Double install
zeeke
Double install
Post by zeeke » Sun Nov 07, 2010 7:45 pm
Hi
I'm just wondering, is it ok to install MakeMKV on both my HTPC and my WHS or do I need two license keys?
skittle
Re: Double install
Post by skittle » Sun Nov 07, 2010 8:04 pm
Mike Admin has said its fine (yes you can use the same key), as long as you dont run both at the same time.
zeeke
Re: Double install
Post by zeeke » Mon Nov 08, 2010 6:15 am
Sound reasonable. Thanks
