Create a Backup BDMV file from an ISO?
vila2k
Post by vila2k »
I have a blu ray player that will play 3D files 'backed up' as BDMV files but not as MKV's
I have an ISO of a 3D blu ray I'd like to watch but when I open the ISO with make MKV The 'backup disc option' is greyed out and i can only make it into an MKV
Is it possible to create a backup from an ISO?
Re: Create a Backup BDMV file from an ISO?
Post by d00zah »
If the .iso is no longer protected, you can probably extract the folder using WinRAR/WinZip. If that fails, you could try mounting the .iso using a free virtual drive like Daemon Tools Lite or Redfox Virtual CloneDrive. Then you can process it like any other disc.
vila2k
Post by vila2k »
Daemon tools let makemkv see it as an optical drive and make a backup - thank you!
