Dusk Till Dawn will not rip?
gilford
Post by gilford »
heres a paste of the info -
MakeMKV v1.6.2 darwin(x86-release) started
Debug logging enabled, log will be saved as /Users/xxxxxxxxxxxxx/MakeMKV_log.txt
Optical drive "DVD+R-DL HL-DT-ST DVDRW GA32N KC08" opened in OS access mode.
Optical drive "BD-ROM MATSHITA DVDRWBD UJ-110 1Y00" opened in OS access mode.
File 00002.mpls was added as title #0
Title #00000.m2ts has length of 10 seconds which is less than minimum title length of 187 seconds and was therefore skipped
Title #00004.m2ts has length of 8 seconds which is less than minimum title length of 187 seconds and was therefore skipped
Title #00005.m2ts has length of 12 seconds which is less than minimum title length of 187 seconds and was therefore skipped
Title #00002.m2ts has length of 16 seconds which is less than minimum title length of 187 seconds and was therefore skipped
Title #00006.m2ts has length of 12 seconds which is less than minimum title length of 187 seconds and was therefore skipped
Saving 1 titles into directory /Volumes/Music/HD Movies/From Dusk Till Dawn
Error 'Posix error - Input/output error' occurred while reading '/BDMV/STREAM/00007.m2ts' at offset '20574498816'
DEBUG: Code 0 at C+jf2).u{99EgQ6L:213137091
Error 'Posix error - Input/output error' occurred while reading '/BDMV/STREAM/00007.m2ts' at offset '20575156224'
Error 'Posix error - Input/output error' occurred while reading '/BDMV/STREAM/00007.m2ts' at offset '20576071680'
Error 'Posix error - Input/output error' occurred while reading '/BDMV/STREAM/00007.m2ts' at offset '20576335872'
Error 'Posix error - Input/output error' occurred while reading '/BDMV/STREAM/00007.m2ts' at offset '20576993280'
Error 'Posix error - Input/output error' occurred while reading '/BDMV/STREAM/00007.m2ts' at offset '20577908736'
DEBUG: Code 1073741829 at rrB}@)bp]+_xS-|'9[:29395839
DEBUG: Code 1073741829 at rrB}@)bp]+_xS-|'9[:121261727
DEBUG: Code 0 at k&b&FoRqqa9v@NU.sLO:121263958
DEBUG: Code 0 at =y`YC@(UD_=li,5t}km::29394298
DEBUG: Code 0 at KN3sHn&ygq,[PiiD"T%I:121261681
DEBUG: Code 0 at =y`YC@(UD_=li,5t}km::29394183
DEBUG: Code 10047807 at =y`YC@(UD_=li,5t}km::29393309
Failed to save title 0 to file /Volumes/Music/HD Movies/From Dusk Till Dawn/title00.mkv
0 titles saved, 1 failed
Re: Dusk Till Dawn will not rip?
Post by mike admin »
looks like a physically scratched disc. To confirm, please try copying 00007.m2ts in finder.
gilford
Post by gilford »
Sorted, thanks!
setarip_old
RESOLVED - Dusk Till Dawn will not rip?
Post by setarip_old »
Glad to hear your problem's been resolved - and MakeMKV was not at fault ;>}
