This is very old but where did you find a DV Web-DL? I've never seen that, only DV from Blu-ray rips.RESET_9999 wrote: ↑Sat Oct 05, 2019 4:51 pmreal web-dl single layer DV of Stranger Things season 3 play nicely.
Someone PMed me asking for MediaInfo of the file that worked. I decided I might as well give some comprehensive documentation, so:
Here are the test files that worked:
Video
Menu ID : 1 (0x1)
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Codec ID : 36
Duration : 59 s 976 ms
Bit rate : 21.3 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.107
Stream size : 152 MiB (95%)
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2
Maximum Content Light Level : 2013 cd/m2
Maximum Frame-Average Light Level : 393 cd/m2
Video
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.04.0A, EL+RPU, SDR compatible / SMPTE ST 2086, HDR10 compatible
Codec ID : hev1
Codec ID/Info : High Efficiency Video Coding
Duration : 59 s 977 ms
Bit rate : 21.9 Mb/s
Frame rate mode : Constant
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.110
Stream size : 157 MiB (100%)
Default : Yes
Alternate group : 1
Encoded date : UTC 2020-04-24 14:23:37
Tagged date : UTC 2020-04-24 14:23:37
Codec configuration box : hvcC+dvcC
Video
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU / SMPTE ST 2086, HDR10 compatible
Codec ID : dvhe
Codec ID/Info : High Efficiency Video Coding with Dolby Vision
Color space : YUV
Bit depth : 10 bits
Default : Yes
Alternate group : 1
Encoded date : UTC 2020-04-24 14:23:57
Tagged date : UTC 2020-04-24 14:23:57
Video
Format : HEVC
Codec ID : hev1
Color space : YUV
Bit depth : 10 bits
Default : Yes
Alternate group : 1
Encoded date : UTC 2020-04-24 14:12:43
Tagged date : UTC 2020-04-24 14:12:43
Video
Format : HEVC
Codec ID : dvhe
Color space : YUV
Bit depth : 10 bits
Default : Yes
Alternate group : 1
Encoded date : UTC 2020-04-24 13:53:07
Tagged date : UTC 2020-04-24 13:53:07
Video
Menu ID : 1 (0x1)
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU, HDR10 compatible / SMPTE ST 2086, HDR10 compatible
Codec ID : 6
Color space : YUV
Bit depth : 10 bits
Video #1
Menu ID : 1 (0x1)
Format : HEVC
HDR format : SMPTE ST 2086, HDR10 compatible
Codec ID : 36
Color space : YUV
Bit depth : 10 bits
Video #2
Menu ID : 1 (0x1)
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.07.06, EL+RPU, 8 compatible / SMPTE ST 2086, HDR10 compatible
Codec ID : 6
Duration : 59 s 934 ms
Width : 1 920 pixels
Height : 1 080 pixels
Color space : YUV
Bit depth : 10 bits
Video #1
Menu ID : 1 (0x1)
Format : HEVC
Codec ID : 36
Color space : YUV
Bit depth : 10 bits
Video #2
Menu ID : 1 (0x1)
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.07.05, EL+RPU, 8 compatible / SMPTE ST 2086, HDR10 compatible
Codec ID : 36
Color space : YUV
Bit depth : 10 bits
Video #1
Format : HEVC
Codec ID : hev1
Duration : 1 min 0 s
Bit rate : 22.1 Mb/s
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.111
Stream size : 159 MiB (99%)
Default : Yes
Alternate group : 1
Encoded date : UTC 2020-04-24 14:21:16
Tagged date : UTC 2020-04-24 14:21:16
Video #2
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.04.06, EL+RPU, SDR compatible / SMPTE ST 2086, HDR10 compatible
Codec ID : hev1
Bit rate : 121 kb/s
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.002
Stream size : 888 KiB (1%)
Default : No
Alternate group : 1
Video #1
Format : HEVC
Codec ID : dvhe
Color space : YUV
Bit depth : 10 bits
Default : Yes
Alternate group : 1
Encoded date : UTC 2020-04-24 14:21:09
Tagged date : UTC 2020-04-24 14:21:09
Video #2
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.05.03, BL+RPU / SMPTE ST 2086, HDR10 compatible
Codec ID : dvhe
Bit rate : 121 kb/s
Color space : YUV
Bit depth : 10 bits
Default : No
Alternate group : 1
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (mp42/dby1/isom)
File size : 39.6 GiB
Duration : 1 h 59 min
Overall bit rate : 47.6 Mb/s
Encoded date : UTC 2020-04-24 19:00:45
Tagged date : UTC 2020-04-24 19:00:45
Video
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.05.06, BL+EL+RPU / SMPTE ST 2086, HDR10 compatible
Codec ID : dvhe
Bit rate : 47.0 Mb/s
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.236
Stream size : 39.1 GiB (99%)
Default : Yes
Alternate group : 1
Codec configuration box : hvcC+dvcC+hvcE
Audio
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : ac-3
Bit rate mode : Constant
Bit rate : 640 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 545 MiB (1%)
Service kind : Complete Main
Default : Yes
Alternate group : 2
So i went through the process again (john wick 3)Sgt Hartman wrote: ↑Sat Apr 25, 2020 8:24 pmffmpeg: https://www.ffmpeg.org/download.htmlrosavanwinkle wrote: ↑Sat Apr 25, 2020 8:04 pmhmmm i think i'm going wrong somewhere,because i have to use the underlaying ac3 audio of the truehd atmos cause otherwise i get a error/hdr
may i have a link to your ffmpeg and tsmuxer?
tsMuxer (nightly): https://bintray.com/justdan96/tsMuxer/t ... UI-Nightly
Once you use tsMuxer you can get the TrueHD/DTS track directly from the original .m2ts file.
and yet i still seem to have the issue that if i use the trueHD track i get a error: see image,
i have to use the underlaying ac3 track otherwise it won''t play(see image)
heres my file info aswell as my ffmpeg command i used:
ffmpeg.exe -i bluray:D:\Test\iso\John\ -map 0:0 -c copy D:\Test\2.exit\BL.hevc -map 0:1 -c copy D:\Test\2.exit\EL.hevc
General
Complete name : D:\Test\plex test\john wick 3.ts
Format : MPEG-TS
File size : 71.5 GiB
Duration : 2 h 10 min
Overall bit rate mode : Variable
Overall bit rate : 78.3 Mb/s
Maximum Overall bit rate : 35.5 Mb/s
Video
Menu ID : 1 (0x1)
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.06.06, BL+EL+RPU, HDR10 compatible / SMPTE ST 2086, HDR10 compatible
Codec ID : 6
Bit rate : 73.8 Mb/s
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.371
Stream size : 67.4 GiB (94%)
Mastering display luminance : min: 0.0010 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 1000 cd/m2
Maximum Frame-Average Light Level : 358 cd/m2
Audio
Menu ID : 1 (0x1)
Format : AC-3 MLP FBA 16-ch
Format/Info : Audio Coding 3 + Meridian Lossless Packing FBA with 16-channel presentation
Commercial name : Dolby TrueHD with Dolby Atmos
Muxing mode : Stream extension
Codec ID : 131
Bit rate mode : Variable
Bit rate : 640 kb/s
Maximum bit rate : 6 327 kb/s
Channel(s) : 8 channels
Channel layout : L R C LFE Ls Rs Lb Rb
Stream size : 599 MiB (1%)
Language : English
Number of dynamic objects : 15
Bed channel count : 1 channel
Bed channel configuration : LFE
Mediaplayer: Nvidia Shield TV Pro
TV: LG 55SK7900PLA
Soundbar: LG SK8 (not LG SK8Y)
plex pass user
Discord:Rosa#1111
TV: LG 55SK7900PLA
plex pass user
Discord:Rosa#1111
Use MakeMKV 1.51.1 (I deselect all audio tracks and subtitles, so i only convert the video)rosavanwinkle wrote: ↑Sun Apr 26, 2020 10:03 amhmmm i think i'm going wrong somewhere,because i have to use the underlaying ac3 audio of the truehd atmos cause otherwise i get a error/hdr
Use this old or fixed tsmuxer:
tsMuxer dvhe.04.zip https://forums.plex.tv/uploads/short-ur ... pD0Jt1.zip
tsMuxer dvhe.08.zip https://forums.plex.tv/uploads/short-ur ... 13jSZs.zip
(I found the two tsmuxers here in the forum and also shared them at plex forum)
ffmpeg is not required... just get the soundtracks directly from the disc/.mpls/.m2ts
SamuriHL summed it up well:
If you need subtitles, demux with the tsmuxer the PGS subtitles from the disc/.mpls /.m2ts in .sup files.SamuriHL wrote: ↑Thu Apr 16, 2020 3:36 amGoddamn this is AWESOME! Made an unprotected ISO of Joker (you'll see why in a sec). Created the MKV with MakeMKV. Opened TSMuxer and dropped the MKV onto it. Opened the mounted ISO's 800.mpls and added the audio track. Spit out a TS file, dropped it on my NAS. Plex picked it up and is now playing in Dolby Vision with ATMOS. Super brilliant and thanks to all who have been fighting this good fight!!
Then create an SRT subtitle from the .sup with the program subtitle edit. Then put it in the folder of your video and name it like this:
filename_from_video .eng.srt
filename_from_video .eng.forced.srt
This is my way as I play it with the Shield 2019 Pro and Plex
Here's another hint it might not work for you:
shawnc22 wrote: ↑Sat Apr 25, 2020 4:04 pmFrom personal testing, it does not seem like an issue with profile 6, but rather one with recent versions of tsmuxer and the video track that makemkv is creating. If you create the BL+EL+RPU hevc track with yusecope’s tool instead (which theoretically is the same one generated by makemkv), it will work fine in profile 6 with the latest nightly builds of tsmuxer. If you also modify the source code of the latest tsmuxer build to create profile 4 instead of 6 files with the video track from makemkv, plex will also not recognize the video track at all. It seems like there’s just something from the makemkv video track that recent versions of tsmuxer do not like. The other odd thing is mediainfo still detects the video track just fine despite not being playable on plex.
kcxserver wrote: ↑Sun Apr 26, 2020 10:52 amUse MakeMKV 1.51.1 (I deselect all audio tracks and subtitles, so i only convert the video)rosavanwinkle wrote: ↑Sun Apr 26, 2020 10:03 amhmmm i think i'm going wrong somewhere,because i have to use the underlaying ac3 audio of the truehd atmos cause otherwise i get a error/hdr
SamuriHL summed it up well:If you need subtitles, demux with the tsmuxer the PGS subtitles from the disc/.mpls /.m2ts in .sup files.SamuriHL wrote: ↑Thu Apr 16, 2020 3:36 amGoddamn this is AWESOME! Made an unprotected ISO of Joker (you'll see why in a sec). Created the MKV with MakeMKV. Opened TSMuxer and dropped the MKV onto it. Opened the mounted ISO's 800.mpls and added the audio track. Spit out a TS file, dropped it on my NAS. Plex picked it up and is now playing in Dolby Vision with ATMOS. Super brilliant and thanks to all who have been fighting this good fight!!
Here's another hint it might not work for you:shawnc22 wrote: ↑Sat Apr 25, 2020 4:04 pmFrom personal testing, it does not seem like an issue with profile 6, but rather one with recent versions of tsmuxer and the video track that makemkv is creating. If you create the BL+EL+RPU hevc track with yusecope’s tool instead (which theoretically is the same one generated by makemkv), it will work fine in profile 6 with the latest nightly builds of tsmuxer. If you also modify the source code of the latest tsmuxer build to create profile 4 instead of 6 files with the video track from makemkv, plex will also not recognize the video track at all. It seems like there’s just something from the makemkv video track that recent versions of tsmuxer do not like. The other odd thing is mediainfo still detects the video track just fine despite not being playable on plex.
Still the same error/issue, used makemkv just for the videotrack, then used tsmuxer (both of them) to get the truehd track...anyone wants to talk to me in a chat on discord? idk where i'm going wrong...
Discord: Rosa Van Winkle#2593
TV: LG 55SK7900PLA
plex pass user
Discord:Rosa#1111
TV: LG 55SK7900PLA
plex pass user
Discord:Rosa#1111
There are 3 single layer DV profile 05.06 web-dl releases circulating on the web.tr000 wrote: ↑Sun Apr 26, 2020 3:37 amThis is very old but where did you find a DV Web-DL? I've never seen that, only DV from Blu-ray rips.RESET_9999 wrote: ↑Sat Oct 05, 2019 4:51 pmreal web-dl single layer DV of Stranger Things season 3 play nicely.
Stranger things S03
Mandalorian S01
Star Wars New Hope (which I successfully added a trueHD Atmos track)
the last two can be found on one of the most known public torrent websites. ST can be found on a Russian tracker.
Complete name : G:\4k\Star.Wars.Episode.IV-A.New.Hope.1977.DV.ts
Format : MPEG-TS
File size : 21.4 GiB
Duration : 2 h 4 min
Overall bit rate : 24.6 Mb/s
Video
Menu ID : 1 (0x1)
Format : HEVC
Format profile : Main 10@L5@High
Codec ID : 36
Bit rate : 20.9 Mb/s
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.105
Stream size : 18.2 GiB (85%)
Color range : Full
Audio #1
Menu ID : 1 (0x1)
Codec ID : 131
Bit rate : 640 kb/s
Maximum bit rate : 3 705 kb/s
Stream size : 571 MiB (3%)
Language : English
Number of dynamic objects : 13
Text #1
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Language : English
Text #2
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Delay relative to video : 41 ms
Language : English
My c9 just refuses to play the Mandalorian video files. Actually the files play at first but once I skip to another point in the film the video stops playing and shows a message “the file cannot be recognized”. After that, that message shows everytime I try to play the video. Very weird. Apparently the tv can play it but only temporarily.RESET_9999 wrote: ↑Sun Apr 26, 2020 12:51 pmThere are 3 single layer DV profile 05.06 web-dl releases circulating on the web.tr000 wrote: ↑Sun Apr 26, 2020 3:37 amThis is very old but where did you find a DV Web-DL? I've never seen that, only DV from Blu-ray rips.RESET_9999 wrote: ↑Sat Oct 05, 2019 4:51 pmreal web-dl single layer DV of Stranger Things season 3 play nicely.
Stranger things S03
Mandalorian S01
Complete name : G:\4k\Star.Wars.Episode.IV-A.New.Hope.1977.DV.ts Format : MPEG-TS File size : 21.4 GiB Duration : 2 h 4 min Overall bit rate mode : Variable Overall bit rate : 24.6 Mb/s Maximum Overall bit rate : 35.5 Mb/s Video ID : 4117 (0x1015) Menu ID : 1 (0x1) Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5@High HDR format : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU Codec ID : 36 Duration : 2 h 4 min Bit rate : 20.9 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 bits Bits/(Pixel*Frame) : 0.105 Stream size : 18.2 GiB (85%) Color range : Full Audio #1 ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : AC-3 MLP FBA 16-ch Format/Info : Audio Coding 3 + Meridian Lossless Packing FBA with 16-channel presentation Commercial name : Dolby TrueHD with Dolby Atmos Muxing mode : Stream extension Codec ID : 131 Duration : 2 h 4 min Bit rate mode : Variable Bit rate : 640 kb/s Maximum bit rate : 3 705 kb/s Channel(s) : 8 channels Channel layout : L R C LFE Ls Rs Lb Rb Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 571 MiB (3%) Language : English Service kind : Complete Main Number of dynamic objects : 13 Bed channel count : 1 channel Bed channel configuration : LFE Text #1 ID : 4768 (0x12A0) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Language : English Text #2 ID : 4769 (0x12A1) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Delay relative to video : 41 ms Language : English
yes as we discussed the other day about that, the problem seems to be the C9 because the files play fine on the C6, C7, C8, Shield, X700 & oppo.deadchip12 wrote: ↑Sun Apr 26, 2020 1:23 pmMy c9 just refuses to play the Mandalorian video files. Actually the files play at first but once I skip to another point in the film the video stops playing and shows a message “the file cannot be recognized”. After that, that message shows everytime I try to play the video. Very weird. Apparently the tv can play it but only temporarily.
Are you playing with subs (pgs) on? If yes, try without.rosavanwinkle wrote: ↑Sun Apr 26, 2020 10:03 amSo i went through the process again (john wick 3)Sgt Hartman wrote: ↑Sat Apr 25, 2020 8:24 pmffmpeg: https://www.ffmpeg.org/download.htmlrosavanwinkle wrote: ↑Sat Apr 25, 2020 8:04 pmhmmm i think i'm going wrong somewhere,because i have to use the underlaying ac3 audio of the truehd atmos cause otherwise i get a error/hdr
heres my file info aswell as my ffmpeg command i used:Code: Select all
General ID : 1 (0x1) Complete name : D:\Test\plex test\john wick 3.ts Format : MPEG-TS File size : 71.5 GiB Duration : 2 h 10 min Overall bit rate mode : Variable Overall bit rate : 78.3 Mb/s Maximum Overall bit rate : 35.5 Mb/s Video ID : 4117 (0x1015) Menu ID : 1 (0x1) Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High HDR format : Dolby Vision, Version 1.0, dvhe.06.06, BL+EL+RPU, HDR10 compatible / SMPTE ST 2086, HDR10 compatible Codec ID : 6 Duration : 2 h 10 min Bit rate : 73.8 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.371 Stream size : 67.4 GiB (94%) Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0010 cd/m2, max: 1000 cd/m2 Maximum Content Light Level : 1000 cd/m2 Maximum Frame-Average Light Level : 358 cd/m2 Audio ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : AC-3 MLP FBA 16-ch Format/Info : Audio Coding 3 + Meridian Lossless Packing FBA with 16-channel presentation Commercial name : Dolby TrueHD with Dolby Atmos Muxing mode : Stream extension Codec ID : 131 Duration : 2 h 10 min Bit rate mode : Variable Bit rate : 640 kb/s Maximum bit rate : 6 327 kb/s Channel(s) : 8 channels Channel layout : L R C LFE Ls Rs Lb Rb Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 599 MiB (1%) Language : English Service kind : Complete Main Number of dynamic objects : 15 Bed channel count : 1 channel Bed channel configuration : LFE
No subs at allSgt Hartman wrote: ↑Sun Apr 26, 2020 2:16 pmAre you playing with subs (pgs) on? If yes, try without.rosavanwinkle wrote: ↑Sun Apr 26, 2020 10:03 amSo i went through the process again (john wick 3)Sgt Hartman wrote: ↑Sat Apr 25, 2020 8:24 pm
TV: LG 55SK7900PLA
plex pass user
Discord:Rosa#1111
TV: LG 55SK7900PLA
plex pass user
Discord:Rosa#1111
Very interesting. BL+RPU makes sense since I get BL+EL+RPU from Blu-rays. I never got the AC3+THD to work on my TV though.RESET_9999 wrote: ↑Sun Apr 26, 2020 12:51 pmThere are 3 single layer DV profile 05.06 web-dl releases circulating on the web.tr000 wrote: ↑Sun Apr 26, 2020 3:37 amThis is very old but where did you find a DV Web-DL? I've never seen that, only DV from Blu-ray rips.RESET_9999 wrote: ↑Sat Oct 05, 2019 4:51 pmreal web-dl single layer DV of Stranger Things season 3 play nicely.
Stranger things S03
Mandalorian S01
I watched the Mandalorian on the native Disney+ app with DV and it was unremarkable, but good to know the scene can rip DV from streams. I wish there was more DV available since basically everything on Netflix and Disney+ has it.
I see people watch Mandalorian on Disney+ and say it is fake hdr with max luminance never exceeding 200 nits. However when I download the webrip x265 10 bit torrent version of the show and watch it on my oled it doesn't look like fake hdr. The specular highlights definitely are way above 200 nits; explosions and lasers are even blinding at times. The overall presentation is better than some ultra hd bluray even. The only complaint is the blacks look elevated in dark scenes, shadow detail is not the best and there's some color banding on the sky. Not sure if there is a diffencence between this version and the streaming one.tr000 wrote: ↑Mon Apr 27, 2020 12:24 amVery interesting. BL+RPU makes sense since I get BL+EL+RPU from Blu-rays. I never got the AC3+THD to work on my TV though.RESET_9999 wrote: ↑Sun Apr 26, 2020 12:51 pmThere are 3 single layer DV profile 05.06 web-dl releases circulating on the web.
Stranger things S03
Mandalorian S01
I'm not sure what is going wrong when I try this, but no matter what I do the files stutter like crazy when I try playing them through plex on the 2019 Shield, when I hit stop the Shield is unresponsive for about 10 seconds as well. I've tried multiple versions of tsMuxer, and mode 1 and 2 of yusesope's tool. Though when I try mode 2, media info reports the file as profile 08.06 rather than profile 5 for some reason.
I have a 2019 Shield non pro, and a LG B9
I'm currently using version 3 revision 1 of yusesope's tool and the latest tsMuxer nightly.
I demux the m2ts in tsMuxer, then put them in yusesope's tool, then back to tsMuxer to remux with the audio track.
Can anyone using a Shield let me know their exact steps and which versions of the software lead to smooth playback?
Thank you!
Thank you!
use this version of tsmuxer, then the output will be dhve05.06 instead of dhve 08.06Arbigator wrote: ↑Mon Apr 27, 2020 3:40 amI'm not sure what is going wrong when I try this, but no matter what I do the files stutter like crazy when I try playing them through plex on the 2019 Shield, when I hit stop the Shield is unresponsive for about 10 seconds as well. I've tried multiple versions of tsMuxer, and mode 1 and 2 of yusesope's tool. Though when I try mode 2, media info reports the file as profile 08.06 rather than profile 5 for some reason.
Thank you!
https://bintray.com/justdan96/tsMuxer/t ... 1-36#files
I am not a native English speaker.
Sorry for my bad English.
try turning off the new player and make sure frame rate match is on in the plex player settingsArbigator wrote: ↑Mon Apr 27, 2020 3:40 amI'm not sure what is going wrong when I try this, but no matter what I do the files stutter like crazy when I try playing them through plex on the 2019 Shield, when I hit stop the Shield is unresponsive for about 10 seconds as well. I've tried multiple versions of tsMuxer, and mode 1 and 2 of yusesope's tool. Though when I try mode 2, media info reports the file as profile 08.06 rather than profile 5 for some reason.
Thank you!
