Unable to rip custom Blu-Ray discs
Rancor022
Post by Rancor022 » Sat Apr 25, 2020 9:04 pm
So I have a few Blu-Ray discs that I made years ago that contain home videos, animation, etc. that I made a long time ago. I had used a couple different Blu-Ray authoring tools, such as Aiseesoft Blu-Ray Creator, as well as 25GB BD-R discs. However, when I try to rip them, MakeMKV will load drive information, but won't open the disc. Instead it just says "data".
I suppose in that case it isn't possible to rip homemade Blu-Ray discs? Or is there perhaps a reason my disc is labelled as being a "data" disc?
Re: Unable to rip custom Blu-Ray discs
Post by Woodstock » Sat Apr 25, 2020 9:23 pm
If there is no encryption used, you SHOULD be able to simply copy the files to your hard drive, and play them from there.
Grauhaar
Post by Grauhaar » Sun Apr 26, 2020 4:28 am
You can use MKVTollNIX to convert the xxxxx.m2ts stream file(s) to mkv.
Good Luck :)
Rancor022
Post by Rancor022 » Sun Apr 26, 2020 5:28 am
Grauhaar wrote: Sun Apr 26, 2020 4:28 am You can use MKVTollNIX to convert the xxxxx.m2ts stream file(s) to mkv.
Ah that's a good suggestion, I hadn't thought about that.
