UHD Drive clarification for ripping 4K UHD discs
LGans316
Post by LGans316 »
Hope you are safe and well.
I did go through the UHD drive sticky thread but ultimately I am confused.
I am looking to buying this drive Archgon md-8107s-u3-uhd https://www.amazon.co.uk/Archgon-Extern ... 07Q65WJXC/ to rip my 4K UHD Blu-rays.
Wondering if MakeMKV will work with this drive out of the box without any flashing?
st4evr
Re: UHD Drive clarification for ripping 4K UHD discs
Post by st4evr »
No, it will not. Drive manufacturers/distributors have patched the loophole that allows for UHD BD ripping on compatible drives they ship long ago. Hence, why the topic of flashing/re-flashing is still so actively discussed within the walls of this forum.
If you are unsure you are capable of flashing a drive, forum members provide "ready-to-go" services here:
https://www.makemkv.com/forum/viewforum.php?f=20
Additionally, drive topics usually go here:
https://www.makemkv.com/forum/viewforum.php?f=16
You just posted in the UHD discs forum, which is typically used to discuss discs and/or disc related problems.
