DVD discs are detected, cannot backup or save
decibels
Post by decibels » Wed Apr 29, 2020 8:07 pm
I finished backing up all my Blu-ray discs with ease and now starting my DVD music/concert discs and MKV will detect the disc as the info shows up on the right. I tried an ABBA disc as well as two Bocelli disks with the same result.
The backup and save titles icons are not selectable at all, only open files is available.
Is there something that I am missing to be able to backup these discs?
Thank you for any guidance and assistance!!
Re: DVD discs are detected, cannot backup or save
Post by Woodstock » Wed Apr 29, 2020 8:41 pm
"Backup" will never work for DVDs.
Does the operating system show "no disk" when you insert the DVD?
decibels
Post by decibels » Wed Apr 29, 2020 9:10 pm
Okay good to know that backup is not possible.
This is what is shown as an example
OS device name: /dev/rdisk3
Current profile: DVD-ROM
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E111
Serial number: REDL012382WL
Firmware date: 2017-12-21
Highest AACS version: 71
Status: Might be supported in future, keep fingers crossed
Drive platform: Pioneer RS8601
Firmware version: ID76
Disc Information
Label: Andrea Bocelli
Timestamp: 2008-01-15 11:15:59
Data capacity: 7.72 Gb
Disc type: DVD-ROM
Disc size: 120mm
Maximum read rate: 10.08 Mbps [1x]
Number of layers: 2 (OTP)
Post by Woodstock » Wed Apr 29, 2020 9:12 pm
OK, so the disk is detected. When you click on the Open button, does it try reading it? Can you post what is in the debug log from opening it?
(debug logging is explained in the FAQ link in my signature)
decibels
Post by decibels » Wed Apr 29, 2020 9:21 pm
Okay it did open the disc now with the below
Calculated BUP offset for VTS #1 does not match one in IFO header.
Calculated BUP offset for VTS #2 does not match one in IFO header.
Calculated BUP offset for VTS #3 does not match one in IFO header.
Title #1 was added (1 cell(s), 0:05:01)
Title #2 was added (18 cell(s), 1:37:58)
Title #3 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #4 was added (1 cell(s), 0:15:41)
Post by Woodstock » Wed Apr 29, 2020 10:07 pm
OK, now you can select which titles you want to make into MKV files, and hit start. There is more you can do (change title names and file names, etc.), but let's start with the basics and make sure it can convert the three files that were more than 2 minutes long.
decibels
Post by decibels » Wed Apr 29, 2020 10:12 pm
Thank you for your help thus far!
I started the process and it is creating/saving the MKV files to an external drive. Will update once completed.
If I understand correctly, these MKV files will play back directly on my Oppo 103 from the hard drive?
decibels
Post by decibels » Thu Apr 30, 2020 12:49 am
Okay, all files were saved successfully and I will test them later tonight on the Oppo.
Thank you
