Any way to download v1.15.0 or prior?
Just bought a stack of UHD discs from BB and some are really dropping frames and stuttering after the rip completes with no errors logged. Drops are at the same time / repeatable.
Anyone else seeing this with recent rips?
[Solved] Dropping frames...
Re: Dropping frames...
https://www.makemkv.com/download/old/henkeli wrote: ↑Fri Apr 24, 2020 8:37 amAny way to download v1.15.0 or prior?
i think your problem is playback device or bandwidth limited 1.15.1 fixed seamless branching audio dropouts going back means you are missing the fix
Yup, thanks dude.Billycar11 wrote: ↑Fri Apr 24, 2020 10:31 amhttps://www.makemkv.com/download/old/
Tested files on another PC. Same issues.
Changed VLC File Cache from 300ms to 1000ms and that fixed it.
Will have to figure out what to set in JRiver on my HTPC to avoid frame drops on certain files.
