Pink Panther (1963)
Kappabear
Pink Panther (1963)
Post by Kappabear »
When I attempt to rip/convert "The Pink Panther (1963)", within a minute it fails with the errors below. I have no clue as to why it fails. The disk plays perfectly in VLC and Apple DVD Player. It's the only title on the disk, and there are no audio options other English.
MakeMKV v1.15.1 darwin(x64-release) started
Debug logging enabled, log will be saved as /Users/Me/MakeMKV_log.txt
Optical drive "DVD+R-DL TSSTcorp CDDVDW SH-S202N SB02d" opened in OS access mode.
Calculated BUP offset for VTS #0 does not match one in IFO header.
Title #1 was added (17 cell(s), 1:54:51)
Saving 1 titles into directory /Users/Me/Movies/THE_PINK_PANTHER_MOVIE_ONLY
AV synchronization issues were found in file '/Users/Me/Movies/THE_PINK_PANTHER_MOVIE_ONLY/title_t00.mkv' (title #1)
AV sync issue in stream 0 at 0:00:32.482 : video frame timecode differs by -16.716ms
AV sync issue in stream 0 at 0:03:32.662 : video frame timecode differs by -16.694ms
DEBUG: Code 4294949424 at 3XA:9URij{|ddd&kf0hw:121275389
DEBUG: Code 0 at 3XA:9URij{|ddd&kf0hw:213140633
DEBUG: Code 0 at 12n3M84.-Z~c`8wRW71Q/:29400140
DEBUG: Code 0 at %$4P&W?OM;\l}eqJ:29396138
DEBUG: Code 0 at _kAnP8/ QH,5@aS^C:121264464
DEBUG: Code 0 at _kAnP8/ QH,5@aS^C:121263912
DEBUG: Code 0 at _kAnP8/ QH,5@aS^C:213130145
LIBMKV_TRACE: Exception: Error in p->FetchFrames(2,true)
AV sync issue in stream 1 at 0:04:58.016 with duration of 32ms : broken timecode, apparent audio skew is -298.164s
AV sync issue in stream 0 at 0:00:00.083 : video frame timecode differs by -298.164s
Failed to save title 0 to file /Users/Me/Movies/THE_PINK_PANTHER_MOVIE_ONLY/title_t00.mkv
0 titles saved, 1 failed
Logs:
Debug log started at Sun Apr 19 15:29:54 2020 , written by MakeMKV v1.15.1 darwin(x64-release)
001005:0000 MakeMKV v1.15.1 darwin(x64-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/Me/MakeMKV_log.txt
002010:0000 Optical drive "DVD+R-DL TSSTcorp CDDVDW SH-S202N SB02d" opened in OS access mode.
No  SDF v06d: TSSTcorp_CDDVDW_SH-S202N_SB02_SH-S202NFirmware
SDF id v06d: TSSTcorp_CDDVDW_SH-S202N_SB02_SH-S202NFirmware
No auto SDF v06d: TSSTcorp_CDDVDW_SH-S202N_SB02_SH-S202NFirmware
DEBUG: Code 0 at &{3i)-QLdg>G:Y,6c:29395540
DEBUG: Code 0 at |vdFo@*k0iC'^H5^":121261773
DEBUG: Code 0 at |vdFo@*k0iC'^H5^":29393792
003002:0000 Calculated BUP offset for VTS #0 does not match one in IFO header.
003028:0000 Title #1 was added (17 cell(s), 1:54:51)
005014:0000 Saving 1 titles into directory /Users/Me/Movies/THE_PINK_PANTHER_MOVIE_ONLY
004007:0010 AV synchronization issues were found in file '/Users/Me/Movies/THE_PINK_PANTHER_MOVIE_ONLY/title_t00.mkv' (title #1)
004047:0010 AV sync issue in stream 0 at 0:00:32.482 : video frame timecode differs by -16.716ms
004047:0010 AV sync issue in stream 0 at 0:03:32.662 : video frame timecode differs by -16.694ms
DEBUG: Code 256 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 512 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 768 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 1024 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 1280 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 1536 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 1792 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 2048 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 2304 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 2560 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 2816 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 3072 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 3328 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 3584 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 3840 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 4096 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 4352 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 4608 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 4864 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 5120 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 5376 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 5632 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 5888 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 6144 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 6400 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 6656 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 6912 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 7168 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 7424 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 7680 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 7936 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 8192 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 8448 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 8704 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 8960 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 9216 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 9472 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 9728 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 9984 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 10240 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 10496 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 10752 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 11008 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 11264 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 11520 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 11776 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 12032 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 12288 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 12544 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 12800 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 13056 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 13312 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 13568 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 13824 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 14080 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 14336 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 14592 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 14848 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 15104 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 15360 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 15616 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 15872 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 16128 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 16384 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 16640 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 16896 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 17152 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 17408 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 17664 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 17920 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 18176 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 18432 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 18688 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 18944 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 19200 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 19456 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 19712 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 19968 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 20224 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 20480 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 20736 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 20992 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 21248 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 21504 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 21760 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 22016 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 22272 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 22528 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 22784 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 23040 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 23296 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 23552 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 23808 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 24064 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 24320 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 24576 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 24832 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 25088 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 25344 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 25600 at #SxlI&%\Eds(NjVZ7?k:213132652
001003:0020 DEBUG: Code 4294949424 at 3XA:9URij{|ddd&kf0hw:121275389
001003:0020 DEBUG: Code 0 at 3XA:9URij{|ddd&kf0hw:213140633
001003:0020 DEBUG: Code 0 at 12n3M84.-Z~c`8wRW71Q/:29400140
001003:0020 DEBUG: Code 0 at %$4P&W?OM;\l}eqJ:29396138
001003:0020 DEBUG: Code 0 at _kAnP8/ QH,5@aS^C:121264464
001003:0020 DEBUG: Code 0 at _kAnP8/ QH,5@aS^C:121263912
001003:0020 DEBUG: Code 0 at _kAnP8/ QH,5@aS^C:213130145
001002:0020 LIBMKV_TRACE: Exception: Error in p->FetchFrames(2,true)
---- Failed /Users/Me/Movies/THE_PINK_PANTHER_MOVIE_ONLY/title_t00.mkv
ch_0         317927610000 0
ch_1         318468150000 0
ch_2         319008690000 0
ch_3         319549230000 0
ch_4         320089770000 0
ch_5         320756436000 0
ch_6         321296976000 0
ch_7         321837516000 0
mt=0x7f952c420610 n=2
s=0 n=1 o=503541760
    0   6607 000011   321837516000       54054000 CA45F082 000001B32D01E0240CEEE3821020202620262C2C2C2C2C2C343034363636343434343636363A3A3A4644443A3A3A36383C3C404044464C4E4C484846484E4E525252646460607474788E8EAB10111112121213131313141414141415151515151516161616161616171717171717171718181819181818191A1A1A1A191B1B1B
s=1 n=1 o=182265856
    1   1792 000001   321857280000       34560000 A319DF71 0B77A0641E40E1DC2DCB807E19FEB2E8D0C51E1EA343347C7E8E0F2AAE863E7E85FB97CF9FA57D09F3E7D5D2D8F4FB95BEB6F974354FA8C75CB103ECD9A1C27D06C3A730B615A4F94D84AF9EDBAEE6B567CFDD217E96139AF0C929A3BBCA8FAB3E7F1A1537C961BE750A75284FD5A652FD3258842C117CB75BEA50A1AA54E9CC
mt=0x7f952c4203a0 n=2
s=0 n=2 o=503541760
    0   3004 000018   321747426000       54054000 3813BAE7 00000100001FFFFBB8000001B58555571680000001018257299C0405948E0000010282559CA670101652380000010382559CA670101652380000010482559CA670101652380000010582559CA670101652380000010682559CA670101652380000010782559CA670E5622B03A523800000010822559CA671958083291C000001
    0    859 000018   321801480000       36036000 E33260F0 00000100005FFFFBB8000001B58555579400000001018257299C0405948E0000010282559CA670101652380000010382559CA670101652380000010482559CA670101652380000010582559CA670101652380000010682559CA670101652380000010782559CA670E5620E0F5D01D291C0000001081A559CA671958083291C00
s=1 n=35 o=182265856
    1   1792 002001   321891840000       34560000 CB24C8D9 0B77ADF81E40E1DC31CB807E1BFEB2E8D8CD1E1CA32354747E8F0F2AEE863E86E9D257B6DFA57CF9F2E7EE5F44F4FB7057AD0AB527EF9F3E7D5DF2A7CFD2C02AE932A7CF94DB7B5DF3E7CE6C28A6F9FA576E5D3E7CF75C372F9F39D6F7C872212B729D52B214F3A58CF9F527EEAB3EA4FDCD2A6F94BF56E21BEA506E3A9B4DED
    1   1792 002001   321926400000       34560000 40894008 0B77A5281E40E1DC31CB807E1BFEB2E8C8C51E1DA3A394787A8D8F2AAE86A57E969427CF9F2EA50A0DC4B0A3D4EAFB623FACFDF531B49F3F530D2D34D49F3EA6A953E54FA9B8AF4933E5C9A942AE5553E734DF3DD6FD2BE7EA5F41AEFBC88FABBEA6961577B6ADAA7BAD7437CA9D3E7D0D529A5AA1577CF9F2A84FD33E7AFD53
    1   1792 002001   321960960000       34560000 2370C9C6 0B771A3C1E40E1DC35CB807E1DFEB2E8C8CD1F1BA32374787E8E8F2AAE883E7CF9FA5A4FDCD27D4A9B976F5F59EAFB6EAEB6F6BD1AEFAB4374F9D267CFDCD286B9D55AD1DD527CFA1A57EA5ED87349F3E8556E297CF9F5284F9F3E5D0BCBA9A13E850ABBA86A9ED2A4FA9579D495B64B4A15754A69577CF755B7CFA1428709D4
    1   1792 002001   321995520000       34560000 995927B2 0B775C7A1E40E1DC39CB807E1DFEB2E8C8DD011AA2A3346C028F0F2AAE870C7E960D783613257D4D4BF534D33EC6FBA23B4B01CBE7D4A156D6A9F9184F9F434CEA6D6AEFA72EA4A9ED44C95F3F4B497A5A53D2BEA5495A5A4F6239869BC88FDF2A86E61427F4A0DC52FDED6A5112D27D4DD3E84F6BD7736A13DD6FA946AE9933
    1   1792 002001   322030080000       34560000 38FCAAA1 0B7757461E40E1DC3DCB807E1FFEB2E8B0D5011DA383346C7A8E0FAAAE863F4AF9F42A54AB3EAEE69CD7CFA958F4FB6C578EE933E7D0AB67530DEC422F75BE7CFDF2A54F9F3E854A0D77D3A13DD6E9DA57CA9F3E9D4D31174F9F5374A7D5F6ADC34B49FBDAEF9F91836E9537CA635C534D4C35695F3A5CF9543534D2C2AD5D52
    1   1792 002001   322064640000       34560000 7EC2FAA9 0B7704081E40E1DC3DCB807E1FFEB2E8D0E51C1CA323347476800FAAAE863EA4FA1527D4D2C27CFDEBE84FA1C0EAFBACA58EE6DBE7EA61A674FD2A67CF9FAA7AFD325A74954DB6A9F42AB5DF3B4B09FA57D09FA57E45FBEA30AB3A7D4BCC2E6E8D5B0DF3DB70D53B214DF2A74AD53E54F9D3E74F953E7EB553F7B5D4D754E6BA
    1   1792 002001   322099200000       34560000 30D12929 0B776E8B1E40E1DC41CB807E21FEB2E8D0DD1E1BA32334787E8E802AAE883DB6F9D3E8695FA57CFA13E7D09F58F4FBAC52D75085285ADFA4E0569527CFA9AE7CF5FC27CFD0BAA4FDD957C9693F4AF95C31F4D5A59D59F679B0DD2586E7C8B0A13F5694AE7A6F6B437C46956AD5DF4256F5FBE569553F4AF9D3F734DEC34B5AB3
    1   1792 002001   322133760000       34560000 9CBBCC5F 0B77BC761E40E1DC41CB807E21FEB2E8C8D51A1CA383547C7E8F0EAEAE863E74F9D4284FD2C27CB043A7EA92D8F4FB3470D4AD4EEC0A5FA97979C3E7EEDC447CF9CD2A699D3A7E960EC73505D77D6D2D6AD59F2EAD50ABE7495F52854BF26AA1544C995A9A8A23BEA5E6CB96A0257B1EB4354922B87D5A9BE7E9953E4B0B3BF2
    1   1792 002001   322168320000       34560000 6F7BD884 0B77EA581E40E1DC3DCB807E21FEB2E8C8CD1C1BA363546802800EAEAE84427B4DF427CFA1A584AD2C27D59FBEF6FA1844DEB12E6B8FD4D374ED2BE7D0A9544AF9D4373006A98895F39AEE622583714BE7B61B2486FA7A8AEFA9527CF7731EEA39A6FDDB9E24215B7FC30916D625D70DF429D4A02554FA1A5A6E6BBE84E9F3F7
    1   1792 002001   322202880000       34560000 464CEBF0 0B779C391E40E1DC39CB807E21FEB2E8C0D51D1CA36334747E800EAAAE8AA57CF9F3E7CF9F3E7EE93264C92BDEE0FA204EEA7FB39D6E7A20EAE3AB984F7838BA92C3E7D4AADB8D1125774FA0D77CADCBEAE95FA64349D2A8D49F42535F660FBAB4E4E3888DED78B4E0F63B4E9338B9B136BBDDD5D5BF1C3295442EC9397EE734
    1   1792 002001   322237440000       34560000 FBD3EE08 0B77EAAE1E40E1DC35CB807E21FEB2E8D8E51C1BA363546C768F8F2AAE883E7D49F52AD49F3EA6E5F40195DED8F4FA224FC06FBB4E26FA38EC7FABCE0838A3EAD6DBEAEA92C3730DED2A55D53E7B0DD917499F4DAEFA352A4F9DA57B0F6894BB1AEF33AB4DED7AA4E1475A5B083AA57E995427CFA14418FA1A6535DF3E7EA932
    1   1792 002001   322272000000       34560000 27891CB8 0B7796491E40E1DC35CB807E21FEB2E8C8CD1B1AA3835470028F8F2CAE863E7CF9F427CAD2BE7CF9ED7A50A158F4FA623BB6770B5B873033E48FABDDEE38A4E2D5FA1A4FDED84C92BBEA3B12BE869A1A0555DEBF4C95F3EA4FA0D3869775FCFC6EDFBF851DD6EDD2A74D2BF736E0EB7EE953E7CFF8BAEEF9DC2D6DB5C07F923E
    1   1792 002001   322306560000       34560000 0E82F556 0B77253E1E40E1DC35CB807E21FEB2E8D0D51C1DA363D478728F0E2AAE85D77CF9F3E7CF9F3E7D0A1427CF9F57F6FA5FD2E073AB5DEFAB9FEC72E41EA82E1FE26F0CEA7362248F5A13F7E986568EEA13E54AD2BF2AF6DD2CCF9F2F4AFF7613B7B4EC7383EAC838A562869A4E21EE1BC34AC24B8F2DDB7D0D2D656A9F56A4AD2D
    1   1792 002001   322341120000       34560000 D92966BB 0B7782301E40E1DC35CB807E21FEB2E8D8DD1B1DA2C3547872800F2AAE88A57CF9FA64AF9F3E84FD2BE854DCD9EAFA603AC06BB9FEB3B59FE4D2EB8CEEABB3ECD2C3E7E937BDD5B14C37B5AA35A4F96EAAEFD26B7CF6BBEA4E9F3EA4FB77FAF7B5EE1BAA1D86F8D0E0F9EE6E8D3CB4B76DF52B6F75BF4B0A9BA54FA93EA6A6B5
    1   1792 002001   322375680000       34560000 95C4FD78 0B7731A71E40E1DC35CB807E23FEB2E8D0C51F1EA32334707A8F8FAAAE863F4AF9F3EA55A9427CFD2C27CF9F4AE0FA5FB9EACFB9CB6875B5EACFD0C8E96C37EAD3120D757025AF59D3E7D4D4EB56853427CE9ED6D845F4284E9ED77E97786EEB9CF4835B5E083B1BBA82DA6886BB9AECD61B9B6E6466449615844F9F3E7D19F6
    1   1792 002001   322410240000       34560000 0C2B79BE 0B7724511E40E1DC35CB807E23FEB2E8D0D51F1BA32394787A8E0F2AD6883E74F9F4286A5F3E7EA5D3EA6E5F6DEAFA5F6CAE7FBBEAC877CCEC2BB50E872E9BC272E51E0E2E3A555AD427EF92D3A54D521734D542A4B9F3EA35E7527D0775F1291CEEA9F20C2D6C1AED33A1BE8D30B5C0FDECDB0961AE56D5F4324EA9A1554D4D
    1   1792 002001   322444800000       34560000 03CE1E30 0B772A111E40E1DC31CB807E23FEB2E8D0DD001CA342F470028E0EAAAE863F7C9693E86969434AFD2BEB549F43F6FA6158DCD3BA0EA7F89DAED3AA0B8E384BEC82EB9B4A9F578696BB986EC8BDAEFD2D28695541AF4DCBE830DFA57CAB7873F633EE6FA21E083A39B085F6AD8D3038E14E0C37EED256E0561A98089ABE84FA15
    1   1792 002001   322479360000       34560000 E3C2BF8F 0B774F601E40E1DC2DCB807E21FEB2E8D0DD1D1CA3637470768F0EAAAE863E7CFA93E7B714BE84F9DA5ACF9F59EAFA94CEE876EA5AE8781DB80ECA4E086DB3EC6FD1CB55EE3CB8A2E525EA53BE24FC6BDAE9A9527CF6E2A5161F397E9785507A9BECE75BEE08B74CE4E2402EA6BB9AECCFD2588CF0B9555ABBD58E53D2755C93
    1   1792 002001   322513920000       34560000 B41A9107 0B77282A1E40E1DC29CB807E21FEB2E8C8CD001CA32354787A8E0F2AAE55527CF6DC27D49552D50A9534AFA959EAFA6152E8D393DD737AA0E26F90BE0CF89BE4D389CB0863BCC1A77D27CFDEEAA6F9DA4AEED2BE74F9D3ECCFD5259B4F7AEF7A35E4E3A1DDEF3D1FBAD6A33B0CFBB2EC73A3577564A54CF5FBF4B010BEA686B3
    1   1792 002001   322548480000       34560000 52AC44EB 0B77C4611E40E1DC29CB807E21FEB2E8B8CD1F1EA3039400768F0EB52E843E7CAA1434AFD4D34BA9F3F4AFD2DCF4FA9369F1BB9EEBFBEAEEEB5975C51217435D095527D4D325E1F6EF15B9E9E7C20E9F3BB55FACBD83D8896B537CA953EE92EEF1BB9EEBFBEAEEEB0975B83221537CF9F3EACFA93EE61CEB873939D6E7A35BA0
    1   1792 002001   322583040000       34560000 2C14A3C0 0B7703831E40E1DC29CB807E1FFEB2E8C8D51F19A36374747E8E0F2AAE86527CF9FA64B0A13A7D5A93F4AFA157F6FA92CEE283AA584E3A35BC6BAA1C26EE1AECCFB33C4D181FBCD17B988F55D1A76D2BF7CAD0BEA4B6BC286986BE7CFB84B4F036B6E3A84BA07B9AEE7FA34E86BB9BC27251B926B1508748BBD8136BC0116E94
    1   1792 002001   322617600000       34560000 0FCFEE92 0B7734291E40E1DC29CB807E21FEB2E8D0CD1C1DA36354747A8F8F2AAE863E7CF9F3E7CFD2BF4AF9F427CFD4D9EAFA934FACD7A1DE883A1CE21FB23E276B9BECCFA9CC27F0B3C346C3A4E9203E74E73AA7CF9CDC1AFA93A84F9F667CFB8553B620E8D7AB3EA6FAB4EAD3838EAD38358ED3A9FE136EBDB739FA95709FBE4D56BD
    1   1792 002001   322652160000       34560000 57D3D4AC 0B77ADEB1E40E1DC21CB807E21FEB2E8C8BD001BA383946C7A8E002AAE883DA6F6BBEACF9F3E7CF9F3EA4FA959EAFA9334EC6FB1BE09AFA0E22BB525E7363CEA6FB1CB0D37BA89457BDAF5603D7D5D33EACAD0D69CF953E7D09ED7569B8549789FE4837D2E073A1FEE8214DE2CFA9BEAE7838EA324516092A41308933F69ADF5
    1   1792 002001   322686720000       34560000 A806CE5A 0B77E4021E40E1DC1DCB807E1DFEB2E8D8D51D1CA3835470768E8FAAAE86BA52F9552A695F567CAAB3E7CF9FBEF6FA90BDE8D7ACCF47381BEC6F935ACD6E1BEAD3107E282E389292BBE7558BBDA6A6DBE5E952D774F9F3F516ABD3715F8495F834EB978B4EA6FAA0E2D3A1BEA7FB1D907389D7CE2EC18CFD5A3B10AC2A734D53
    1   1792 002001   322721280000       34560000 93B772AB 0B777F921E40E1DC19CB807E1BFEB2E8D0DD1D1BA343147C7E8E8FAAAE862EA4F9F3AA4F9F3E8695F4E7CF9F57F6FA8657B8D38BA7E89D1DDED6EB65493834B8D7AA0E22E3E6B7A988BE0A555774FA1A57CF9D3DB8A694254FA13A86F777BAEF02EB3A13EDE93AB4E2E6D3AD86BB82E4D6B51875A2522EA2DD65756C4686969C
    1   1792 002001   322755840000       34560000 B3EBA22A 0B7713771E40E1DC15CB807E17FEB2E8D8D51C1CA36354747E8E8EAAAE890C7D0D2C34AFA143730D5258509F70D1C21342EA73AB8E14B534EC6FB34E08361BEA72EB8E8F6E38BAF61D354988D784F6DB9AEFA9A5ACF95A9AD19F567CFB744AE21FEC938B5AAD7B1FECD389AEA6BB1BC4CFB33E27EEE988E6BB988E243F4C992B
    1   1792 002001   322790400000       34560000 CA72FD34 0B77F3471E40E1DC15CB807E13FEB2E8D8D51C1AA3437400028E0EAAAE8E3E7B5DD527CFD5257D4D2BE7D60643D5EE5070B876E4CF4D6B1BEE3F91BE93639BECCF19CD6D243989463BE7EE952B495091184F9EDC2E31F3F4AF9CD84AFB67D1FA20ECE38A4DE73B86ECD37B8E072F1AECE61B4894645686961C27D108BE7EA695
    1   1792 002001   322824960000       34560000 42BB4D79 0B7782EF1E40E1DC11CB807E13FEB2E8E8DD1D1BA383546C7A8E8F2AAE863F44969BD84F9F3E85077BE754D342F6FA52BFB82391CD6E79CCEAE3B25A6E3834F26FB1D8E9383DB8E5FBE7D0DD3E5692956B882BBD86F9FA5853A8D384FB74B4F820E2E7621D68AD9FE4E61B5B6D3A9BEC8FB0CB8F2E55B09695756F5F5874A5F5
    1   1792 002001   322859520000       34560000 4DB34FFA 0B778F721E40E1DC11CB807E11FEB2E8C8C51F1DA303347C028E0F2AAE86527CF9FA4AF4D4BE7E95FA5CEA5F63AEFA4870E06FB51E26FB35D4D3921AED6D9BEACFB84B8D620BBA92DD256A57AE54F9F3E7CF9F3F4C935BE7EF613DDEFF74362BA0E357AB4E472D9BEAFB7BCE072E9AEED389FB936EB94CF63BE7EA92EB7CFD2C
    1   1792 002001   322894080000       34560000 96421121 0B77BCE11E40E1DC0DCB807E0FFEB2E8C8DD1D1AA323747C7A8F0F2AAE863E84A9FA57D09FA17D49F427D0A957F6FA50D6E2338B9E133835F0D30CEA4E7833EC1FB20AEFA166AEFD4BF74F61BE7CF77D37495CDC2B09F4E74A9F434B0B676FB7B9E2EABA1DE87C34C4D5F8DAD46E9FEA96DD28547A56A6A9D3E5D1DFA62971EC
    1   1792 002001   322928640000       34560000 B740B0CF 0B7711B71E40E1DC0DCB807E0DFEB2E8B8E51F1EA3A37470728E8E2AAE903E7E95F567CF9F3E7D4DCBE7E96BAAF6FA506BE0D790CDA2359CEAD38B5A82FA9CBA72E34E106DB8F346A11A55D2C3535DF3E5D49EEB7CFB339D6E9F3E7CFB74172E20EAE78B8DED3920BA937B68ECFB1BEC73034BA7EEBD7E99F567EFA93E7D4D2D
    1   1792 002001   322963200000       34560000 2653DC92 0B7723BD1E40E1DC09CB807E0BFEB2E8C0E51B1DA3A35478728F0F2AAE863E7CFA8D77D09F5256A2DD67B5E1AEF6FA506C8E9791CDAE6B20E486BD37B3781BEAD6EA4D6EB6355D4953E86E6BBE5549D527CA61577D46D585C969529B7780FB5F3AE422C5282D3B34E2FA19BE87FB1FEE361A0E09615AAD5DFAA7D49F3F731DD2
    1   1792 002001   322997760000       34560000 12B03199 0B775FF61E40E1DC09CB807E09FEB2E8D0CD1E1BA2E3747C728E802AAE9056850B33E850A93F535D4BE7D09F72E0FA8E4386EBA39D8AB3A0EA23825AEFDD87E41FA52855AB577D5D33A9B5ABBDAF0D2BDAF0A152A4F6BBF7309FD17CFF76962C21EA85FCE7E237BA8096BD74C8389AEED5F52B6D2C534E9553E7D5A3C284FA93
    1   1792 002001   323032320000       34560000 B4B2ECC0 0B771A581E40E1DC09CB807E09FEB2E8C8D51D1EA32334006E8E002AAE86567D0953E7D09F427E988D34AF6BDCF4FA5A67E0E78B9D93A987F283CA5AF4E0B9E872EB5B6AA19BF15DF56A54AB577CFA9A57CF9F3F4CE5F55AF49F427CFF7436EDB9E2EB421D00F8A0E93ABD2DE7FC34EE0BAB5D86FAB9AEF9541B8E9F3E7CEAB4
    1   1792 002001   323066880000       34560000 2A60C4E9 0B77C3B01E40E1DC09CB807E07FEB2E8D0DD1E1CA3235478768E8F2AAE86567CFA167495D7A6735DCBE7CF9F59EAFA505CAED78CEAF37625B8838B4E0FA99BE8D3B1C90E5FB8EA994D6AEF600D554A9A64B49F29AF49F52A4F9FA652FB741D35B9E4D75CDE0D789BE2E2EA17E737B5E28363D8747A917D09F56AEA9EEB7D4A15
mt=0x7f952c40fcd0 n=2
s=0 n=0 o=503541760
s=1 n=1 o=182265856
    1   1792 002001   323101440000       34560000 FA91EDDD 0B7794711E40E1DC05CB807E07FEB2E8B8C51A1CA383347C7E8F802BAE553E7E992C27CF9DBA7AF9F3E850A158F4FA5258AEE78CEB59F520EA96C4DE222BB4E2838267E967BE7E95F56A55DED77E46191ACF9F41D845FA649AE0D7569B74172C35E19ADA6DC878A0E286C1D84D768CB2321AAA1CF89184F9F42A55E1274B0D33
004008:0010 AV sync issue in stream 1 at 0:04:58.016 with duration of 32ms : broken timecode, apparent audio skew is -298.164s
004047:0010 AV sync issue in stream 0 at 0:00:00.083 : video frame timecode differs by -298.164s
005003:0000 Failed to save title 0 to file /Users/Me/Movies/THE_PINK_PANTHER_MOVIE_ONLY/title_t00.mkv
005004:0080 0 titles saved, 1 failed
Re: Pink Panther (1963)
Based on the disk title, I assume you bought the same Pink Panther set I did. But, I did not have any ripping issues with it, so the best I can suggest is given a wipe down.
These disks are "new old stock", and have had years to accumulate the chemical film I've seen on a LOT of disks. They look almost like a mirror... but it's that "almost" that is enough to cause the laser to not be able to read the data. I've tried to get pictures of it, but they're enough of a mirror that my cameras can't focus on the disk, just the background reflected off of it.
