NoTitles saved when converting XFiles S1.D1
nzdreamer55
#1 Post by nzdreamer55 » Sun Nov 07, 2010 5:57 am
Here is the log file
Debug log started at Sun Nov 07 05:42:33 2010 , written by MakeMKV v1.6.2 win(x64-release)
001005:0000 MakeMKV v1.6.2 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Admin/MakeMKV_log.txt
003002:0000 Calculated BUP offset does not match one in IFO header.
003028:0000 Title #0 was added (23 cell(s), 0:47:56)
003028:0000 Title #1 was added (20 cell(s), 0:45:35)
003028:0000 Title #2 was added (19 cell(s), 0:42:36)
003028:0000 Title #3 was added (19 cell(s), 0:44:04)
003025:0000 Title #4/1 has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #4/2 has length of 71 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #4/3 has length of 63 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #4/4 has length of 52 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #5 has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:0000 Saving 4 titles into directory F:/Video/XFS1
001003:0020 DEBUG: Code 2152 at IRA_H;]'tP~\ViBpg-3:121262716
vobs=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
001003:0020 DEBUG: Code 0 at 4[XX/VGo,o,itCCBLt{E:29394183
001003:0020 DEBUG: Code 5356 at 4[XX/VGo,o,itCCBLt{E:29393309
005003:0000 Failed to save title 0 to file F:/Video/XFS1/title00.mkv
001003:0020 DEBUG: Code 51369 at IRA_H;]'tP~\ViBpg-3:121262716
vobs=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
001003:0020 DEBUG: Code 68091 at 4[XX/VGo,o,itCCBLt{E:29393309
005003:0000 Failed to save title 1 to file F:/Video/XFS1/title01.mkv
001003:0020 DEBUG: Code 2120 at IRA_H;]'tP~\ViBpg-3:121262716
vobs=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
001003:0020 DEBUG: Code 26367 at 4[XX/VGo,o,itCCBLt{E:29393309
005003:0000 Failed to save title 2 to file F:/Video/XFS1/title02.mkv
001003:0020 DEBUG: Code 2080 at IRA_H;]'tP~\ViBpg-3:121262716
vobs=ZeNp9VE1oE0EUfrOpm1SrRAsRmjaEBkohq0R7iBcxVo8W1+KhLR4KShu0miL+9GbUiiWnUKSKeOhJBS8F76WIoKKV4KkIwWCltWCkB0GFNDEz773Nzhp9JDxm5pvvfe9ndhGk3TRrZPA9Bs1Mnbnso+EBmGlL1J3dNqEIRsnD+D7lWr2EfeWkxGcHHlpymSefkpsw6C8nAUqmvJdR+30gdxpBZRwD1sRST96SKI6XOntJ+f7QcFX6Gz78cxw2jucjyuxIl6PTFg29wpPvK9G8HjUf8cB4zJ1vORn4oHTdzal4dRrDT/eFC88WD0NC+s09qIe9l9exwQnLjUsYOj6787Y6DzA+hG5IIA4uV66575ccYlwXQMcP+XRd0qr+Rn26IQLXfzw7A5BWcQuZmKaL68F5GNRUrt+5XXBe+q8dm0oXTExj3zoylqZL6GW4196l5cdzwHjuc/7FfcVjM3479ZnrYeEcLWv8Zl2/JFgTBaevFKf4RPFVgnu3ZB3YZDpjdY6VNPIyH99/PxBOYf/1uYl+uxBz13cyBGMqv8ed+DQOPLBQkfwBLG3cwjnux3pxPTlPp0+Eex0nXsqf8cY88nvnKNCL/nS73vdt9WtVf0FwXrzP/TVB3/fRu+J6efHZ+tyovsTz6nzKiPB7VKOyJmDdrZfxbIyPmhGN18mPfJTw7Gdo/tkSnrn04p9SXcxGitp5EGIwtz6ye7IlAn/PEUAL+Udz3are4vM09v3YnWgzPYwP13S8TfjEKq6Zb+kLrn9WcL1BM8n7PC/MV2jDdzJPvPxeTp4oKx023St+Qvwhipel/eBx1PHGwk93MHdR7b+bjeE8kU6H32jdocZxFfminu8sW6kV6zd68Kq6lziFerjvC0I/Z93Mc3QG9dBnBdKdep+88Vi33Yvz9+v54f/q+xee+/UyOFyV34MC1Zvv85rr59ULnngr+3u0/anFI2q99Rvrl6X+MWY+d8VyzwPrfFvE9cLyrOWu4x9Jkf3d
001003:0020 DEBUG: Code 102114 at 4[XX/VGo,o,itCCBLt{E:29393309
005003:0000 Failed to save title 3 to file F:/Video/XFS1/title03.mkv
005004:0080 0 titles saved, 4 failed
005037:0204 Copy complete. 0 titles saved, 4 failed.
Application exited at Sun Nov 07 05:50:41 2010
Please let me know what I can do to help out.
Steve
nzdreamer55
Re: NoTitles saved when converting XFiles S1.D1
#2 Post by nzdreamer55 » Sun Nov 07, 2010 4:28 pm
Not sure if this will help, but I copied the dist to my HD using DVDFab8 and I jsut copied the main sections. I then ran it through MakeMVK and got 4 perfect MKV files. Originally I was using DVDfab passkey to decryp the disc on the fly when I first tried to make mkv files, but the second time it was decrypted after copying it to my HD.
Steve
setarip_old
#3 Post by setarip_old » Mon Nov 08, 2010 12:17 am
Hi!
Have you (as you should tried using ONLY Make MKV DIRECTLY to make an MKV of your original, commercial disc?
What is the source material from which you generated the Debug file (Commerial disc, .ISO, something else)?
nzdreamer55
#4 Post by nzdreamer55 » Mon Nov 08, 2010 5:09 am
So the first time I used just MakeMkv the second post where it worked I used DVDFab to copy it to my hard drive then run that through makemkv. I have the commercial DVD disc.
The first time I am using dvdfab passkey to remove the DVD protections. Should I just use MakeMkv with out dvdfab passkey? Will MakeMkv remove the dvd protections from DVDs?
Steve
setarip_old
#5 Post by setarip_old » Mon Nov 08, 2010 3:30 pm
Yes...
Yes...
nzdreamer55
#6 Post by nzdreamer55 » Mon Nov 08, 2010 3:42 pm
That is AWESOME! I cannot wait to give it a try. I'll give it a try and let you know if it works.
Steve
nzdreamer55
#7 Post by nzdreamer55 » Wed Nov 10, 2010 3:48 pm
That totally worked. Thanks for making this great little program and the help.
Steve
setarip_old
#8 Post by setarip_old » Wed Nov 10, 2010 5:14 pm
Glad to hear that my suggestion worked for you ;>}
