Grencola
#2221 Post by Grencola » Thu Apr 23, 2020 1:14 pm
box4m wrote: Thu Apr 23, 2020 5:12 am edit: i tried it and seems like it created single layer hmm, is it "correct" or dvdfabmethod?
correct. the shield has its own weird color and stutter bugs etc, but all the dv info is retained. comparing the disc to the .ts on x700 is identical.
darrrkmanxxx wrote: Thu Apr 23, 2020 7:30 am
How did you achieved that? Do I need to tweak settings somewhere in tsMuxer? I used w64-nightly-2020-04-19--02-12-02 and tried to generate a dv .ts, with those settings:
https://drive.google.com/file/d/1ZTYpgK ... sp=sharing
But what came out is (no dv detected):
https://drive.google.com/file/d/103ylhd ... sp=sharing
What am I doing wrong?
try using tsmuxer(4.06 fix).rar from a few pages ago
4knewbie wrote: Thu Apr 23, 2020 9:26 am Does anyone know why some movies have a very light DV layer (usually under 100MB) and some others have a much larger one (~5-7 GB) ?
Yea, that's MEL vs FEL (minimal vs full enhancement layer). mel carries just the rpu metadata where fel carries the full 12-bit info (debatable if needed as nothing is 12 bit yet).
Sgt Hartman wrote: Thu Apr 23, 2020 12:07 pm So, I tried Saving Private Ryan with last MakeMKV, muxing with tsMuxer (profile 6 and 4). With 6 no video, only audio. With 4 same "blinking" effect both on Plex and MX Player, I really think it's a Shield issue.
you're using both latest apps? the latest plex beta breaks dv, so you need to use the version just before it.
Sgt Hartman
#2222 Post by Sgt Hartman » Thu Apr 23, 2020 1:36 pm
Grencola wrote: Thu Apr 23, 2020 1:14 pm
I used the latest official versions, about Plex both old and new exoplayer, same result. It's just that movie, for the others seems to work fine.
Grencola
#2223 Post by Grencola » Thu Apr 23, 2020 2:25 pm
Sgt Hartman wrote: Thu Apr 23, 2020 1:36 pm It's just that movie, for the others seems to work fine.
Ah, ok. Yea it's always a pain when there's an odd one out that doesn't work, yet your process is the same. it has a decently sized FEL (6mb/s) which is the only thing I can think of.
#2224 Post by shawnc22 » Thu Apr 23, 2020 3:17 pm
this is related to what I wrote here:
viewtopic.php?f=12&t=18602&start=2205#p88273
kazuma
#2225 Post by kazuma » Thu Apr 23, 2020 3:29 pm
where exacly? i can't find the tsmuxer 4.06 fix? what are the steps to do that with tsmuxer?
Sgt Hartman
#2226 Post by Sgt Hartman » Thu Apr 23, 2020 4:16 pm
shawnc22 wrote: Thu Apr 23, 2020 3:17 pm
Yep, that's right! I just would like to figure out a way to address this issue with that specific movie, it's just the only element of disturb so far.
jayper
#2227 Post by jayper » Thu Apr 23, 2020 11:57 pm
shawnc22 wrote: Thu Apr 23, 2020 2:39 am
mulucy wrote: Thu Apr 23, 2020 1:54 am
Grencola wrote: Wed Apr 22, 2020 11:16 pm
My tool is obsolete. it made a profile 7 dv mp4 with lossy ac3 audio from a .m2ts file to play on x700 etc. but now you can just throw that m2ts straight into tsmuxer and make a dv .ts file with lossless audio + atmos.
Just to clarify it, the steps include yusecope's tool to create a DV track, correct?
nope, the x700 is capable of playing the DV tracks as is. Just need to remux it in a ts container.
I've remuxed (TsMuxer 4.06 fix) MKVs created with MakeMKV 1.15.1 and I have not been able to get them to play on the Sony x700. I have tried via a USB drive, and via the DLNA player (Plex) and I have gotten a black screen in both cases. I have tried two separate Vision movies and it is the same experience both times. Anyone have luck?
#2228 Post by RESET_9999 » Fri Apr 24, 2020 12:10 am
jayper wrote: Thu Apr 23, 2020 11:57 pm I've remuxed (TsMuxer 4.06 fix) MKVs created with MakeMKV 1.15.1 and I have not been able to get them to play on the Sony x700. I have tried via a USB drive, and via the DLNA player (Plex) and I have gotten a black screen in both cases. I have tried two separate Vision movies and it is the same experience both times. Anyone have luck?
on the x700, only the MEL(small layer) DV movies will work using that method.
Just remux directly your uhd-bd to dual layer TS with atmos and subtitles. No need of makemkv with the x700
ragico
#2229 Post by ragico » Fri Apr 24, 2020 7:32 am
Someone knows how to demux the hevc files created with yusesope tool?
Grencola
#2230 Post by Grencola » Fri Apr 24, 2020 2:01 pm
ragico wrote: Fri Apr 24, 2020 7:32 am Someone knows how to demux the hevc files created with yusesope tool?
hevc is pretty well demuxed already. do you mean how to extract each individual .bmp file? you can grab some sw at gpac's github, but it would be around 1440 frames per hour @ 24p.
Hanto
#2231 Post by Hanto » Fri Apr 24, 2020 2:01 pm
Same problem on my Toshiba OLED TV when I use tsmuwer (no matter the version)
MP4 works fine so I think tsmuxer has a bug because even if I try just for test to remux a ts demo file that works on TV that doesn't works anymore.
box4m
#2232 Post by box4m » Fri Apr 24, 2020 3:20 pm
probably stupid question as usual but whats the goto application to do what tsmuxer does but with .mp4 as output?
#2233 Post by shawnc22 » Fri Apr 24, 2020 3:59 pm
box4m wrote: Fri Apr 24, 2020 3:20 pm probably stupid question as usual but whats the goto application to do what tsmuxer does but with .mp4 as output?
literally the title of this thread and the first post :)
tr000
#2234 Post by tr000 » Sat Apr 25, 2020 7:52 am
Grencola wrote: Fri Apr 24, 2020 2:01 pm
I think he just wants to separate the single file into the base layer and enhancement layer .hevcs. You should be able to do this by muxing the BL_EL_EPU.hevc file with MP4Muxer then using MP4Demuxer to get the BL and EL separately.
tr000
#2235 Post by tr000 » Sat Apr 25, 2020 8:05 am
tr000 wrote: Sat Apr 11, 2020 6:09 am So after 10+ hours of agonizing labor, Jumanji did not work through any method in mkv form or m2ts form. I will begrudgingly watch it in HDR10.
The thought was in the back of my head. That damned movie. The one that I spent ten hours trying to get to work a couple weeks ago. I gave up. I gave up for good. Or so, I thought. The idea kept nagging me, an endless ringing in the dark annals of my mind. In the midst of the chaos in the world I decided to download the Blu-Ray rip of the cursed film again, and set my laptop aside for two days as it dutifully downloaded the film.
Many more hours later...and, initially, the same result. Lovecraftian forms alternating in green and blue, with the "Dolby Vision" logo mocking me as the glint of the glitched playback glistened in my eye.
Damn ye! Let the tomb strike ye dead, Dolby Vision! Haaaaaark! Hark, Triton! Hark! Bellow, bid our father the sea king! Rise from the depths full foul in his fury! Black waves teeming with salt foam to smother this young mouth with pungent slime, to choke ye, engorging your organs till ye turn blue and bloated with builds and brine and can scream no more. Only when he, crowned in cockle shells, with slithering tentacle tail and steaming beard take up his fell be-finned arm, his coral tonged trident screeches banshee-like in the tempest, and PLUNGES right through yer gullet! Besting ye! A bulging blacker no more, but a blasted bloody film now a nothing for the harpies and the souls of dead sailors to peck and claw and feed upon only to be lapped up and swallowed by the infinite waters of the dread emperor himself. Forgotten to any man, to any time. Forgotten to any God or Devil, forgotten, even, to the sea. For any stuff or part of Dolby Vision, even any scantling of your 12-bit color depth is DV no more, but is now itself the sea!
An idea forms. Perhaps @yusesope's tool was the key...but in a different form. Surely it couldn't be. All files, whether taken straight from the .m2ts and muxed with MP4Muxer, or with DVDFab, or with the single hevc made by mode 2 of yusesope's tool invariably failed.
But....mode 1? No. A foolish thought. For a TV who only supports 4 and 5, what could mode 1 ever do? Still...worth a try. The -mode 2 flag is removed from the .bat. The tool laboriously muxes together the bl and el. Quick. NVMe. 5 minutes. No expectations. .\mp4muxer -i bl_el_rpu.hevc -i audio.ac3 --dv-profile 5.
No expectation. TV is turned on. File is navigated to.
Press Play.
DOLBY VISION
Sony Pictures Logo.
No.....could it be? Skip around the movie. Sanity check.
ITWORKED. IT FINALLY WORKED. I never thought I would see the day.
Success. At last.
