tr000 wrote:
Sun Apr 26, 2020 3:37 am
RESET_9999 wrote:
Sat Oct 05, 2019 4:51 pm
real web-dl single layer DV of Stranger Things season 3 play nicely.
This is very old but where did you find a DV Web-DL? I've never seen that, only DV from Blu-ray rips.
There are 3 single layer DV profile 05.06 web-dl releases circulating on the web.
Stranger things S03
Mandalorian S01
Star Wars New Hope (which I successfully added a trueHD Atmos track)
the last two can be found on one of the most known public torrent websites. ST can be found on a Russian tracker.
Complete name                            : G:\4k\Star.Wars.Episode.IV-A.New.Hope.1977.DV.ts
File size                                : 21.4 GiB
Duration                                 : 2 h 4 min
Overall bit rate                         : 24.6 Mb/s
Video
Format profile                           : Main 10@L5@High
HDR format                               : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU
Bit rate                                 : 20.9 Mb/s
Chroma subsampling                       : 4:2:0
Bits/(Pixel*Frame)                       : 0.105
Stream size                              : 18.2 GiB (85%)
Color range                              : Full
Audio #1
Format                                   : AC-3 MLP FBA 16-ch
Format/Info                              : Audio Coding 3 + Meridian Lossless Packing FBA with 16-channel presentation
Muxing mode                              : Stream extension
Codec ID                                 : 131
Maximum bit rate                         : 3 705 kb/s
Stream size                              : 571 MiB (3%)
Number of dynamic objects                : 13
Text #1
Format                                   : PGS
Codec ID                                 : 144
Text #2
Format                                   : PGS
Codec ID                                 : 144
Delay relative to video                  : 41 ms
deadchip12
Post by deadchip12 »
RESET_9999 wrote:
Sun Apr 26, 2020 12:51 pm
Stranger things S03
Mandalorian S01
Video
Color range                              : Full
Audio #1
Codec ID                                 : 131
Text #1
Format                                   : PGS
Codec ID                                 : 144
Text #2
Format                                   : PGS
Codec ID                                 : 144
My c9 just refuses to play the Mandalorian video files. Actually the files play at first but once I skip to another point in the film the video stops playing and shows a message “the file cannot be recognized”. After that, that message shows everytime I try to play the video. Very weird. Apparently the tv can play it but only temporarily.
deadchip12 wrote:
Sun Apr 26, 2020 1:23 pm
yes as we discussed the other day about that, the problem seems to be the C9 because the files play fine on the C6, C7, C8, Shield, X700 & oppo.
Sgt Hartman
Post by Sgt Hartman »
rosavanwinkle wrote:
Sun Apr 26, 2020 10:03 am
Sgt Hartman wrote:
Sat Apr 25, 2020 8:24 pm
Sat Apr 25, 2020 8:04 pm
hmmm i think i'm going wrong somewhere,because i have to use the underlaying ac3 audio of the truehd atmos cause otherwise i get a error/hdr
may i have a link to your ffmpeg and tsmuxer?
ffmpeg: https://www.ffmpeg.org/download.html
tsMuxer (nightly): https://bintray.com/justdan96/tsMuxer/t ... UI-Nightly
Once you use tsMuxer you can get the TrueHD/DTS track directly from the original .m2ts file.
So i went through the process again (john wick 3)
and yet i still seem to have the issue that if i use the trueHD track i get a error: see image,
i have to use the underlaying ac3 track otherwise it won''t play(see image)
heres my file info aswell as my ffmpeg command i used:
ffmpeg.exe -i bluray:D:\Test\iso\John\ -map 0:0 -c copy D:\Test\2.exit\BL.hevc -map 0:1 -c copy D:\Test\2.exit\EL.hevc
General
Complete name                            : D:\Test\plex test\john wick 3.ts
File size                                : 71.5 GiB
Duration                                 : 2 h 10 min
Overall bit rate                         : 78.3 Mb/s
Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.06.06, BL+EL+RPU, HDR10 compatible / SMPTE ST 2086, HDR10 compatible
Codec ID                                 : 6
Bit rate                                 : 73.8 Mb/s
Bits/(Pixel*Frame)                       : 0.371
Stream size                              : 67.4 GiB (94%)
Mastering display luminance              : min: 0.0010 cd/m2, max: 1000 cd/m2
Maximum Frame-Average Light Level        : 358 cd/m2
Audio
Codec ID                                 : 131
Maximum bit rate                         : 6 327 kb/s
Stream size                              : 599 MiB (1%)
Number of dynamic objects                : 15
Are you playing with subs (pgs) on? If yes, try without.
rosavanwinkle
Post by rosavanwinkle »
Sgt Hartman wrote:
Sun Apr 26, 2020 2:16 pm
General
Video
Codec ID                                 : 6
Audio
Codec ID                                 : 131
No subs at all
Mediaplayer: Nvidia Shield TV Pro
TV: LG 55SK7900PLA
Soundbar: LG SK8 (not LG SK8Y)
plex pass user
Discord:Rosa#1111
tr000
Post by tr000 »
Stranger things S03
Mandalorian S01
Video
Color range                              : Full
Audio #1
Codec ID                                 : 131
Text #1
Format                                   : PGS
Codec ID                                 : 144
Text #2
Format                                   : PGS
Codec ID                                 : 144
Very interesting. BL+RPU makes sense since I get BL+EL+RPU from Blu-rays. I never got the AC3+THD to work on my TV though.
I watched the Mandalorian on the native Disney+ app with DV and it was unremarkable, but good to know the scene can rip DV from streams. I wish there was more DV available since basically everything on Netflix and Disney+ has it.
deadchip12
tr000 wrote:
Mon Apr 27, 2020 12:24 am
Stranger things S03
Mandalorian S01
Video
Color range                              : Full
Audio #1
Codec ID                                 : 131
Text #1
Format                                   : PGS
Codec ID                                 : 144
Text #2
Format                                   : PGS
Codec ID                                 : 144
I see people watch Mandalorian on Disney+ and say it is fake hdr with max luminance never exceeding 200 nits. However when I download the webrip x265 10 bit torrent version of the show and watch it on my oled it doesn't look like fake hdr. The specular highlights definitely are way above 200 nits; explosions and lasers are even blinding at times. The overall presentation is better than some ultra hd bluray even. The only complaint is the blacks look elevated in dark scenes, shadow detail is not the best and there's some color banding on the sky. Not sure if there is a diffencence between this version and the streaming one.
Arbigator
Post by Arbigator »
I'm not sure what is going wrong when I try this, but no matter what I do the files stutter like crazy when I try playing them through plex on the 2019 Shield, when I hit stop the Shield is unresponsive for about 10 seconds as well. I've tried multiple versions of tsMuxer, and mode 1 and 2 of yusesope's tool. Though when I try mode 2, media info reports the file as profile 08.06 rather than profile 5 for some reason.
I have a 2019 Shield non pro, and a LG B9
I'm currently using version 3 revision 1 of yusesope's tool and the latest tsMuxer nightly.
I demux the m2ts in tsMuxer, then put them in yusesope's tool, then back to tsMuxer to remux with the audio track.
Can anyone using a Shield let me know their exact steps and which versions of the software lead to smooth playback?
Thank you!
badrobot
Post by badrobot »
Arbigator wrote:
Mon Apr 27, 2020 3:40 am
Thank you!
use this version of tsmuxer, then the output will be dhve05.06 instead of dhve 08.06
https://bintray.com/justdan96/tsMuxer/t ... 1-36#files
I am not a native English speaker.
Sorry for my bad English.
Post by shawnc22 »
Thank you!
try turning off the new player and make sure frame rate match is on in the plex player settings
Post by SamuriHL »
Yeah make sure the refresh rate matches the source video. If you're playing 23.976 content at 59 or 60 it'll cause issues.
Totos40
Post by Totos40 »
Hello. sorry for my english, i'm french, i use google translation.
I have been trying for 1 week to put fast and Furious 8 in dolby vision on my tv lg oled65e9 but either I have a black screen and the sound, or the dolby vision logo which is displayed but the image stutters, or the dolby vision logo is displayed but the image displayed has 2 filters.
I used the tools provided in the previous pages.
I used the same technique on the joker film, and it works perfectly.
how to explain that the film fast and furious 8 does not work but that the wild movie yes.
I use iso
rosavanwinkle
Totos40 wrote:
Mon Apr 27, 2020 12:38 pm
I use iso
i'm not sure where your issue is atm,for that reason i shall follow my personal procedure of doing this and see what goes on. i'll keep you posted
TV: LG 55SK7900PLA
plex pass user
Discord:Rosa#1111
Deadly-Knight
Post by Deadly-Knight »
Hello guys,
I've been reading you out extensively in this thread but have yet to find clear steps for dummies and maybe my post will help those like me that are seeking for answers. I bought the new Nvidia Shield 2019 Pro to replace my former one that wasn't supporting the HDR/Dolby Vision. I've spent countless hours learning the 'Do's and Don'ts'. I learned the hard way that MKV files weren't able to do DV but then learned that they do since I have two LG demo files that proved me otherwise. That Kodi wasn't able to play it either. That the Amazon Prime app on the Shield (not the one on the TV) had issues with DV recently as in it wouldn't play Carnival Row or Jack Ryan at all, and that the team was working on a fix. That Plex was the way to go, but couldn't play Blu-ray containers/image/iso/BDMV/etc. That even while selecting the right .m2ts, I only get HDR out of the movie. In the end, on the Shield, the only DV I was able to get was from two LG demo files (MKV format).
TL;DR...I've summarized the next step in my quest for Dolby Vision and Dolby Atmos as in the following: FFmpeg or MakeMKV---->yusesope's tool---->tsMuxeR (nightly)
Question #1- Clear steps that anyone can follow? I found this post but I'm sure the steps changed since then?
by daddy
Tue Aug 06, 2019 5:21 am
Question #2- yusesope's tool, I guess yusesope is a user? A search confirmed this. I have yet to find the tool. I've looked but maybe I'm lacking too much sleep and this confinement is not helping the cause. *Took one last look through the 414 matches* Found this: https://forum.mrmc.tv/viewtopic.php?f=1 ... 310#p25425
Is that it?
Question #3- Why are people picking AC3 over True HD or Atmos?
Question #4- Please?
Thank you guys...going to bed. It's been a long unfruitful night/morning.
Cheers!
D-K
Totos40
Post by Totos40 »
OK thanks a lot
