There are 3 single layer DV profile 05.06 web-dl releases circulating on the web.tr000 wrote: ↑Sun Apr 26, 2020 3:37 amThis is very old but where did you find a DV Web-DL? I've never seen that, only DV from Blu-ray rips.RESET_9999 wrote: ↑Sat Oct 05, 2019 4:51 pmreal web-dl single layer DV of Stranger Things season 3 play nicely.
Stranger things S03
Mandalorian S01
Star Wars New Hope (which I successfully added a trueHD Atmos track)
the last two can be found on one of the most known public torrent websites. ST can be found on a Russian tracker.
Complete name : G:\4k\Star.Wars.Episode.IV-A.New.Hope.1977.DV.ts
Format : MPEG-TS
File size : 21.4 GiB
Duration : 2 h 4 min
Overall bit rate mode : Variable
Overall bit rate : 24.6 Mb/s
Maximum Overall bit rate : 35.5 Mb/s
Video
Menu ID : 1 (0x1)
Format : HEVC
Format profile : Main 10@L5@High
HDR format : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU
Codec ID : 36
Bit rate : 20.9 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.105
Stream size : 18.2 GiB (85%)
Color range : Full
Audio #1
Menu ID : 1 (0x1)
Format : AC-3 MLP FBA 16-ch
Format/Info : Audio Coding 3 + Meridian Lossless Packing FBA with 16-channel presentation
Commercial name : Dolby TrueHD with Dolby Atmos
Muxing mode : Stream extension
Codec ID : 131
Bit rate mode : Variable
Bit rate : 640 kb/s
Maximum bit rate : 3 705 kb/s
Channel(s) : 8 channels
Channel layout : L R C LFE Ls Rs Lb Rb
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 571 MiB (3%)
Language : English
Service kind : Complete Main
Number of dynamic objects : 13
Bed channel count : 1 channel
Bed channel configuration : LFE
Text #1
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Language : English
Text #2
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Delay relative to video : 41 ms
Language : English
