Hi! Couldn't find appropriate fw inside MK LibreDrive pack for my BU40N with 1.02 firmware, although Makemkv states there's one available. I do presume is the BU40N-U variant as I bought it in Spain through Amazon Spain retail. Unit was built in 2018. No matter the variant though, if I'm right there's no 1.02 firmware replacement for any of them. Which one could I use?
Thank you so much.
I really appreciate any help.
Javier
Here is full data:
OS device name: E:
Product: BD-RE BU40N
Revision: 1.02
Serial number: KZ0I29B0235
Firmware date: 2117-11-30 12:18
Highest AACS version: 62
Harware support: Yes
Firmware support: No
Firmware version: 1.02
Can´t find MK firmware for BU40N variant
Re: Can´t find MK firmware for BU40N variant
HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934 or HL-DT-ST-BD-RE_BU40N-1.02-NM01201-211711301218 from "old" folder.
dm29_
Thank you Mike. It was right there.
Kind regards.
Kind regards.
dm29_
Dear Mike.
Unfortunately flasher tool is no longer available (supposed to be here https://forum.cdrinfo.pl/f29/crossflash ... s58-96313/). Found nothing in the forum.
May you share it?
I really appreciate your help.
Thank
Download the lg tool from my video if you want to use it
May you share it?
Thank
Download the lg flasher from my video if you want to use itdm29_ wrote: Sun Apr 26, 2020 11:38 am Dear Mike.
May you share it?
Thank
