I think all my .ts doesn't work because [ HDR10 compatible / SMPTE ST 2086 ] or [ Blu-ray compatible / SMPTE ST 2086, HDR10 compatible ] on hevc file.
I've tried lot of DV profile fot .ts file but nothing works :
- dvhe.04.06 BL+EL+RPU
- dvhe.05.06 BL+RPU
- dvhe.06.06 BL+EL+RPU
- dvhe.08.06 BL+EL+RPU
- dvhe.04.06 EL+RPU
- dvhe.06.06 EL+RPU
- dvhe.07.05 EL+RPU
- dvhe.07.06 EL+RPU
- dvhe.08.03 BL+RPU
I don't understand because lot of .mp4 on DV Profile 4, 5 or 6 works well on my TV, even in double track double layer with HDR10 compatible / SMPTE ST 2086.
Mp4 DV profile 7 doesn't works and DV Profile 8 only in HDR not DV.
Do you know a way to remove [ HDR10 compatible / SMPTE ST 2086 ] or [ Blu-ray compatible / SMPTE ST 2086, HDR10 compatible ] on .ts file ?
I will go crazy lol
kazuma
a noob question:
what is the fastest/easiest way to convert a dts-hd sound file to ac3? which program needed?
Grencola
download eac3to: https://www.videohelp.com/download/eac3to334.zipkazuma wrote: Sun Apr 19, 2020 10:30 pm a noob question:
extract it to your dts folder
run a cmd prompt from there
type:
eac3to.exe input.dts output.ac3 -libav-
tr000
Also a GUI available for those scared of cmd https://www.videohelp.com/software/eac3toGrencola wrote: Mon Apr 20, 2020 3:30 amdownload eac3to: https://www.videohelp.com/download/eac3to334.zipkazuma wrote: Sun Apr 19, 2020 10:30 pm a noob question:
type:Code: Select all
deadchip12
Disney+ is not available in my country so I download this remux to watch The Mandalorian: https://rarbgway.org/torrent/rw213am. This looks like dolby vision single layer mp4? I have had hard time trying to get this to play on my oled c9. I put the film files in an external hdd and connected it to the c9 via usb. At first, the files seemed to play ok, but once I skipped to another point in the film it refused to play and showed message: "the file can't be recognized". Now that message is shown everytime I try to open the files so I can't even play the film anymore. Any idea? The TV did recognize the files at first so it's really weird that it does not recognize the files now anymore. The files are not corrupted btw, I tested them on my computer and they play fine, only without dolby vision.
Grencola
not sure in your situation, sounds like a tv issue-maybe because of the prof 5.06? people say it plays great on the shield and atv4 (and probably fire tv-I'll test tonight). also-not to hijack your post or anything - but seeing this, I feel like compressed x265's could still work in dolby vision (read a while back that x265 now supported dv), and those saying nope it has to be the full lossless video track were misinformed. I should have tested it myself but I just went along believing it. the 30-ish GB x265's you get when you compress a full disc (and leave audio alone) look fantastic still and save you a ton of space! I might do up a few and try to keep dv and compare some before/after screens to see if dv color profile is properly retained etc.deadchip12 wrote: Mon Apr 20, 2020 5:15 am Disney+ is not available in my country so I download this remux to watch The Mandalorian: https://rarbgway.org/torrent/rw213am. This looks like dolby vision single layer mp4? I have had hard time trying to get this to play on my oled c9. I put the film files in an external hdd and connected it to the c9 via usb. At first, the files seemed to play ok, but once I skipped to another point in the film it refused to play and showed message: "the file can't be recognized". Now that message is shown everytime I try to open the files so I can't even play the film anymore. Any idea? The TV did recognize the files at first so it's really weird that it does not recognize the files now anymore. The files are not corrupted btw, I tested them on my computer and they play fine, only without dolby vision.
deadchip12
Sorry what do you mean by prof 5.06?Grencola wrote: Mon Apr 20, 2020 2:14 pmnot sure in your situation, sounds like a tv issue-maybe because of the prof 5.06? people say it plays great on the shield and atv4 (and probably fire tv-I'll test tonight). also-not to hijack your post or anything - but seeing this, I feel like compressed x265's could still work in dolby vision (read a while back that x265 now supported dv), and those saying nope it has to be the full lossless video track were misinformed. I should have tested it myself but I just went along believing it. the 30-ish GB x265's you get when you compress a full disc (and leave audio alone) look fantastic still and save you a ton of space! I might do up a few and try to keep dv and compare some before/after screens to see if dv color profile is properly retained etc.deadchip12 wrote: Mon Apr 20, 2020 5:15 am Disney+ is not available in my country so I download this remux to watch The Mandalorian: https://rarbgway.org/torrent/rw213am. This looks like dolby vision single layer mp4? I have had hard time trying to get this to play on my oled c9. I put the film files in an external hdd and connected it to the c9 via usb. At first, the files seemed to play ok, but once I skipped to another point in the film it refused to play and showed message: "the file can't be recognized". Now that message is shown everytime I try to open the files so I can't even play the film anymore. Any idea? The TV did recognize the files at first so it's really weird that it does not recognize the files now anymore. The files are not corrupted btw, I tested them on my computer and they play fine, only without dolby vision.
darrrkmanxxx
haha, thanks for showing me. You know what sucks, this:Grencola wrote: Wed Apr 15, 2020 7:17 pmwatch this magic happen when I try the apk on my phone: https://youtu.be/3qIHyLHtcEUdarrrkmanxxx wrote: Wed Apr 15, 2020 7:32 am The 1.21.2 beta was the suggested version from the provided link with SMB in the changelog!
However, I tried 2.8.0 directly from Playstore and there's also no such thing as 'Local Network', there's only a bunch of useless added crap
See for yourself:
https://drive.google.com/file/d/1-hePke ... sp=sharing
I've also tried on different devices...
just gotta wait til the tablet/tv version gets updated.
https://drive.google.com/file/d/1KyMUYa ... sp=sharing
just look at this sh**. On my pc it say, that it isn't compatible, even with my OP6T!
Not sure if it's allowed to post pirated content links here but i did a TS remux with subtitles from that release and it plays great on my x700. I also tested playback on the Shield and the C8. no issue at all.deadchip12 wrote: Mon Apr 20, 2020 5:15 am Disney+ is not available in my country so I download this remux to watch The Mandalorian: . This looks like dolby vision single layer mp4? I have had hard time trying to get this to play on my oled c9. I put the film files in an external hdd and connected it to the c9 via usb. At first, the files seemed to play ok, but once I skipped to another point in the film it refused to play and showed message: "the file can't be recognized". Now that message is shown everytime I try to open the files so I can't even play the film anymore. Any idea? The TV did recognize the files at first so it's really weird that it does not recognize the files now anymore. The files are not corrupted btw, I tested them on my computer and they play fine, only without dolby vision.
I also muxed the Star Wars New Hope profile 05.06 DV web-dl with TrueHD Atmos. Works perfectly everywhere I tested playback.
deadchip12
Ah ok so we need to make a ts remux out of this to be able to play on the oled internal player? Because currently the original files are .mp4RESET_9999 wrote: Mon Apr 20, 2020 4:18 pmNot sure if it's allowed to post pirated content links here but i did a TS remux with subtitles from that release and it plays great on my x700. I also tested playback on the Shield and the C8. no issue at all.deadchip12 wrote: Mon Apr 20, 2020 5:15 am Disney+ is not available in my country so I download this remux to watch The Mandalorian: . This looks like dolby vision single layer mp4? I have had hard time trying to get this to play on my oled c9. I put the film files in an external hdd and connected it to the c9 via usb. At first, the files seemed to play ok, but once I skipped to another point in the film it refused to play and showed message: "the file can't be recognized". Now that message is shown everytime I try to open the files so I can't even play the film anymore. Any idea? The TV did recognize the files at first so it's really weird that it does not recognize the files now anymore. The files are not corrupted btw, I tested them on my computer and they play fine, only without dolby vision.
Edit: i tried ts remuxing it but same thing. The file refuses to play. Could you show me the steps how you do it?
Nothing special, I just added the mp4 and subtitles into tsmuxer.
But i read on the doom9 forum that someone else with a C9 struggle playing the TS sample file from the mandalorian. Another user with a C6 said there was no issue playing it.
So since my c8 also work, it sounds like something is different on the C9 internal player
https://forum.doom9.org/showthread.php? ... ost1906702
Grencola
I think it's your tv, bud. I 'tested' it (I have Disney+) on the firestick 4k and it plays in mx player and it looks great, but stutters due to mx player's lack of frame rate switchingdeadchip12 wrote: Mon Apr 20, 2020 5:21 pm I tried ts remuxing it but same thing. The file refuses to play. Could you show me the steps how you do it?
deadchip12
What tv do you have?Grencola wrote: Tue Apr 21, 2020 3:10 amI think it's your tv, bud. I 'tested' it (I have Disney+) on the firestick 4k and it plays in mx player and it looks great, but stutters due to mx player's lack of frame rate switchingdeadchip12 wrote: Mon Apr 20, 2020 5:21 pm I tried ts remuxing it but same thing. The file refuses to play. Could you show me the steps how you do it?![]()
deadchip12
yeah I downloaded that TS sample file and it refused to play on my C9. On your C8 it plays fine? Are you able to skip to other points in the film?RESET_9999 wrote: Mon Apr 20, 2020 7:03 pmNothing special, I just added the mp4 and subtitles into tsmuxer.
daddy
I tryed the Mandolorian 05.06 BL+RPU sample on C7, it plays fine and i m able to skip to other points in the sample.deadchip12 wrote: Tue Apr 21, 2020 5:15 amyeah I downloaded that TS sample file and it refused to play on my C9. On your C8 it plays fine? Are you able to skip to other points in the film?RESET_9999 wrote: Mon Apr 20, 2020 7:03 pmNothing special, I just added the mp4 and subtitles into tsmuxer.
