The Gentlemen blu ray uk
charlie62
Post by charlie62 »
I need a key for this region B disc I have already sent a tgz to Mike. I only posted because this is the first time I have ever had to get a key for a Blu-ray.
rivalskys
Re: The Gentlemen blu ray uk
Post by rivalskys »
Hi
I also have this issue, I'm not sure if there is anything I can submit that would help, I'm new to this.
Is there any fix for this or is it just a case of waiting until the next version of the programme is released.
Many thanks in advance!
charlie62
Post by charlie62 »
Send a dump file to support@makemkv it should be in c drive users makemkv then e mail to support,I'm not the best at explaining but like yourself I'm not the best with computers
rivalskys
Post by rivalskys »
Thanks, I've sent the dump file.
Did you find a way of watching the Blu Ray on your PC?
Many thanks
charlie62
Post by charlie62 »
Sorry I never tried
readingandy
Post by readingandy »
They've excelled themselves here....
The Bluray gives me
This disc uses newer version of AACS protection. Please let us know about it by visiting …..
Saved AACS dump file as C:\Users\Andrew/.MakeMKV/MKB_v76_THE_GENTLEMEN_D106.tgz
and the UHD won't rip either, similar AACS message (see separate thread in the UHD disks section!)
sgtblackice
Post by sgtblackice »
Just submitted my dumps to support also, they normally turn the update around within a day or so.
charlie62
Post by charlie62 »
It's working now thanks Mike
readingandy
Yes, confirmed working now (and the 4k too).
thank you!
rivalskys
Post by rivalskys »
Thanks Mike, this now works!
KillingTime
Post by KillingTime »
Hi, it's not working for me. Using v1.15.1, downloaded today 03 June 2020.
How did you get this to work? Thanks.
KillingTime
Anyone?
I mailed support@makemkv.com with the tgz file 3 days ago but have not heard back.
As this title is already known to makemkv, 'key not found' presumably means they're releasing the same title with different keys.
Thanks.
Post by d00zah »
KillingTime wrote: Sat Jun 06, 2020 12:23 pm I mailed support@makemkv.com with the tgz file 3 days ago but have not heard back.
Thanks.
Dumps should be sent to svq@makemkv.com , but Mike should have still gotten yours(?). You won't get personalized response... the disc will just decrypt once the db is updated/downloaded.
& a release can have many keys depending on region, rental/retail, etc..
Historically, a new release of MakeMKV was required when a new AACS version appeared.
LibreDrive can change that IF:
- MakeMKV reports LibreDrive as 'Enabled'.
MakeMKV (Small).jpg (32.6 KiB) Viewed 25215 times
- 'Allow contacting web server for updates' is checked on the 'General' prefs tab.
- You're are not experiencing any DNS/firewall issues. (An error msg should show if you are unable to download a necessary update).
viewtopic.php?f=1&t=17848
If you meet all those criteria for LibreDrive, be patient & keep trying disc.
KillingTime
Hello d00zah,
Thank you for the reply and explanation. It's working now.
I'd forgotten that MakeMKV can download from the internet for the latest updates. Network connection added. Problem solved.
In the past, I've always downloaded the latest binary and that's worked for problem titles.
Best Regards.
