Avengers: Infinity War key unknown
Duecey
Post by Duecey » Fri Apr 17, 2020 9:48 pm
I flashed my ASUS BW-16D1HT firmware to 3.01 so that I can read UHDs, which seemed to work fine. But when decrypting Avengers: Infinity War I keep getting an error message. It's even stuck in unmounting.
Error:
Evaluation version, 23 day(s) out of 30 remaining
Using LibreDrive mode (v05 id=E064BA3E3F81)
Downloading latest HK to C:\Users\jakei/.MakeMKV ...
Error 'OS error - The I/O device reported an I/O error' occurred while reading '/AACS/MKB_RO.inf' at offset '3809256'
Error 'OS error - The I/O device reported an I/O error' occurred while reading '/AACS/MKB_RO.inf' at offset '0'
Error 'OS error - The I/O device reported an I/O error' occurred while reading 'BD-RE ASUS BW-16D1HT 3.01' at offset '4194304'
Error 'OS error - The I/O device reported an I/O error' occurred while reading 'BD-RE ASUS BW-16D1HT 3.01' at offset '4253696'
Error 'OS error - The I/O device reported an I/O error' occurred while reading 'BD-RE ASUS BW-16D1HT 3.01' at offset '818020352'
Error 'OS error - The I/O device reported an I/O error' occurred while reading 'BD-RE ASUS BW-16D1HT 3.01' at offset '5242880'
Error 'OS error - The I/O device reported an I/O error' occurred while reading 'BD-RE ASUS BW-16D1HT 3.01' at offset '5304320'
Error 'OS error - The I/O device reported an I/O error' occurred while reading 'BD-RE ASUS BW-16D1HT 3.01' at offset '819068928'
Error 'OS error - The I/O device reported an I/O error' occurred while reading 'BD-RE ASUS BW-16D1HT 3.01' at offset '819070976'
Error 'OS error - The I/O device reported an I/O error' occurred while reading 'BD-RE ASUS BW-16D1HT 3.01' at offset '1114112'
Error 'OS error - The I/O device reported an I/O error' occurred while reading 'BD-RE ASUS BW-16D1HT 3.01' at offset '1120256'
Saved AACS dump file as C:\Users\jakei/.MakeMKV/MKB20_v68_MARVEL'S_AVENGERS-_INFINITY_WAR_0928.tgz
Re: Avengers: Infinity War key unknown
Post by Woodstock » Fri Apr 17, 2020 9:51 pm
And you've looked at the "sticky" message at the top of General forum to find out how to fix this problem?
Duecey
Post by Duecey » Fri Apr 17, 2020 11:05 pm
Hey I did, none of the stuff worked. I ended up re-doing the firmware flash and now it rips.
Problem is now though, the 4K Rips are laggy. It's like it's 15 FPS instead of 24.9.
Post by Woodstock » Sat Apr 18, 2020 1:18 pm
Are you playing across a network? 4K video uses a LOT of bandwidth. Also, if your playback device does not have hardware support for h265 video playback, VLC's software playback isn't going to cut it if your processor isn't VERY fast.
If you read the CPU specifications for UHD playback, that list starts with the earliest Intel chips that had h265 hardware playback.
Duecey
Post by Duecey » Sat Apr 18, 2020 2:09 pm
Hey Woodstock, appreciate your reply.
No I'm just playing it on my PC to test. My Plex server isn't even recognizing the file, even though it sees the regular blu-ray rips just fine. My specs are quite high:
i9 9900k 4.8ghz
32 GB DDR4 2800mh
m.2 2TB SSD
GTX 2080 Ti
ASUS BW-16D1HT
st4evr
Post by st4evr » Sat Apr 18, 2020 5:18 pm
Have you tested play back on any other PC software player to try and rule out a potential specific software problem with the one you are currently using? E.g JRiver, MPC-BE + madVR, etc?
Have you tried playback straight from the full folder structure backup? Same behavior? Or have you only tried playback from the MKV file container created by MakeMKV?
Do you have a standalone player that supports playback of these files that you can test? E.g. OPPO-203/205? If so, same behavior?
Some PC software players under some circumstances/environments can act weird with 4K UHD BD playback if either not setup correctly and/or have bugs that can cause this. The next logical step is to try something new/different to try and rule those things out.
Duecey
Post by Duecey » Mon Apr 20, 2020 1:16 pm
Hey, so for the Blu-Rays yes. I tried other play-back video players, no skipping or any issues; however the 4K is still slowed down even on local play-back.
st4evr
Post by st4evr » Mon Apr 20, 2020 7:54 pm
So again, this is occurring in playback for both the MKV container of the movie(s) and full folder structure?
Is there any other PC available (with compatible/recent GPU for 4K playback) where playback of the exact same copies/files can be tested?
Also, are you using the latest MakeMKV release/version?
