Ex Machina
ungratefulninja
Ex Machina
Post by ungratefulninja » Sat Apr 25, 2020 1:29 am
Hi all,
New to the forums, but I've learned a decent amount from previously just lurking.
I've been going through my collection of movies and am stuck on Ex Machina. I've attached the log from my attempt and was hoping for some help.
Thanks in advance!
MakeMKV_log.txt
(687.62 KiB) Downloaded 734 times
Re: Ex Machina
Post by Woodstock » Sat Apr 25, 2020 2:09 am
The main issue seems to be that the file /BDMV/STREAM/00000.m2ts has some unreadable sections:
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32987873280, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32987873280-32987879424, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32987879424, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32987879424-32987885568, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32987885568, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32987885568-32987891712, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32987891712, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32987891712-32987897856, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32987897856, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32987897856-32987904000, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32987904000, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32987904000-32987910144, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32987910144, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32987910144-32987916288, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32987916288, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32987916288-32987922432, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32987922432, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32987922432-32987928576, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32987928576, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32987928576-32987934720, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32987934720, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32987934720-32987940864, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32987940864, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32987940864-32987947008, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32987947008, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32987947008-32987953152, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32987953152, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32987953152-32987959296, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32987959296, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32987959296-32987965440, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32987965440, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32987965440-32987971584, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32987971584, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32987971584-32987977728, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32987977728, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32987977728-32987983872, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32987983872, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32987983872-32987990016, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32987990016, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32987990016-32987996160, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32987996160, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32987996160-32988002304, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32988002304, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32988002304-32988008448, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32988008448, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32988008448-32988014592, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32988014592, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32988014592-32988020736, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32988020736, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32988020736-32988026880, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32988026880, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32988026880-32988033024, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32988033024, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32988033024-32988039168, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32988039168, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32988039168-32988045312, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32988045312, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32988045312-32988051456, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32988051456, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32988051456-32988057600, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32988057600, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32988057600-32988063744, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32988063744, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32988063744-32988069888, attempting to work around
004004:0000 The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 32988069888, attempting to work around
That's a fairly large area.
Have you tried cleaning the disk?
ungratefulninja
Re: Ex Machina
Post by ungratefulninja » Sat Apr 25, 2020 3:05 am
I have cleaned it with a microfiber cloth and there is no visible dirt or scratches. The log is actually from my 3rd attempt, the 1st had a "volume key is unknown" error, and the 2nd was similar to the log I posted but without the volume key error.
henkeli
Re: Ex Machina
Post by henkeli » Sat Apr 25, 2020 4:20 pm
ungratefulninja wrote: Sat Apr 25, 2020 3:05 am I have cleaned it with a microfiber cloth and there is no visible dirt or scratches. The log is actually from my 3rd attempt, the 1st had a "volume key is unknown" error, and the 2nd was similar to the log I posted but without the volume key error.
I had the same error on my first purchase of this disc from BB. It came with a slip cover. Cleaning did not work. I returned it the other day for a replacement disc (no slip cover on the replacement version) and it worked perfectly.
Pretty good movie for $10 IMO
ungratefulninja
Re: Ex Machina
Post by ungratefulninja » Sat Apr 25, 2020 6:58 pm
Ah, mine also came with a slip cover. Unfortunately I'm way passed my return period so that's out of the question.
Definitely, I really like the movie and at $10 I'll probably just end up getting another in hopes that it works.
ungratefulninja
Re: Ex Machina
Post by ungratefulninja » Sat Apr 25, 2020 9:25 pm
Welp, just had a chance to try playing the movie and my Xbox One S and PS4 aren't getting passed the initial black screen. Looks like I'll have to get another copy and hope it works.
Thanks everyone for your help and assistance!
