ts has length of 67 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00132.m2ts has length of 100 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00133.m2ts has length of 62 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00134.m2ts has length of 47 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00135.m2ts has length of 41 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00136.m2ts has length of 67 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00137.m2ts has length of 42 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00138.m2ts has length of 67 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00139.m2ts has length of 66 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00140.m2ts has length of 57 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00141.m2ts has length of 41 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00142.m2ts has length of 112 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00143.m2ts has length of 214 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00145.m2ts has length of 305 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00146.m2ts has length of 275 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00147.m2ts has length of 281 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00148.m2ts has length of 276 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00150.m2ts has length of 210 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00151.m2ts has length of 172 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00152.m2ts has length of 26 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00153.m2ts has length of 36 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00154.m2ts has length of 33 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00155.m2ts has length of 35 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00156.m2ts has length of 39 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00157.m2ts has length of 54 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00158.m2ts has length of 180 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00159.m2ts has length of 34 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00160.m2ts has length of 21 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00161.m2ts has length of 51 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00162.m2ts has length of 31 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00163.m2ts has length of 61 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00164.m2ts has length of 61 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00165.m2ts has length of 26 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00166.m2ts has length of 254 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00173.m2ts has length of 1 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00175.m2ts has length of 24 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00176.m2ts has length of 26 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00177.m2ts has length of 26 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00178.m2ts has length of 20 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00183.m2ts has length of 20 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00186.m2ts has length of 300 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00188.m2ts has length of 300 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00203.m2ts has length of 0 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00210.m2ts has length of 11 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00211.m2ts has length of 11 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00234.m2ts has length of 61 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00239.m2ts has length of 54 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00240.m2ts has length of 54 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Streaming server started, web server address is http://192.168.1.20:51001 or http://localhost:51000
UPnP server enabled on address 192.168.1.20
This seems fine so far (although no m2ts file is selected). But then when I goto watch one of the titles in VLC:
vlc  http://mediabox:51000/stream/title0.ts
the streamed file is some other short-content of the disc (a making-of clip), about 10 minutes long.
I downloaded the "title0.ts" file, it was about 10MiB - not the near 30GiB I expected. I then tried the other titles, they were all the same sort of short clips - all "extra content" not the movie.
Can someone please help me out here.
thanks,
Mr Knob.
Re: Streaming: files mapped to incorrect files??
#2 Post by mike admin » Tue Nov 09, 2010 8:18 am
Can you see required title information in browser if you navigate to http://mediabox:51000/ ?
knobbi
#3 Post by knobbi » Wed Nov 10, 2010 11:21 pm
It's weird, but it's working fine now!
name	value
id	0
duration	1:50:33
chaptercount	30
formatcount	2
format0	m2ts
file0	/stream/title0.m2ts
format1	ts
file1	/stream/title0.ts
I swear, the other day I got what I described. I don't remember reading this before - although being a noob, I was really just playing around. Maybe I broke something.
*shrug*
Thanks, and keep up the good work.
- Mr Knob.
