Just Bought the Asus BC-12D1HT
nbat58
Post by nbat58 »
Hi all,
New here, I wonder if I have just made a big mistake in puchasing the Asus BC-12D1HT or is this drive still OK to convert via flashing to UHD friendly status, of course the firmware the drive will come with will make a big differenece.
What should I look for when I get the drive in terms of firmware and the next step to take, or should I just go and cancel my order and look for something else.
st4evr
Re: Just Bought the Asus BC-12D1HT
Post by st4evr »
It is not a very popular drive for this purpuse, but some have had luck with it:
https://www.makemkv.com/forum/search.ph ... rds=12D1HT
So, if you can instead get one of the recommended drives where you live, do so. Read the guide for those requirements.
https://www.makemkv.com/forum/viewtopic ... 16&t=19634
nbat58
Post by nbat58 »
Thank you for all your help St4evr, the drive has just been shipped and I just realised the drive I bought was the BC-12D2HT and not the BC-12D1HT, not sure whether this makes any difference or not but I going to do some reading on this drive and flash it once I know which original firmware it contains.
nbat58 wrote:
Tue Apr 21, 2020 7:05 pm
The BC-12D2HT should come with 3.11. Just flash it with BC-12D2HT 3.11-MK and you will be good to go!
nbat58
Post by nbat58 »
Brilliant, thank you for the good news.
nbat58
Post by nbat58 »
unfortunately it looks like my drive is older, manufactured in December 2017 and came with firmware version 3.01 (see below).
Manufacturer: ASUS
Product: BC-12D2HT
Revision: 3.01
Serial number: K9BI1292407
Firmware date: 2117-11-15 19:26
Bus encryption flags: 1E
Harware support: Yes
Firmware support: No
Firmware version: 3.01
will this work OK and a keeper or should I send it back for another UHD friendly drive?
If it's a keeper, which is the best firware for it? the 3.01MK or is it flashable with the 3.11MK? or is it best kept as is?
Many thanks
nbat58 wrote:
Fri Apr 24, 2020 5:11 pm
Manufacturer: ASUS
Product: BC-12D2HT
Revision: 3.01
Many thanks
Yep, go with the 3.01-MK from the "MK\old" folder. That should do the trick!
nbat58
Post by nbat58 »
Thanks, is it advisable to make a copy and dump the original firmware of the drive or is this no longer necessary?
If it's still required (for safe keeping just in case) what utility should I use to do this? is Dosflash still the tool to do this or can it be done with the modified Asus ODD FW Changer?
nbat58 wrote:
Sat Apr 25, 2020 10:38 am
no longer necessary
nbat58
Post by nbat58 »
Thank you, are there other firmware versions that will work with this drive or is the 3.01MK the best to use?
nbat58 wrote:
Sat Apr 25, 2020 6:10 pm
It is best to NOT cross-flash this model drive. All sorts of issues have arisen before. You could try the 3.11-MK but if it is already working for you on 3.01-MK, I'd leave it alone.
nbat58
Post by nbat58 »
I haven't flashed my drive yet, I am just making sure I got everything right before going ahead and flashing it, I have noticed a DE firmware file version 3.00 in the the firmware pack what are the benefits of DE firmwares?
nbat58 wrote:
Sun Apr 26, 2020 10:45 am
The DE firmwares are the standard firmwares with just one byte changed to "DE" which re-enables firmware downgrading.
nbat58
Post by nbat58 »
Thank you for the explanation, I appreciate all your help, I am going to flash the 3.01-MK now.
nbat58
Post by nbat58 »
Thank you all for your help.
Manufacturer: ASUS
Product: BC-12D2HT
Revision: 3.01
