Hi folks,
I was wondering if anyone got an idea what happened to my .mkv files. Every now and again the sound will drop out and disappear for a few seconds...then its back on track.
The sound if perfectly in sync, even after it dropped out for a moment.
How do I fix this? It's really annoying especially when you miss something important from the movie...
Regards,
germandude
Annoying sound problem
crowfax
Re: Annoying sound problem
What are you using to play the files?
Media Box: Ryzen 5700x / Arc A380, Windows 11, BU40N, BW-16D1HT, BP60NB10
Playback Devices: Nvidia Shield Pro, Apple TV 4k
germandude
hey sorry, i figured out how to do it. it was a problem on my end.
im playing my files with the mede8er med500x. i had the sound setting set to 2ch downstream ^^ fixed it now by selecting the correct audio channels.
cheers n good nite
cheers n good nite
