The extracted atmos track from mkv with ffmpeg would be without an ac3 core so tsmuxer still wouldn't recognize it. You can simply use eac3to, though, instead of ffmpeg to extract the atmos track into thd+ac3 format and those steps would then work.
Dolby Vision and 1.15.1
Re: Dolby Vision and 1.15.1
I'll have to try that. This would save the step of having to rip the whole disc. If you can work just from the MKV then it work be much quicker. Thanks for that idea!
I see it on the Canadian Best Buy site, the Web code is 14276266 (I'd add the link, but I'm not sure if that's allowed here).
I thought eac3to can extract the audio from the MKV? That was the 2nd workflow that was mentioned here:
https://www.makemkv.com/forum/viewtopic ... =15#p87830
1. Use MakeMKV
2. Use eac3to to get the audio
3. Remux using tsmuxer
And done.
Yea I just hadn't tried it yet. I'm re-ripping all my DV titles right now and the last two were DTS:X so I was able to directly remux those in tsmuxer. The one I'm ripping right now is another ATMOS track so I'll be trying the extract from eac3to and adding it through tsmuxer.olevelo wrote: ↑Thu Apr 16, 2020 7:16 pmI thought eac3to can extract the audio from the MKV? That was the 2nd workflow that was mentioned here:
1. Use MakeMKV
And done.
it's not that easy and cannot be done without breaking tsmuxer the developers said. The solution they are working on will be as good, who cares about the ac3 coreSamuriHL wrote: ↑Thu Apr 16, 2020 4:46 pmCorrect me if I'm mistaken here, but, that's not the same thing. MakeMKV already puts the THD/ac3 interleaved audio track in the MKV, tsmuxer just doesn't recognize it in the MKV container. So ideally, they'd fix the ability for tsmuxer to use the track already within the MKV container and we'd be good to go.
I absolutely couldn't care less about the AC3 core so if what they're working on will work and we can drop an MKV made by MakeMKV into it and remux it into a TS, I'm all good!RESET_9999 wrote: ↑Thu Apr 16, 2020 7:45 pmit's not that easy and cannot be done without breaking tsmuxer the developers said. The solution they are working on will be as good, who cares about the ac3 coreSamuriHL wrote: ↑Thu Apr 16, 2020 4:46 pmCorrect me if I'm mistaken here, but, that's not the same thing. MakeMKV already puts the THD/ac3 interleaved audio track in the MKV, tsmuxer just doesn't recognize it in the MKV container. So ideally, they'd fix the ability for tsmuxer to use the track already within the MKV container and we'd be good to go.
For those that are looking to make this work in the easiest way possible:
1) Rip to MKV with MakeMKV
4) Remux to TS
4) Remux to TS
Thanks for the command line for eac3to. Saves me the trouble of looking it up? Have you tried playing it in Kodi? I'd rather not have to use Plex as well.SamuriHL wrote: ↑Thu Apr 16, 2020 9:54 pmFor those that are looking to make this work in the easiest way possible:
4) Remux to TS
Angryunibrow
Kodi does not play DV right now, need to use Plex on the shield.olevelo wrote: ↑Thu Apr 16, 2020 10:16 pmThanks for the command line for eac3to. Saves me the trouble of looking it up? Have you tried playing it in Kodi? I'd rather not have to use Plex as well.SamuriHL wrote: ↑Thu Apr 16, 2020 9:54 pmFor those that are looking to make this work in the easiest way possible:
4) Remux to TS
I thought Kodi had a beta for DV support on the SHIELD? I haven't tried it, no. Personally I love plex and have it set up really well on my LAN with the NAS.
Thank you! Just to add to this, MakeMKV needs to be 1.15.1, eac3to I believe any of the latest versions will work.. But I think someone here just said that TSMuxer needs to be one of the nightly builds? The latest stable doesn't work?SamuriHL wrote: ↑Thu Apr 16, 2020 9:54 pmFor those that are looking to make this work in the easiest way possible:
4) Remux to TS
I’ve been holding off until this was simple and now seems like the right time. Thanks. What is the workflow for DTS:X tracks?SamuriHL wrote: ↑Thu Apr 16, 2020 9:54 pmFor those that are looking to make this work in the easiest way possible:
4) Remux to TS
