Dolby Vision and 1.15.1
Thornback
Re: Dolby Vision and 1.15.1
#211 Post by Thornback » Mon Apr 27, 2020 11:50 am
Ok, thanks.
As for playback devices currently supported, would I have any luck with madVR on Windows 10? Works a charm with HDR10 as an external player on Kodi.
#212 Post by SamuriHL » Mon Apr 27, 2020 11:54 am
There is no Dolby vision playback on a pc. So no madvr won't help you.
Thornback
#213 Post by Thornback » Mon Apr 27, 2020 12:00 pm
Right, so that's another hurdle that needs to be overcome. Oh well.
#214 Post by SamuriHL » Mon Apr 27, 2020 12:55 pm
I wouldn't count on that happening soon. A lot of things have to come together to make it work and no one's working on them. Madvr supporting Dolby vision is almost 0 chance right now. Plus you need a splitter that can read the metadata and pass it to a decoder that we don't have. Dolby vision requires license fees to get official support which isn't happening on a pc. The only way it happens is for people to develop it unofficially and as I said, they aren't working on it.
Maxoumax6
#215 Post by Maxoumax6 » Mon Apr 27, 2020 5:28 pm
I tried this brand new MakeMKV version, but it does not trigger DV on my LG C8.
If I'm right, this new worflow only works if you use Plex on the Shield, right?
All my files are DV profile 04.06.
monkeymindboy
#216 Post by monkeymindboy » Mon Apr 27, 2020 6:28 pm
@Maxoumax6
See page two of this thread.
New possible method:
1) Create MKV backup using v1.15.1 of MakeMKV.
2) Extract and convert atmos track from MKV to thd+ac3 format using eac3to.
3) Add MKV and the extracted thd+ac3 atmos audio track to tsmuxer and mux.
Windows 10 Pro
LG WH16NS40 - UHD Friendly
Asus BW-16D1HT - UHD Friendly
LG WH16NS40 - External Drive - Blu-Ray
HD/DVD - XBOX360 - External Drive
Shasarak
#217 Post by Shasarak » Tue Apr 28, 2020 8:57 am
So, for someone like myself who refuses to buy a 2019 Shield and is violently allergic to Plex, can files created in the way that is described in this thread (makemkv, eac3to, TsMuxer) be played any other way? For example, could my Oppo 203 play them correctly? ATV4K?
DaMacFunkin
#218 Post by DaMacFunkin » Tue Apr 28, 2020 2:11 pm
Just use TS muxer to create a TS or M2TS from your decrypted back up for use on Oppo 203.
AlvaroB
#219 Post by AlvaroB » Wed Apr 29, 2020 12:00 pm
I made a backup of 1917 (HDR10+ and DV) to a MKV. The mediainfo says:
Video
ID in the original source m : 4113 (0x1011)
Format                      : HEVC
Format/Info                 : High Efficiency Video Coding
Format profile              : Main 10@L5.1@High
HDR format                  : SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
Codec ID                    : V_MPEGH/ISO/HEVC
Duration                    : 1 h 58 min
Bit rate                    : 76.4 Mb/s
Width                       : 3 840 pixels
Height                      : 2 160 pixels
Display aspect ratio        : 16:9
Frame rate mode             : Constant
Frame rate                  : 23.976 (24000/1001) FPS
Color space                 : YUV
Chroma subsampling          : 4:2:0 (Type 2)
Bit depth                   : 10 bits
Bits/(Pixel*Frame)          : 0.384
Stream size                 : 63.5 GiB (93%)
Language                    : English
Default                     : No
Forced                      : No
Color range                 : Limited
Color primaries             : BT.2020
Transfer characteristics    : PQ
Matrix coefficients         : BT.2020 non-constant
Mastering display color pri : Display P3
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 1000 cd/m2
Maximum Frame-Average Light : 168 cd/m2
Original source medium      : Blu-ray
I don't see any mention to DV layers, is this ok? I edited the track names with MKVToolnix and I don't know if this affected the track.
mulucy
#220 Post by mulucy » Wed Apr 29, 2020 12:11 pm
@Maxoumax6
Does using MakeMKV retain the DV data in profile 7? What's the advantage of using MakeMKV anyway?
yusesope
#221 Post by yusesope » Wed Apr 29, 2020 12:32 pm
mike admin wrote:
Wed Apr 15, 2020 5:41 pm
While not announced on release notes page, MakeMKV 1.15.1 (released 15.4.20) should correctly recognize and preserve Dolby Vision streams in MKV file. Given the original thread is 143 pages at the time of this writing, I'm creating a separate thread. Please report any DV issues here.
Hi guys.
I tested the latest version of makemkv only once with the sample ISO posted by @RESET_9999 (HERE).
So forgive any oversights.
I have two questions for mike:
  • AUD NALus are absent in the enhancement layer. Shouldn't they be mandatory in UHD-BD and therefore in a 1:1 copy?
  • All NALus in the enhancement layer have a value of nuh_layer_id other than 0. Is it a desired choice? and if so, why?
Cruzader1986
#222 Post by Cruzader1986 » Wed Apr 29, 2020 2:57 pm
Video
Format                      : HEVC
Color space                 : YUV
Bit depth                   : 10 bits
Language                    : English
Default                     : No
Forced                      : No
mediainfo can't detect dolby vision on mkv yet. if you use tsmuxer on that mkv, the resulting .ts will be marked as dolby vision
AlvaroB
#223 Post by AlvaroB » Wed Apr 29, 2020 8:17 pm
Good to know, thank you! I'm not gonna mux it to .ts yet, as my TV doesn't play DV. I just wanted to future proof it so I don't have to rip it again in a few years when I want Dolby Vision.
rosavanwinkle
#224 Post by rosavanwinkle » Wed Apr 29, 2020 11:20 pm
So i just converted a movie using makemkv and then tsmuxer
tried playing it in mxplayer pro i get hdr....
Plex gives me dolby vision. do i have to change some settings?
I seriously am starting to trip out on where i'm wrong.
Discord: Rosa Van Winkle#2593 if anyone wants to guide me through this.
General
Complete name                            : \\SHIELD\internal\Movies\Yip Man 4.ts
File size                                : 46.5 GiB
Duration                                 : 1 h 45 min
Overall bit rate                         : 63.3 Mb/s
Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.04.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Bit rate                                 : 59.5 Mb/s
Frame rate                               : 24.000 FPS
Bits/(Pixel*Frame)                       : 0.299
Stream size                              : 43.7 GiB (94%)
Mastering display color primaries        : BT.2020
Maximum Content Light Level              : 630 cd/m2
Maximum Frame-Average Light Level        : 460 cd/m2
Audio
Format                                   : AC-3 MLP FBA 16-ch
Format/Info                              : Audio Coding 3 + Meridian Lossless Packing FBA with 16-channel presentation
Muxing mode                              : Stream extension
Codec ID                                 : 131
Maximum bit rate                         : 7 896 kb/s
Stream size                              : 482 MiB (1%)
Language                                 : Chinese
Mediaplayer: Nvidia Shield TV Pro
TV: LG 55SK7900PLA
Soundbar: LG SK8 (not LG SK8Y)
plex pass user
Discord:Rosa#1111
#225 Post by shawnc22 » Wed Apr 29, 2020 11:42 pm
General
Video
Audio
Codec ID                                 : 131
Language                                 : Chinese
Like I said in the other thread, the issue is with your set up. The files you're creating are clearly fine, especially if they're playing in DV with Plex, so I would suggest stop tinkering with the remux process and focus more on the set up. Have you tried any of the suggestions I had mentioned? Another thing you may want to try is just playing the mkv directly from the result of makemkv and see if atmos audio is working from that. If that doesn't work, then there's obviously something that's preventing atmos from being played. What does the rest of your system look like (brand/model of audio receiver, how everything is hooked up, etc)?
