Feature Request: Disable automatic disk scan
Dude69
Post by Dude69 »
I often use my DVD drive for ripping disks, it takes a long time. Same time I might fire up MakeMKV to work no images. Problem is, MakeMKV will always automatically scan the disk drive. It not only interrupts the process but also delays me using MakeMKV. Thanks for considering this option.
doveplay
Re: Feature Request: Disable automatic disk scan
Post by doveplay »
I vote for this with a small clarification: The scanning (what is automatic today) and analysis (which requires an action today) should be configurable such that one can toggle automatic mode for both.
anomousny
Post by anomousny »
+1
For my typical usage the automatic disk scan is useless and makes me wait every time I start MakeMKV.
joe42
Post by joe42 »
I too would like to have an option to disable the automatic disc scan.
rinza
Post by rinza »
Please add this feature. I use other tools to work with physical media, with MakeMKV working almost exclusively with ISO files. MakeMKV's automatic behaviour causes seek conflicts, disrupting the other program.
How I currently workaround this problem:
I have a dummy ISO file that I mount as a virtual drive. I have MakeMKV's "single drive" mode enabled, and tell it to use the virtual drive when it opens.
It would be nice to just have a checkbox in the MakeMKV config to disable that behaviour instead of deflecting unwanted behaviour with a hack.
kolepard
Post by kolepard »
I too would like to see an option to disable automatic disc scanning.
Thank you for considering this feature.
Kevin
Turn on exclusive drive mode/ single drive mode
Exclusive mode won't work for this, because the goal is to go directly to ripping images on the hard drive. Exclusive mode just limits how many drives are "inconvenienced" getting there.
paulster
Post by paulster »
Adding a +1 for this. I rip everything to ISO first and since I have two drives if I get a 2-disc set then I can't start MakeMKV until the second ISO has finished ripping or it can cause problems with the drive that's active.
mtc3882
Post by mtc3882 »
And a +1 from me too. The automatic DVD drive scan when I start makemkv is a nuisance and adds unnecessary delay. I only use makemkv to convert already-ripped DVDs which are stored on a hard drive. It's okay if auto-scan is the default when makemkv is downloaded, but I'd like to be able to change that behaviour on a permanent basis.
magingen
Post by magingen »
It's been 10 years and this is still an issue. How hard can it be to add something like this?
magingen wrote:
Tue Nov 08, 2022 6:46 pm
It's not an issue turn on single drive mode in settings
goldenvenom
Post by goldenvenom »
Hi, a bit late coming back for this topic, i even asked AI to collerct info but there is no hit.
Enabling "single drive mode" won't avoid loading the drive automatically.
proc-mkv1-> rip uhd
proc-mkv2-> convert to .mkv
ptoc-mkv2 loads the drive that mkv1 uses which slows it down a lot until it found it just to open a bbmv. Am i missing something to archieve this behaviour?
Greetings
goldenvenom wrote:
Fri Apr 04, 2025 8:07 am
proc-mkv1-> rip uhd
Greetings
When you create the second MakeMKV process, the one I think you're using to load a backup and create .mkv files from it, are you selecting a different optical drive than the one you selected when you created the first MakeMKV process?
