UHD Friendly Drive techPulsel20 = BD-RE BU40N
hutchy71
Post by hutchy71 » Mon Apr 20, 2020 4:35 pm
I bought the external UHD-drive mentioned in the subject in Germany and would like to flash it UHD reader-friendly and preferably on a Linux system, Ubuntu 19.04, if necessary I would also have a Windows 10 to run.
Now the turorials here - at least for me - are quite confusing. Can someone explain in simple steps how I can achieve my goal. I would be very grateful to you for that !!!
I enclose pictures of the drive and the installed firmware:
st4evr
Re: UHD Friendly Drive techPulsel20 = BD-RE BU40N
Post by st4evr » Mon Apr 20, 2020 7:36 pm
You can contact members who provide these types of one-on-one services here:
https://www.makemkv.com/forum/viewforum.php?f=20
One of several discussions on Linux native flashing can be found here:
https://www.makemkv.com/forum/viewtopic ... inux+flash
And did you review the step-by-step video guide linked in this post where Billy walks the viewer through each step in a Windows environment?
https://www.makemkv.com/forum/viewtopic ... 16&t=19634
hutchy71
Post by hutchy71 » Mon Apr 20, 2020 9:34 pm
I found my way, it was easy, used a Windows 10 system:
Download the windows tool
BH14NS40_N1.00-A4_patched.exe
install it und - in my case - flash with the firmware
DE_LG BU40N_1.00.bin
et voila ...it works.
Remember not to install makemkv via snap.
Useing Ubuntu 19.04, open terminal:
sudo add-apt-repository ppa:heyarje/makemkv-beta
sudo apt-get update
sudo apt-get install makemkv-bin makemkv-oss
Hope that helps you. Good luck!
