darrrkmanxxx
Post by darrrkmanxxx » Thu Apr 23, 2020 7:30 am
Grencola wrote: Wed Apr 22, 2020 11:16 pm
kazuma wrote: Wed Apr 22, 2020 10:23 pm @grencola, which profile uses your tool? or is this question irrelevant?
My tool is obsolete. it made a profile 7 dv mp4 with lossy ac3 audio from a .m2ts file to play on x700 etc. but now you can just throw that m2ts straight into tsmuxer and make a dv .ts file with lossless audio + atmos.
How did you achieved that? Do I need to tweak settings somewhere in tsMuxer? I used w64-nightly-2020-04-19--02-12-02 and tried to generate a dv .ts, with those settings:
https://drive.google.com/file/d/1ZTYpgK ... sp=sharing
But what came out is (no dv detected):
https://drive.google.com/file/d/103ylhd ... sp=sharing
What am I doing wrong?
4knewbie
Post by 4knewbie » Thu Apr 23, 2020 9:26 am
Does anyone know why some movies have a very light DV layer (usually under 100MB) and some others have a much larger one (~5-7 GB) ?
Sgt Hartman
Post by Sgt Hartman » Thu Apr 23, 2020 12:07 pm
So, I tried Saving Private Ryan with last MakeMKV, muxing with tsMuxer (profile 6 and 4). With 6 no video, only audio. With 4 same "blinking" effect both on Plex and MX Player, I really think it's a Shield issue.
Grencola
Post by Grencola » Thu Apr 23, 2020 1:14 pm
box4m wrote: Thu Apr 23, 2020 5:12 am edit: i tried it and seems like it created single layer hmm, is it "correct" or dvdfabmethod?
correct. the shield has its own weird color and stutter bugs etc, but all the dv info is retained. comparing the disc to the .ts on x700 is identical.
darrrkmanxxx wrote: Thu Apr 23, 2020 7:30 am
try using tsmuxer(4.06 fix).rar from a few pages ago
4knewbie wrote: Thu Apr 23, 2020 9:26 am Does anyone know why some movies have a very light DV layer (usually under 100MB) and some others have a much larger one (~5-7 GB) ?
Yea, that's MEL vs FEL (minimal vs full enhancement layer). mel carries just the rpu metadata where fel carries the full 12-bit info (debatable if needed as nothing is 12 bit yet).
Sgt Hartman wrote: Thu Apr 23, 2020 12:07 pm So, I tried Saving Private Ryan with last MakeMKV, muxing with tsMuxer (profile 6 and 4). With 6 no video, only audio. With 4 same "blinking" effect both on Plex and MX Player, I really think it's a Shield issue.
you're using both latest apps? the latest plex beta breaks dv, so you need to use the version just before it.
Sgt Hartman
Post by Sgt Hartman » Thu Apr 23, 2020 1:36 pm
Grencola wrote: Thu Apr 23, 2020 1:14 pm
I used the latest official versions, about Plex both old and new exoplayer, same result. It's just that movie, for the others seems to work fine.
Grencola
Post by Grencola » Thu Apr 23, 2020 2:25 pm
Sgt Hartman wrote: Thu Apr 23, 2020 1:36 pm It's just that movie, for the others seems to work fine.
Ah, ok. Yea it's always a pain when there's an odd one out that doesn't work, yet your process is the same. it has a decently sized FEL (6mb/s) which is the only thing I can think of.
Post by shawnc22 » Thu Apr 23, 2020 3:17 pm
this is related to what I wrote here:
viewtopic.php?f=12&t=18602&start=2205#p88273
kazuma
Post by kazuma » Thu Apr 23, 2020 3:29 pm
where exacly? i can't find the tsmuxer 4.06 fix? what are the steps to do that with tsmuxer?
Sgt Hartman
Post by Sgt Hartman » Thu Apr 23, 2020 4:16 pm
shawnc22 wrote: Thu Apr 23, 2020 3:17 pm
Yep, that's right! I just would like to figure out a way to address this issue with that specific movie, it's just the only element of disturb so far.
jayper
Post by jayper » Thu Apr 23, 2020 11:57 pm
shawnc22 wrote: Thu Apr 23, 2020 2:39 am
mulucy wrote: Thu Apr 23, 2020 1:54 am
Just to clarify it, the steps include yusecope's tool to create a DV track, correct?
nope, the x700 is capable of playing the DV tracks as is. Just need to remux it in a ts container.
I've remuxed (TsMuxer 4.06 fix) MKVs created with MakeMKV 1.15.1 and I have not been able to get them to play on the Sony x700. I have tried via a USB drive, and via the DLNA player (Plex) and I have gotten a black screen in both cases. I have tried two separate Vision movies and it is the same experience both times. Anyone have luck?
Post by RESET_9999 » Fri Apr 24, 2020 12:10 am
jayper wrote: Thu Apr 23, 2020 11:57 pm I've remuxed (TsMuxer 4.06 fix) MKVs created with MakeMKV 1.15.1 and I have not been able to get them to play on the Sony x700. I have tried via a USB drive, and via the DLNA player (Plex) and I have gotten a black screen in both cases. I have tried two separate Vision movies and it is the same experience both times. Anyone have luck?
on the x700, only the MEL(small layer) DV movies will work using that method.
Just remux directly your uhd-bd to dual layer TS with atmos and subtitles. No need of makemkv with the x700
ragico
Post by ragico » Fri Apr 24, 2020 7:32 am
Someone knows how to demux the hevc files created with yusesope tool?
Grencola
Post by Grencola » Fri Apr 24, 2020 2:01 pm
ragico wrote: Fri Apr 24, 2020 7:32 am Someone knows how to demux the hevc files created with yusesope tool?
hevc is pretty well demuxed already. do you mean how to extract each individual .bmp file? you can grab some sw at gpac's github, but it would be around 1440 frames per hour @ 24p.
Hanto
Post by Hanto » Fri Apr 24, 2020 2:01 pm
Same problem on my Toshiba OLED TV when I use tsmuwer (no matter the version)
MP4 works fine so I think tsmuxer has a bug because even if I try just for test to remux a ts demo file that works on TV that doesn't works anymore.
box4m
Post by box4m » Fri Apr 24, 2020 3:20 pm
probably stupid question as usual but whats the goto application to do what tsmuxer does but with .mp4 as output?
