Thank you for the response. I am assuming this approach is only good for Sony X700 since other players like Shield TV don't support profile 7. In that case, we need to use yusecope's tool. Correct me if I am wrong, please
you're both correct. however you can skip yusesope's tool if you rip your movie with the new makemkv (or dvdfab) first, before putting it through tsmuxer.
Sorry i dont understand that, how does new makemkv help in creating a single layer file?Grencola wrote: ↑Thu Apr 23, 2020 4:26 amyou're both correct. however you can skip yusesope's tool if you rip your movie with the new makemkv (or dvdfab) first, before putting it through tsmuxer.
edit: i tried it and seems like it created single layer hmm, is it "correct" or dvdfabmethod?
How did you achieved that? Do I need to tweak settings somewhere in tsMuxer? I used w64-nightly-2020-04-19--02-12-02 and tried to generate a dv .ts, with those settings:
https://drive.google.com/file/d/1ZTYpgK ... sp=sharing
But what came out is (no dv detected):
https://drive.google.com/file/d/103ylhd ... sp=sharing
What am I doing wrong?
Does anyone know why some movies have a very light DV layer (usually under 100MB) and some others have a much larger one (~5-7 GB) ?
So, I tried Saving Private Ryan with last MakeMKV, muxing with tsMuxer (profile 6 and 4). With 6 no video, only audio. With 4 same "blinking" effect both on Plex and MX Player, I really think it's a Shield issue.
correct. the shield has its own weird color and stutter bugs etc, but all the dv info is retained. comparing the disc to the .ts on x700 is identical.
try using tsmuxer(4.06 fix).rar from a few pages agodarrrkmanxxx wrote: ↑Thu Apr 23, 2020 7:30 am
Yea, that's MEL vs FEL (minimal vs full enhancement layer). mel carries just the rpu metadata where fel carries the full 12-bit info (debatable if needed as nothing is 12 bit yet).
you're using both latest apps? the latest plex beta breaks dv, so you need to use the version just before it.Sgt Hartman wrote: ↑Thu Apr 23, 2020 12:07 pmSo, I tried Saving Private Ryan with last MakeMKV, muxing with tsMuxer (profile 6 and 4). With 6 no video, only audio. With 4 same "blinking" effect both on Plex and MX Player, I really think it's a Shield issue.
I used the latest official versions, about Plex both old and new exoplayer, same result. It's just that movie, for the others seems to work fine.Grencola wrote: ↑Thu Apr 23, 2020 1:14 pmyou're using both latest apps? the latest plex beta breaks dv, so you need to use the version just before it.Sgt Hartman wrote: ↑Thu Apr 23, 2020 12:07 pmSo, I tried Saving Private Ryan with last MakeMKV, muxing with tsMuxer (profile 6 and 4). With 6 no video, only audio. With 4 same "blinking" effect both on Plex and MX Player, I really think it's a Shield issue.
Ah, ok. Yea it's always a pain when there's an odd one out that doesn't work, yet your process is the same. it has a decently sized FEL (6mb/s) which is the only thing I can think of.Sgt Hartman wrote: ↑Thu Apr 23, 2020 1:36 pmIt's just that movie, for the others seems to work fine.
this is related to what I wrote here:Sgt Hartman wrote: ↑Thu Apr 23, 2020 1:36 pmI used the latest official versions, about Plex both old and new exoplayer, same result. It's just that movie, for the others seems to work fine.Grencola wrote: ↑Thu Apr 23, 2020 1:14 pmyou're using both latest apps? the latest plex beta breaks dv, so you need to use the version just before it.Sgt Hartman wrote: ↑Thu Apr 23, 2020 12:07 pmSo, I tried Saving Private Ryan with last MakeMKV, muxing with tsMuxer (profile 6 and 4). With 6 no video, only audio. With 4 same "blinking" effect both on Plex and MX Player, I really think it's a Shield issue.
viewtopic.php?f=12&t=18602&start=2205#p88273
where exacly? i can't find the tsmuxer 4.06 fix? what are the steps to do that with tsmuxer?Grencola wrote: ↑Thu Apr 23, 2020 1:14 pmcorrect. the shield has its own weird color and stutter bugs etc, but all the dv info is retained. comparing the disc to the .ts on x700 is identical.try using tsmuxer(4.06 fix).rar from a few pages agodarrrkmanxxx wrote: ↑Thu Apr 23, 2020 7:30 am
What am I doing wrong?Yea, that's MEL vs FEL (minimal vs full enhancement layer). mel carries just the rpu metadata where fel carries the full 12-bit info (debatable if needed as nothing is 12 bit yet).you're using both latest apps? the latest plex beta breaks dv, so you need to use the version just before it.Sgt Hartman wrote: ↑Thu Apr 23, 2020 12:07 pmSo, I tried Saving Private Ryan with last MakeMKV, muxing with tsMuxer (profile 6 and 4). With 6 no video, only audio. With 4 same "blinking" effect both on Plex and MX Player, I really think it's a Shield issue.
Yep, that's right! I just would like to figure out a way to address this issue with that specific movie, it's just the only element of disturb so far.shawnc22 wrote: ↑Thu Apr 23, 2020 3:17 pmthis is related to what I wrote here:Sgt Hartman wrote: ↑Thu Apr 23, 2020 1:36 pmI used the latest official versions, about Plex both old and new exoplayer, same result. It's just that movie, for the others seems to work fine.
I've remuxed (TsMuxer 4.06 fix) MKVs created with MakeMKV 1.15.1 and I have not been able to get them to play on the Sony x700. I have tried via a USB drive, and via the DLNA player (Plex) and I have gotten a black screen in both cases. I have tried two separate Vision movies and it is the same experience both times. Anyone have luck?
on the x700, only the MEL(small layer) DV movies will work using that method.jayper wrote: ↑Thu Apr 23, 2020 11:57 pmI've remuxed (TsMuxer 4.06 fix) MKVs created with MakeMKV 1.15.1 and I have not been able to get them to play on the Sony x700. I have tried via a USB drive, and via the DLNA player (Plex) and I have gotten a black screen in both cases. I have tried two separate Vision movies and it is the same experience both times. Anyone have luck?
Just remux directly your uhd-bd to dual layer TS with atmos and subtitles. No need of makemkv with the x700
