Transporter 3...fatal error but no message
germandude
Post by germandude » Fri Nov 05, 2010 12:06 am
Hi folks,
I just found out about makemkv today. First of all i gotta say that its by far the best bluray-to-mkv app that I found during my half day testing. It's easy and it does what it says.
So i got myself Transporter 1-3 as BD and started ripping them for my mede8er. I didn't encounter any problems with part 1+2...both the picture and sound are perfect.
However whenever I try to rip Transporter 3 it will do everything correctly up to the point when the progress bar freezes during the ripping process. The time will continue to add on, but nothing happens. No error message.
I saw that a few people in this forum are having the same problem with v.1.6.2.
Strange thing in my case is that my drive will continue to read the disc. If I try to abort the process via the "cancel" button then nothing happens. So I just have to close the program via the Windows button.
Another odd thing is that once I open makemkv again, it won't read the disc. So I have to reboot my machine. As soon as the Windows log-off screen says "shutting down" the loading circle freezes as well and I gotta physically shut down my computer via the power button.
Once I booted up Windows again I can't see my drive on the computer anymore. So I have to physically turn it off and on again to have it back in my devices list in Windows.
I've tried everything from: (1) giving it time to finish ripping; (2) cleaning the disc
Hopefully someone can gimme a hand solving these issues.
Here are my specs:
Lenovo Thinkpad Edge 15
i5 Dual Core 2.27GHz
4GB DDR3 Ram
ATI Mobility Radeon HD 545v (512GB DDR3)
Kingston SSD 128GB
Toshiba Samsung SH-B123 Bluray Drive 12x (external)
germandude
Re: Transporter 3...fatal error but no message
Post by germandude » Fri Nov 05, 2010 12:16 am
I'm trying to copy the disc with AnyDVD HD now and see if it works then. Will report results!
setarip_old
Post by setarip_old » Fri Nov 05, 2010 12:22 am
Hi!
Sounds like your system overheated.
Is your system overclocked?
Are all three discs commercial, pressed, Blu-ray discs?
germandude
Post by germandude » Fri Nov 05, 2010 12:24 am
Nope, nothing overclocked. Checked the temperatures as well and they're all sweet. Must be something else!
setarip_old
Post by setarip_old » Fri Nov 05, 2010 12:37 am
I guess you didn't see my second question, so I'll repeat it:
If not,you shouldn't presume that MakemKV (or any similar program) would process it/them properly...
germandude
Post by germandude » Fri Nov 05, 2010 12:43 am
Sorry yeah I missed that. All three are commercial discs!
germandude
Post by germandude » Fri Nov 05, 2010 2:10 am
Problem solved, it worked like a charm via AnyDVD HD.
servocrow
Post by servocrow » Fri Nov 05, 2010 5:16 pm
HA ! ive actually beens scolded for suggesting this, I too tend to use AnyD*D to rip blu rays then use MAKEMKV, I own a serial for MAKEMKV, however I still feel its decrypting is its weaker feature, one NEEDS and arsenal of tools these days ...
glad you solved your issue even happier you proved my freakin point !
germandude
Post by germandude » Fri Nov 05, 2010 5:24 pm
Yup I was stoked too when I found out that it worked...but you're absolutely right! Often you just gotta have more than one program...sadly
Post by mike admin » Sat Nov 06, 2010 9:51 am
Please post the debug log. I find it very unlikely that MakeMKV couldn't process a disc but could process the same disc decrypted by other program.
