Mike said that's already being done. It's creating an interleaved thd/ac3 track in the MKV. It's just that at the moment tsmuxer doesn't recognize it when we try to remux, but, in the MKV, it's there.DaMacFunkin wrote: ↑Thu Apr 16, 2020 6:18 pm
In MKV is it possible to retain ac3 core in Atmos for greater compatabillity?
deadchip12
Does anyone watch dolby vision remuxes on oled and notice some kind of distortion line running continously across the screen during dark scenes? It’s almost like this: https://youtu.be/eJmicmxGdkM (go to 0:29 mark) but way darker and noticeable in a pitch dark room. Yesterday I watched 1917 and this was very evident during dark scenes. I remember seeing the same issue in some other films as well. Is it caused by the remux, the oled or the film itself?
The OLED https://www.rtings.com/tv/discussions/E ... ode-odditydeadchip12 wrote: ↑Fri Apr 17, 2020 8:22 pmDoes anyone watch dolby vision remuxes on oled and notice some kind of distortion line running continously across the screen during dark scenes? It’s almost like this: https://youtu.be/eJmicmxGdkM (go to 0:29 mark) but way darker and noticeable in a pitch dark room. Yesterday I watched 1917 and this was very evident during dark scenes. I remember seeing the same issue in some other films as well. Is it caused by the remux, the oled or the film itself?
- Contact:
No, I was wrong, or rather I didn't mean it that way. If you extract both TrueHD plus eac3 core, you get two separate tracks in MKV. If TrueHD only - then you get TrueHD only (with Atmos metadata if it was there).
If you want to retain eac3 core, then you have to select it.
What I'm saying, that there is no need for tsmuxer to require eac3 core to begin with. In the worst case, if a 100% compatibility is required, one could always "create" eac3 core from TrueHD, with ffmpeg or any other tool. That core will not have Atmos metadata, but it is discarded by decoder anyway.
There is fundamental differecnce between DTS-HD and TrueHD.
In DTS, the HD layer is extension, you need to have core+hd extension to decode audio.
TrueHD is self-contained codec, eac3 is present on blu-ray only as a fallback. You can mux in a silent eac3 track or leave it empty -- providing you have setup for TrueHD, the player would discard eac3 stream and use TrueHD part only.
So, to preserve the full compatibility one just have to check both streams - truehd and eac3. As for re-encoding to m2ts, MakeMKV uses a tag called a "source id" (now picked up by mediainfo and other software). If two tracks in MKV file have the same source id, then it means that these tracks come from the same source track and have the same content in different encoding. There is nothing that prevents tsmuxer (or any other tool) to recognize two separate tracks this way and join them together. This is what I meant by tsmuxer limitation.
Ah, I got it now. Thanks for the detailed explanation. In my case I've just been creating a THD+AC3 track from the TrueHD track in the MKV and then adding that track into TSMuxer for output to TS. This has worked on every title I've tried so far which is a fair amount. But yes, in the beginning I was extracting the core AC3 as a separate track but I stopped doing that because it wasn't getting picked up anyway. Now I understand you're saying that the extra AC3 track COULD be picked up and interleaved for TS but isn't. That makes sense.mike admin wrote: ↑Fri Apr 17, 2020 9:30 pmNo, I was wrong, or rather I didn't mean it that way. If you extract both TrueHD plus eac3 core, you get two separate tracks in MKV. If TrueHD only - then you get TrueHD only (with Atmos metadata if it was there).
deadchip12
Sorry but this is not the issue I’m talking aboutBillycar11 wrote: ↑Fri Apr 17, 2020 9:01 pmThe OLED https://www.rtings.com/tv/discussions/E ... ode-odditydeadchip12 wrote: ↑Fri Apr 17, 2020 8:22 pmDoes anyone watch dolby vision remuxes on oled and notice some kind of distortion line running continously across the screen during dark scenes? It’s almost like this: https://youtu.be/eJmicmxGdkM (go to 0:29 mark) but way darker and noticeable in a pitch dark room. Yesterday I watched 1917 and this was very evident during dark scenes. I remember seeing the same issue in some other films as well. Is it caused by the remux, the oled or the film itself?
I think I've found the problem but impossible to resolve.Hanto wrote: ↑Thu Apr 16, 2020 3:26 pmHello my friends.
Excuse my poor English, I'm French
I have read all 144 pages and still have same problem : my TV play well .mp4 DV but not my .ts of the same source.
Source is Alita DV teaser demo.mp4 and my TV don't play it.
So, I've demuxed BL.hevc and EL.hevc then remuxed in .mp4 forced DV Profile 4 with mp4muxer and this one play fine on my tv. (EL : Dolby Vision, Version 1.0, dvhe.04.06, EL+RPU, SDR compatible / SMPTE ST 2086, HDR10 compatible)
I also tried with yusescope V3 rev1 tool then remuxed in .mp4 forced DV Profile 4 with mp4muxer and this one play fine too. (Dolby Vision, Version 1.0, dvhe.04.06, BL+EL+RPU, SDR compatible / SMPTE ST 2086, HDR10 compatible)
Works fine with forced DV Profile 5 too, but not in yusescope V3 rev1 tool -mode 2 : Black screen
But file .ts made with tsmuxer with the same BL and EL don't work on my TV. (Video format not supported)
I don't understand. I've tried lot of tsmuxer version (edited,04.06 fix, patched, nightly...)
I don't understand because I've a lot of LG DV demo .ts (dvhe.04.06 BL+EL+RPU) that work on my TV.
For .mp4 files only DV Profile 4 and 5 can work, not 7 or 8. Can't try Profile 6 don't have found the good mp4muxer for.
And for .ts files made with tsmuxer, none of them work, and I can't have dvhe 04.06 with dual layer, only 07.05.
If anyone know what's the problem and help please ?
Thank you a lot guys
Source Dual Layer .mp4 DV Profile 7 : doesn't workDual Layer MP4 Forced DV Profile 4 with mp4muxer : WorksCode: Select all
Général Nom complet : E:\Alita Original.mp4 Format : MPEG-4 Profil du format : Base Media / Version 2 Identifiant du codec : mp42 (mp42/dby1/isom) Taille du fichier : 277 Mio Durée : 40s 97 ms Débit global moyen : 57,9 Mb/s Date d'encodage : UTC 2019-07-17 08:39:57 Date de marquage : UTC 2019-07-17 08:39:57 Vidéo #1 ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Profil du format : Main 10@L5.1@High HDR format : SMPTE ST 2086, HDR10 compatible Identifiant du codec : hev1 Identifiant du codec/Info : High Efficiency Video Coding Durée : 40s 82 ms Débit : 55,2 Mb/s Largeur : 3 840 pixels Hauteur : 2 160 pixels Format à l'écran : 16/9 Type d'images/s : Constant Images par seconde : 23,976 (24000/1001) Im/s Espace de couleurs : YUV Sous-échantillonnage de la chrominance : 4:2:0 (Type 2) Profondeur des couleurs : 10 bits Bits/(Pixel*Image) : 0.277 Taille du flux : 264 Mio (95%) Default : Non Date d'encodage : UTC 2019-07-17 08:39:57 Date de marquage : UTC 2019-07-17 08:39:57 Gamme de couleurs : Limited Coordonnées de chromaticité : BT.2020 Caractéristiques du transfert : PQ Coefficients de la matrice : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2 Maximum Content Light Level : 443 cd/m2 Maximum Frame-Average Light Level : 47 cd/m2 Codec configuration box : hvcC Vidéo #2 ID : 2 Format : HEVC Format/Info : High Efficiency Video Coding Profil du format : Main 10@L5.1@High HDR format : Dolby Vision, Version 1.0, dvhe.07.06, EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible Identifiant du codec : dvhe Identifiant du codec/Info : High Efficiency Video Coding with Dolby Vision Durée : 40s 82 ms Débit : 2 120 kb/s Largeur : 1 920 pixels Hauteur : 1 080 pixels Format à l'écran : 16/9 Type d'images/s : Constant Images par seconde : 23,976 (24000/1001) Im/s Espace de couleurs : YUV Sous-échantillonnage de la chrominance : 4:2:0 (Type 2) Profondeur des couleurs : 10 bits Bits/(Pixel*Image) : 0.043 Taille du flux : 10,1 Mio (4%) Default : Non Date d'encodage : UTC 2019-07-17 08:39:57 Date de marquage : UTC 2019-07-17 08:39:57 Gamme de couleurs : Limited Coordonnées de chromaticité : BT.2020 Caractéristiques du transfert : PQ Coefficients de la matrice : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2 Codec configuration box : hvcC+dvcC Audio ID : 3 Format : AC-3 Format/Info : Audio Coding 3 Nom commercial : Dolby Digital Identifiant du codec : ac-3 Durée : 40s 97 ms Type de débit : Constant Débit : 640 kb/s Canaux : 6 canaux Channel layout : L R C LFE Ls Rs Echantillonnage : 48,0 kHz Images par seconde : 31,250 Im/s (1536 SPF) Mode de compression : Avec perte Taille du flux : 3,06 Mio (1%) Langue : Français Service kind : Complete Main Default : Non Date d'encodage : UTC 2019-07-17 08:39:57 Date de marquage : UTC 2019-07-17 08:39:57
Single Layer MP4 Forced DV Profile 4 with yusescope V3 rev1 tool mp4muxer : Works and DV Profile 5 works too.Code: Select all
Nom complet : E:\DLP4.mp4 Format : MPEG-4 Profil du format : Base Media / Version 2 Identifiant du codec : mp42 (mp42/dby1/isom) Taille du fichier : 274 Mio Durée : 40s 82 ms Débit global moyen : 57,3 Mb/s Date d'encodage : UTC 2020-04-16 12:42:04 Date de marquage : UTC 2020-04-16 12:42:04 Vidéo #1 ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Profil du format : Main 10@L5.1@High HDR format : SMPTE ST 2086, HDR10 compatible Identifiant du codec : hev1 Identifiant du codec/Info : High Efficiency Video Coding Durée : 40s 82 ms Débit : 55,2 Mb/s Largeur : 3 840 pixels Hauteur : 2 160 pixels Format à l'écran : 16/9 Type d'images/s : Constant Images par seconde : 23,976 (24000/1001) Im/s Espace de couleurs : YUV Sous-échantillonnage de la chrominance : 4:2:0 (Type 2) Profondeur des couleurs : 10 bits Bits/(Pixel*Image) : 0.277 Taille du flux : 264 Mio (96%) Default : Oui Alternate group : 1 Date d'encodage : UTC 2020-04-16 12:42:04 Date de marquage : UTC 2020-04-16 12:42:04 Gamme de couleurs : Limited Coordonnées de chromaticité : BT.2020 Caractéristiques du transfert : PQ Coefficients de la matrice : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2 Maximum Content Light Level : 443 cd/m2 Maximum Frame-Average Light Level : 47 cd/m2 Codec configuration box : hvcC Vidéo #2 ID : 2 Format : HEVC Format/Info : High Efficiency Video Coding Profil du format : Main 10@L5.1@High HDR format : Dolby Vision, Version 1.0, dvhe.04.06, EL+RPU, SDR compatible / SMPTE ST 2086, HDR10 compatible Identifiant du codec : hev1 Identifiant du codec/Info : High Efficiency Video Coding Durée : 40s 82 ms Débit : 2 120 kb/s Largeur : 1 920 pixels Hauteur : 1 080 pixels Format à l'écran : 16/9 Type d'images/s : Constant Images par seconde : 23,976 (24000/1001) Im/s Espace de couleurs : YUV Sous-échantillonnage de la chrominance : 4:2:0 (Type 2) Profondeur des couleurs : 10 bits Bits/(Pixel*Image) : 0.043 Taille du flux : 10,1 Mio (4%) Default : Non Alternate group : 1 Date d'encodage : UTC 2020-04-16 12:42:04 Date de marquage : UTC 2020-04-16 12:42:04 Gamme de couleurs : Limited Coordonnées de chromaticité : BT.2020 Caractéristiques du transfert : PQ Coefficients de la matrice : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2 Codec configuration box : hvcC+dvcC
Single Layer .ts Profile 4 (dvhe 04 06) : Doesn't workCode: Select all
Général Nom complet : E:\P4.mp4 Format : MPEG-4 Profil du format : Base Media / Version 2 Identifiant du codec : mp42 (mp42/dby1/isom) Taille du fichier : 274 Mio Durée : 40s 82 ms Débit global moyen : 57,3 Mb/s Date d'encodage : UTC 2020-04-16 08:25:14 Date de marquage : UTC 2020-04-16 08:25:14 Vidéo ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Profil du format : Main 10@L5.1@High HDR format : Dolby Vision, Version 1.0, dvhe.04.06, BL+EL+RPU, SDR compatible / SMPTE ST 2086, HDR10 compatible Identifiant du codec : hev1 Identifiant du codec/Info : High Efficiency Video Coding Durée : 40s 82 ms Débit : 57,3 Mb/s Largeur : 3 840 pixels Hauteur : 2 160 pixels Format à l'écran : 16/9 Type d'images/s : Constant Images par seconde : 23,976 (24000/1001) Im/s Espace de couleurs : YUV Sous-échantillonnage de la chrominance : 4:2:0 (Type 2) Profondeur des couleurs : 10 bits Bits/(Pixel*Image) : 0.288 Taille du flux : 274 Mio (100%) Default : Oui Alternate group : 1 Date d'encodage : UTC 2020-04-16 08:25:14 Date de marquage : UTC 2020-04-16 08:25:14 Gamme de couleurs : Limited Coordonnées de chromaticité : BT.2020 Caractéristiques du transfert : PQ Coefficients de la matrice : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2 Maximum Content Light Level : 443 cd/m2 Maximum Frame-Average Light Level : 47 cd/m2 Codec configuration box : hvcC+dvcC+hvcE
Dual layer DV Profile 7 : Doesn't work, can't have DV Profile 4Code: Select all
Général ID : 1 (0x1) Nom complet : E:\P4.ts Format : MPEG-TS Taille du fichier : 280 Mio Durée : 39s 957 ms Type de débit global : Variable Débit global moyen : 58,6 Mb/s Débit global maximum : 35,5 Mb/s Vidéo ID : 4117 (0x1015) ID de menu : 1 (0x1) Format : HEVC Format/Info : High Efficiency Video Coding Profil du format : Main 10@L5.1@High HDR format : Dolby Vision, Version 1.0, dvhe.04.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible Identifiant du codec : 36 Durée : 40s 40 ms Débit : 55,7 Mb/s Largeur : 3 840 pixels Hauteur : 2 160 pixels Format à l'écran : 16/9 Images par seconde : 23,976 (24000/1001) Im/s Espace de couleurs : YUV Sous-échantillonnage de la chrominance : 4:2:0 (Type 2) Profondeur des couleurs : 10 bits Bits/(Pixel*Image) : 0.280 Taille du flux : 266 Mio (95%) Gamme de couleurs : Limited Coordonnées de chromaticité : BT.2020 Caractéristiques du transfert : PQ Coefficients de la matrice : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2 Maximum Content Light Level : 443 cd/m2 Maximum Frame-Average Light Level : 47 cd/m2
LG DV demo .ts Profile 4 : WorksCode: Select all
Général ID : 1 (0x1) Nom complet : E:\P4DL.ts Format : MPEG-TS Taille du fichier : 280 Mio Durée : 39s 957 ms Type de débit global : Variable Débit global moyen : 58,6 Mb/s Débit global maximum : 35,5 Mb/s Vidéo #1 ID : 4113 (0x1011) ID de menu : 1 (0x1) Format : HEVC Format/Info : High Efficiency Video Coding Profil du format : Main 10@L5.1@High HDR format : SMPTE ST 2086, HDR10 compatible Identifiant du codec : 36 Durée : 40s 40 ms Largeur : 3 840 pixels Hauteur : 2 160 pixels Format à l'écran : 16/9 Images par seconde : 23,976 (24000/1001) Im/s Espace de couleurs : YUV Sous-échantillonnage de la chrominance : 4:2:0 (Type 2) Profondeur des couleurs : 10 bits Gamme de couleurs : Limited Coordonnées de chromaticité : BT.2020 Caractéristiques du transfert : PQ Coefficients de la matrice : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2 Maximum Content Light Level : 443 cd/m2 Maximum Frame-Average Light Level : 47 cd/m2 Vidéo #2 ID : 4117 (0x1015) ID de menu : 1 (0x1) Format : HEVC Format/Info : High Efficiency Video Coding Profil du format : Main 10@L5.1@High HDR format : Dolby Vision, Version 1.0, dvhe.07.05, EL+RPU, 8 compatible / SMPTE ST 2086, HDR10 compatible Identifiant du codec : 36 Durée : 40s 40 ms Largeur : 1 920 pixels Hauteur : 1 080 pixels Format à l'écran : 16/9 Images par seconde : 23,976 (24000/1001) Im/s Espace de couleurs : YUV Sous-échantillonnage de la chrominance : 4:2:0 (Type 2) Profondeur des couleurs : 10 bits Gamme de couleurs : Limited Coordonnées de chromaticité : BT.2020 Caractéristiques du transfert : PQ Coefficients de la matrice : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Général ID : 1 (0x1) Nom complet : E:\LG Dolby Trailer 4K Demo.ts Format : MPEG-TS Taille du fichier : 308 Mio Durée : 1 min 20s Type de débit global : Constant Débit global moyen : 31,9 Mb/s Vidéo ID : 33 (0x21) ID de menu : 2 (0x2) Format : HEVC Format/Info : High Efficiency Video Coding Profil du format : Main 10@L5@Main HDR format : Dolby Vision, Version 1.0, dvhe.04.06, BL+EL+RPU Identifiant du codec : 36 Durée : 1 min 19s Débit : 29,6 Mb/s Largeur : 3 840 pixels Hauteur : 2 160 pixels Format à l'écran : 16/9 Images par seconde : 23,976 (24000/1001) Im/s Espace de couleurs : YUV Sous-échantillonnage de la chrominance : 4:2:0 Profondeur des couleurs : 10 bits Bits/(Pixel*Image) : 0.149 Taille du flux : 282 Mio (92%) Audio ID : 35 (0x23) ID de menu : 2 (0x2) Format : E-AC-3 Format/Info : Enhanced AC-3 Nom commercial : Dolby Digital Plus Identifiant du codec : 135 Durée : 1 min 20s Type de débit : Constant Débit : 768 kb/s Canaux : 6 canaux Channel layout : L R C LFE Ls Rs Echantillonnage : 48,0 kHz Images par seconde : 31,250 Im/s (1536 SPF) Mode de compression : Avec perte Délai par rapport Vidéo : -948 ms Taille du flux : 7,41 Mio (2%) Service kind : Complete Main
I think the problem is TSMUXER, I've tried a lot of version and same problem evrytime :
This file .ts source works well on my TV :
But when I remux this same file on TSMUXER juste for test, result doesn't work anymore.Général
Format : MPEG-TS
Durée : 1 min 20s
Vidéo
Format : HEVC
Durée : 1 min 19s
Débit : 29,6 Mb/s
Audio
Format : E-AC-3
Durée : 1 min 20s
Débit : 768 kb/s
Canaux : 6 canaux
New .ts file is smaller and many information are lost :
I think is the same problem when I try to convert .mp4 files to .ts with tsmuxer.Général
Nom complet : E:\LG Dolby Trailer 4K Demo2.ts
Format : MPEG-TS
Taille du fichier : 247 Mio
Durée : 1 min 20s
Débit global moyen : 25,6 Mb/s
Vidéo
Format : HEVC
Durée : 1 min 19s
Débit : 23,6 Mb/s
Taille du flux : 224 Mio (91%)
Audio
Format : E-AC-3
Durée : 1 min 20s
Débit : 768 kb/s
Canaux : 6 canaux
Taille du flux : 7,41 Mio (3%)
If you know what is the problem and if somebody can help me please it would be most appreciate.
Thank you a lot
I think all my .ts doesn't work because [ HDR10 compatible / SMPTE ST 2086 ] or [ Blu-ray compatible / SMPTE ST 2086, HDR10 compatible ] on hevc file.
I've tried lot of DV profile fot .ts file but nothing works :
- dvhe.04.06 BL+EL+RPU
- dvhe.05.06 BL+RPU
- dvhe.06.06 BL+EL+RPU
- dvhe.08.06 BL+EL+RPU
- dvhe.04.06 EL+RPU
- dvhe.06.06 EL+RPU
- dvhe.07.05 EL+RPU
- dvhe.07.06 EL+RPU
- dvhe.08.03 BL+RPU
I don't understand because lot of .mp4 on DV Profile 4, 5 or 6 works well on my TV, even in double track double layer with HDR10 compatible / SMPTE ST 2086.
Mp4 DV profile 7 doesn't works and DV Profile 8 only in HDR not DV.
Do you know a way to remove [ HDR10 compatible / SMPTE ST 2086 ] or [ Blu-ray compatible / SMPTE ST 2086, HDR10 compatible ] on .ts file ?
I will go crazy lol
- dvhe.05.06 BL+RPU
- dvhe.04.06 EL+RPU
- dvhe.06.06 EL+RPU
- dvhe.07.05 EL+RPU
- dvhe.07.06 EL+RPU
- dvhe.08.03 BL+RPU
I will go crazy lol
a noob question:
what is the fastest/easiest way to convert a dts-hd sound file to ac3? which program needed?
download eac3to: https://www.videohelp.com/download/eac3to334.zip
extract it to your dts folder
run a cmd prompt from there
type:
eac3to.exe input.dts output.ac3 -libavRe: Dolby Vision now possible through MP4 Mux.
Also a GUI available for those scared of cmd https://www.videohelp.com/software/eac3toGrencola wrote: ↑Mon Apr 20, 2020 3:30 amdownload eac3to: https://www.videohelp.com/download/eac3to334.zip
type:Code: Select all
deadchip12
Disney+ is not available in my country so I download this remux to watch The Mandalorian: https://rarbgway.org/torrent/rw213am. This looks like dolby vision single layer mp4? I have had hard time trying to get this to play on my oled c9. I put the film files in an external hdd and connected it to the c9 via usb. At first, the files seemed to play ok, but once I skipped to another point in the film it refused to play and showed message: "the file can't be recognized". Now that message is shown everytime I try to open the files so I can't even play the film anymore. Any idea? The TV did recognize the files at first so it's really weird that it does not recognize the files now anymore. The files are not corrupted btw, I tested them on my computer and they play fine, only without dolby vision.
not sure in your situation, sounds like a tv issue-maybe because of the prof 5.06? people say it plays great on the shield and atv4 (and probably fire tv-I'll test tonight). also-not to hijack your post or anything - but seeing this, I feel like compressed x265's could still work in dolby vision (read a while back that x265 now supported dv), and those saying nope it has to be the full lossless video track were misinformed. I should have tested it myself but I just went along believing it. the 30-ish GB x265's you get when you compress a full disc (and leave audio alone) look fantastic still and save you a ton of space! I might do up a few and try to keep dv and compare some before/after screens to see if dv color profile is properly retained etc.deadchip12 wrote: ↑Mon Apr 20, 2020 5:15 amDisney+ is not available in my country so I download this remux to watch The Mandalorian: https://rarbgway.org/torrent/rw213am. This looks like dolby vision single layer mp4? I have had hard time trying to get this to play on my oled c9. I put the film files in an external hdd and connected it to the c9 via usb. At first, the files seemed to play ok, but once I skipped to another point in the film it refused to play and showed message: "the file can't be recognized". Now that message is shown everytime I try to open the files so I can't even play the film anymore. Any idea? The TV did recognize the files at first so it's really weird that it does not recognize the files now anymore. The files are not corrupted btw, I tested them on my computer and they play fine, only without dolby vision.
deadchip12
Sorry what do you mean by prof 5.06?Grencola wrote: ↑Mon Apr 20, 2020 2:14 pmnot sure in your situation, sounds like a tv issue-maybe because of the prof 5.06? people say it plays great on the shield and atv4 (and probably fire tv-I'll test tonight). also-not to hijack your post or anything - but seeing this, I feel like compressed x265's could still work in dolby vision (read a while back that x265 now supported dv), and those saying nope it has to be the full lossless video track were misinformed. I should have tested it myself but I just went along believing it. the 30-ish GB x265's you get when you compress a full disc (and leave audio alone) look fantastic still and save you a ton of space! I might do up a few and try to keep dv and compare some before/after screens to see if dv color profile is properly retained etc.deadchip12 wrote: ↑Mon Apr 20, 2020 5:15 amDisney+ is not available in my country so I download this remux to watch The Mandalorian: https://rarbgway.org/torrent/rw213am. This looks like dolby vision single layer mp4? I have had hard time trying to get this to play on my oled c9. I put the film files in an external hdd and connected it to the c9 via usb. At first, the files seemed to play ok, but once I skipped to another point in the film it refused to play and showed message: "the file can't be recognized". Now that message is shown everytime I try to open the files so I can't even play the film anymore. Any idea? The TV did recognize the files at first so it's really weird that it does not recognize the files now anymore. The files are not corrupted btw, I tested them on my computer and they play fine, only without dolby vision.
darrrkmanxxx
haha, thanks for showing me. You know what sucks, this:Grencola wrote: ↑Wed Apr 15, 2020 7:17 pmwatch this magic happen when I try the apk on my phone: https://youtu.be/3qIHyLHtcEUdarrrkmanxxx wrote: ↑Wed Apr 15, 2020 7:32 amThe 1.21.2 beta was the suggested version from the provided link with SMB in the changelog!
However, I tried 2.8.0 directly from Playstore and there's also no such thing as 'Local Network', there's only a bunch of useless added crap
See for yourself:
https://drive.google.com/file/d/1-hePke ... sp=sharing
I've also tried on different devices...
just gotta wait til the tablet/tv version gets updated.
https://drive.google.com/file/d/1KyMUYa ... sp=sharing
just look at this sh**. On my pc it say, that it isn't compatible, even with my OP6T!
