Code for interface with other encoders (e.g. Handbrake)
ender111
#1 Post by ender111 » Thu Jul 19, 2018 3:14 am
cd ~
mkdir -p ~/lib
ln -s /Applications/MakeMKV.app/Contents/lib/libmmbd.dylib ~/lib/libaacs.dylib
ln -s /Applications/MakeMKV.app/Contents/lib/libmmbd.dylib ~/lib/libbdplus.dylib
I found the above code on this forum, but it works only for Mac. Is there a script that will work for PCs? I'm trying to allow Handbrake to operate seamlessly with Handbrake to rip blu rays. Any help would be appreciated.
T'hain Esh Kelch
Re: Code for interface with other encoders (e.g. Handbrake)
#2 Post by T'hain Esh Kelch » Mon Jul 30, 2018 8:44 am
You can just create the folder manually, and copy the files manually.
The 'code' is just terminal commands to create a folder called "lib" in your userfolder and copy those two .dylib files to it.
MetalDave
#3 Post by MetalDave » Thu Apr 30, 2020 5:41 am
We documented a procedure for Windows in another thread which might help.
Important Note: You need to copy the 64-bit version of the dll file if you're running a 64-bit OS.
Support MakeMKV - Buy a license!
(Seriously, you use this thing enough; A lifetime license is well worth it.)
Thank you to all of my fellow supporters!
