tr000
Post by tr000 » Sun Apr 26, 2020 9:32 am
tr000 wrote:
Sat Apr 25, 2020 8:05 am
Success. At last.
Someone PMed me asking for MediaInfo of the file that worked. I decided I might as well give some comprehensive documentation, so:
Here are the test files that worked:
Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Duration                                 : 59 s 976 ms
Bit rate                                 : 21.3 Mb/s
Bits/(Pixel*Frame)                       : 0.107
Stream size                              : 152 MiB (95%)
Maximum Content Light Level              : 2013 cd/m2
Maximum Frame-Average Light Level        : 393 cd/m2
Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.04.0A, EL+RPU, SDR compatible / SMPTE ST 2086, HDR10 compatible
Codec ID                                 : hev1
Codec ID/Info                            : High Efficiency Video Coding
Duration                                 : 59 s 977 ms
Bit rate                                 : 21.9 Mb/s
Bits/(Pixel*Frame)                       : 0.110
Stream size                              : 157 MiB (100%)
Encoded date                             : UTC 2020-04-24 14:23:37
Tagged date                              : UTC 2020-04-24 14:23:37
Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU / SMPTE ST 2086, HDR10 compatible
Encoded date                             : UTC 2020-04-24 14:23:57
Tagged date                              : UTC 2020-04-24 14:23:57
Video
Codec ID                                 : hev1
Encoded date                             : UTC 2020-04-24 14:12:43
Tagged date                              : UTC 2020-04-24 14:12:43
Video
Encoded date                             : UTC 2020-04-24 13:53:07
Tagged date                              : UTC 2020-04-24 13:53:07
Here are the test files that didn't work:
Video
Codec ID                                 : 6
Video #1
HDR format                               : SMPTE ST 2086, HDR10 compatible
Video #2
HDR format                               : Dolby Vision, Version 1.0, dvhe.07.06, EL+RPU, 8 compatible / SMPTE ST 2086, HDR10 compatible
Codec ID                                 : 6
Duration                                 : 59 s 934 ms
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Video #1
Video #2
HDR format                               : Dolby Vision, Version 1.0, dvhe.07.05, EL+RPU, 8 compatible / SMPTE ST 2086, HDR10 compatible
Video #1
Codec ID                                 : hev1
Duration                                 : 1 min 0 s
Bit rate                                 : 22.1 Mb/s
Bits/(Pixel*Frame)                       : 0.111
Stream size                              : 159 MiB (99%)
Encoded date                             : UTC 2020-04-24 14:21:16
Tagged date                              : UTC 2020-04-24 14:21:16
Codec configuration box                  : hvcC
Video #2
HDR format                               : Dolby Vision, Version 1.0, dvhe.04.06, EL+RPU, SDR compatible / SMPTE ST 2086, HDR10 compatible
Codec ID                                 : hev1
Bit rate                                 : 121 kb/s
Bits/(Pixel*Frame)                       : 0.002
Stream size                              : 888 KiB (1%)
Video #1
Encoded date                             : UTC 2020-04-24 14:21:09
Tagged date                              : UTC 2020-04-24 14:21:09
Video #2
HDR format                               : Dolby Vision, Version 1.0, dvhe.05.03, BL+RPU / SMPTE ST 2086, HDR10 compatible
Bit rate                                 : 121 kb/s
And here is the final movie that works great.
Format profile                           : Base Media / Version 2
Codec ID                                 : mp42 (mp42/dby1/isom)
File size                                : 39.6 GiB
Duration                                 : 1 h 59 min
Overall bit rate                         : 47.6 Mb/s
Encoded date                             : UTC 2020-04-24 19:00:45
Tagged date                              : UTC 2020-04-24 19:00:45
Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.05.06, BL+EL+RPU / SMPTE ST 2086, HDR10 compatible
Bit rate                                 : 47.0 Mb/s
Bits/(Pixel*Frame)                       : 0.236
Stream size                              : 39.1 GiB (99%)
Codec configuration box                  : hvcC+dvcC+hvcE
Audio
Codec ID                                 : ac-3
Stream size                              : 545 MiB (1%)
Alternate group                          : 2
rosavanwinkle
Post by rosavanwinkle » Sun Apr 26, 2020 10:03 am
Sgt Hartman wrote:
Sat Apr 25, 2020 8:24 pm
rosavanwinkle wrote:
Sat Apr 25, 2020 8:04 pm
hmmm i think i'm going wrong somewhere,because i have to use the underlaying ac3 audio of the truehd atmos cause otherwise i get a error/hdr
may i have a link to your ffmpeg and tsmuxer?
ffmpeg: https://www.ffmpeg.org/download.html
tsMuxer (nightly): https://bintray.com/justdan96/tsMuxer/t ... UI-Nightly
Once you use tsMuxer you can get the TrueHD/DTS track directly from the original .m2ts file.
So i went through the process again (john wick 3)
and yet i still seem to have the issue that if i use the trueHD track i get a error: see image,
i have to use the underlaying ac3 track otherwise it won''t play(see image)
heres my file info aswell as my ffmpeg command i used:
ffmpeg.exe -i bluray:D:\Test\iso\John\ -map 0:0 -c copy D:\Test\2.exit\BL.hevc -map 0:1 -c copy D:\Test\2.exit\EL.hevc
General
Complete name                            : D:\Test\plex test\john wick 3.ts
File size                                : 71.5 GiB
Duration                                 : 2 h 10 min
Overall bit rate                         : 78.3 Mb/s
Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.06.06, BL+EL+RPU, HDR10 compatible / SMPTE ST 2086, HDR10 compatible
Codec ID                                 : 6
Bit rate                                 : 73.8 Mb/s
Bits/(Pixel*Frame)                       : 0.371
Stream size                              : 67.4 GiB (94%)
Mastering display luminance              : min: 0.0010 cd/m2, max: 1000 cd/m2
Maximum Frame-Average Light Level        : 358 cd/m2
Audio
Format                                   : AC-3 MLP FBA 16-ch
Format/Info                              : Audio Coding 3 + Meridian Lossless Packing FBA with 16-channel presentation
Muxing mode                              : Stream extension
Codec ID                                 : 131
Maximum bit rate                         : 6 327 kb/s
Stream size                              : 599 MiB (1%)
Number of dynamic objects                : 15
Mediaplayer: Nvidia Shield TV Pro
TV: LG 55SK7900PLA
Soundbar: LG SK8 (not LG SK8Y)
plex pass user
Discord:Rosa#1111
kcxserver
Post by kcxserver » Sun Apr 26, 2020 10:52 am
Use MakeMKV 1.51.1 (I deselect all audio tracks and subtitles, so i only convert the video)
Use this old or fixed tsmuxer:
tsMuxer dvhe.04.zip https://forums.plex.tv/uploads/short-ur ... pD0Jt1.zip
tsMuxer dvhe.08.zip https://forums.plex.tv/uploads/short-ur ... 13jSZs.zip
(I found the two tsmuxers here in the forum and also shared them at plex forum)
ffmpeg is not required... just get the soundtracks directly from the disc/.mpls/.m2ts
SamuriHL summed it up well:
SamuriHL wrote:
Thu Apr 16, 2020 3:36 am
Goddamn this is AWESOME! Made an unprotected ISO of Joker (you'll see why in a sec). Created the MKV with MakeMKV. Opened TSMuxer and dropped the MKV onto it. Opened the mounted ISO's 800.mpls and added the audio track. Spit out a TS file, dropped it on my NAS. Plex picked it up and is now playing in Dolby Vision with ATMOS. Super brilliant and thanks to all who have been fighting this good fight!!
If you need subtitles, demux with the tsmuxer the PGS subtitles from the disc/.mpls /.m2ts in .sup files.
Then create an SRT subtitle from the .sup with the program subtitle edit. Then put it in the folder of your video and name it like this:
filename_from_video .eng.srt
filename_from_video .eng.forced.srt
This is my way as I play it with the Shield 2019 Pro and Plex
Here's another hint it might not work for you:
shawnc22 wrote:
Sat Apr 25, 2020 4:04 pm
From personal testing, it does not seem like an issue with profile 6, but rather one with recent versions of tsmuxer and the video track that makemkv is creating. If you create the BL+EL+RPU hevc track with yusecope’s tool instead (which theoretically is the same one generated by makemkv), it will work fine in profile 6 with the latest nightly builds of tsmuxer. If you also modify the source code of the latest tsmuxer build to create profile 4 instead of 6 files with the video track from makemkv, plex will also not recognize the video track at all. It seems like there’s just something from the makemkv video track that recent versions of tsmuxer do not like. The other odd thing is mediainfo still detects the video track just fine despite not being playable on plex.
rosavanwinkle
Post by rosavanwinkle » Sun Apr 26, 2020 12:36 pm
Still the same error/issue, used makemkv just for the videotrack, then used tsmuxer (both of them) to get the truehd track...anyone wants to talk to me in a chat on discord? idk where i'm going wrong...
Discord: Rosa Van Winkle#2593
TV: LG 55SK7900PLA
plex pass user
Discord:Rosa#1111
Post by RESET_9999 » Sun Apr 26, 2020 12:51 pm
tr000 wrote:
Sun Apr 26, 2020 3:37 am
RESET_9999 wrote:
Sat Oct 05, 2019 4:51 pm
real web-dl single layer DV of Stranger Things season 3 play nicely.
This is very old but where did you find a DV Web-DL? I've never seen that, only DV from Blu-ray rips.
There are 3 single layer DV profile 05.06 web-dl releases circulating on the web.
Stranger things S03
Mandalorian S01
Star Wars New Hope (which I successfully added a trueHD Atmos track)
the last two can be found on one of the most known public torrent websites. ST can be found on a Russian tracker.
Complete name                            : G:\4k\Star.Wars.Episode.IV-A.New.Hope.1977.DV.ts
File size                                : 21.4 GiB
Duration                                 : 2 h 4 min
Overall bit rate                         : 24.6 Mb/s
Video
Format profile                           : Main 10@L5@High
Bit rate                                 : 20.9 Mb/s
Chroma subsampling                       : 4:2:0
Bits/(Pixel*Frame)                       : 0.105
Stream size                              : 18.2 GiB (85%)
Color range                              : Full
Audio #1
Codec ID                                 : 131
Maximum bit rate                         : 3 705 kb/s
Stream size                              : 571 MiB (3%)
Number of dynamic objects                : 13
Text #1
Format                                   : PGS
Codec ID                                 : 144
Text #2
Format                                   : PGS
Codec ID                                 : 144
Delay relative to video                  : 41 ms
deadchip12
Post by deadchip12 » Sun Apr 26, 2020 1:23 pm
Stranger things S03
Mandalorian S01
Video
Color range                              : Full
Audio #1
Codec ID                                 : 131
Text #1
Format                                   : PGS
Codec ID                                 : 144
Text #2
Format                                   : PGS
Codec ID                                 : 144
My c9 just refuses to play the Mandalorian video files. Actually the files play at first but once I skip to another point in the film the video stops playing and shows a message “the file cannot be recognized”. After that, that message shows everytime I try to play the video. Very weird. Apparently the tv can play it but only temporarily.
Post by RESET_9999 » Sun Apr 26, 2020 1:26 pm
yes as we discussed the other day about that, the problem seems to be the C9 because the files play fine on the C6, C7, C8, Shield, X700 & oppo.
Sgt Hartman
Post by Sgt Hartman » Sun Apr 26, 2020 2:16 pm
General
Video
Codec ID                                 : 6
Audio
Codec ID                                 : 131
Are you playing with subs (pgs) on? If yes, try without.
rosavanwinkle
Post by rosavanwinkle » Sun Apr 26, 2020 3:48 pm
General
Video
Codec ID                                 : 6
Audio
Codec ID                                 : 131
No subs at all
TV: LG 55SK7900PLA
plex pass user
Discord:Rosa#1111
tr000
Post by tr000 » Mon Apr 27, 2020 12:24 am
Stranger things S03
Mandalorian S01
Video
Color range                              : Full
Audio #1
Codec ID                                 : 131
Text #1
Format                                   : PGS
Codec ID                                 : 144
Text #2
Format                                   : PGS
Codec ID                                 : 144
Very interesting. BL+RPU makes sense since I get BL+EL+RPU from Blu-rays. I never got the AC3+THD to work on my TV though.
I watched the Mandalorian on the native Disney+ app with DV and it was unremarkable, but good to know the scene can rip DV from streams. I wish there was more DV available since basically everything on Netflix and Disney+ has it.
deadchip12
Post by deadchip12 » Mon Apr 27, 2020 3:23 am
Stranger things S03
Mandalorian S01
Video
Color range                              : Full
Audio #1
Codec ID                                 : 131
Text #1
Format                                   : PGS
Codec ID                                 : 144
Text #2
Format                                   : PGS
Codec ID                                 : 144
I see people watch Mandalorian on Disney+ and say it is fake hdr with max luminance never exceeding 200 nits. However when I download the webrip x265 10 bit torrent version of the show and watch it on my oled it doesn't look like fake hdr. The specular highlights definitely are way above 200 nits; explosions and lasers are even blinding at times. The overall presentation is better than some ultra hd bluray even. The only complaint is the blacks look elevated in dark scenes, shadow detail is not the best and there's some color banding on the sky. Not sure if there is a diffencence between this version and the streaming one.
Arbigator
Post by Arbigator » Mon Apr 27, 2020 3:40 am
I'm not sure what is going wrong when I try this, but no matter what I do the files stutter like crazy when I try playing them through plex on the 2019 Shield, when I hit stop the Shield is unresponsive for about 10 seconds as well. I've tried multiple versions of tsMuxer, and mode 1 and 2 of yusesope's tool. Though when I try mode 2, media info reports the file as profile 08.06 rather than profile 5 for some reason.
I have a 2019 Shield non pro, and a LG B9
I'm currently using version 3 revision 1 of yusesope's tool and the latest tsMuxer nightly.
I demux the m2ts in tsMuxer, then put them in yusesope's tool, then back to tsMuxer to remux with the audio track.
Can anyone using a Shield let me know their exact steps and which versions of the software lead to smooth playback?
Thank you!
badrobot
Post by badrobot » Mon Apr 27, 2020 4:38 am
Thank you!
use this version of tsmuxer, then the output will be dhve05.06 instead of dhve 08.06
https://bintray.com/justdan96/tsMuxer/t ... 1-36#files
I am not a native English speaker.
Sorry for my bad English.
Post by shawnc22 » Mon Apr 27, 2020 4:59 am
Thank you!
try turning off the new player and make sure frame rate match is on in the plex player settings
Post by SamuriHL » Mon Apr 27, 2020 11:58 am
Yeah make sure the refresh rate matches the source video. If you're playing 23.976 content at 59 or 60 it'll cause issues.
