[Feature Request] Windows shortcut to target a specific drive
9Nails
Post by 9Nails » Sat Apr 25, 2020 2:45 am
Can I set a command line parameter to tell MakeMKV to use a specific drive in my Windows 10 computer? I would like to use single drive mode, but tell MakeMKV which drive it's to use through the shortcut target instead of manually picking a drive from the list. (My drives are of the same type, so they don't appear different to me.)
Questioning the use of:
"C:\Program Files (x86)\MakeMKV\makemkv.exe" DRV:0
"C:\Program Files (x86)\MakeMKV\makemkv.exe" DRV:1
Grauhaar
Re: Windows shortcut to target a specific drive :?:
Post by Grauhaar » Sat Apr 25, 2020 9:43 am
9Nails wrote: Sat Apr 25, 2020 2:45 am Can I set a command line parameter to tell MakeMKV to use a specific drive in my Windows 10 computer?
No :)
Good Luck :)
aloha
Post by aloha » Sat Apr 25, 2020 12:17 pm
Hello:
But something that might be a feature request for a future version. And maybe not that hard to implement (see disclaimer below).
Reasoning:
Currently the command line MakeMKV has a hidden tool, SDF. That tool HAS the ability to specifically use a specific drive via the -d option. Maybe, just maybe MakeMKV GUI coding could be altered to utilize the -d option from the SDF tool.
Disclaimer:
Of course I have no idea how much coding this would take if it is at all possible, and saying vs doing is actually easier said than done.
Regards,
A
