I don't know for sure as I my TV doesn't support DV. The re-encoded BL worked ok in yusesope's tool, so I assume it has everything it needed. That's why it I uploaded the files for testing.DaMacFunkin wrote: ↑Thu Apr 16, 2020 6:31 amDidn’t think you could re-encode the base layer as it either loses the DV descriptors or doesn’t Mux back in correctly, is this not the case?MartyMcNuts wrote: ↑Thu Apr 16, 2020 12:07 amI was thinking about the stuttering issues people were having with Gemini Man and whether the combination of high frame rate and high bitrate is the cause, so here are some 30 sec sample files (video only, no audio) to see if the stutter issues changes at all. I have re-encoded the base layer to lower the overall bitrate but none of my equipment supports Dolby Vision, so I am unable to test them myself. Anyway, here are the test files.
Feel free to give them a go and report back.
.ts files:
DV_07.09 - https://www.mediafire.com/file/2b8zlvk5 ... s.zip/file
BL+EL+RPU DV_06.09 - https://www.mediafire.com/file/my4qmuh8 ... s.zip/file
.m2ts files:
DV_07.09 - https://www.mediafire.com/file/v2e6nkzc ... s.zip/file
BL+EL+RPU DV_06.09 - https://www.mediafire.com/file/sff991s5 ... s.zip/file
Vertigo86u2
Hi everyone
I recently tried to rip few UHD BD with DVDFAB to mp4 dual layer DV with lossy audio and they playback fine on my LG E9 Plex app.
I'm willing to buy a Sony AG9 and i'm askimg if anybody with a Sony Android TV tried to playback these kind of file with Sony Tv Plex App or i need to re-rip movies in Single Layer DV Mp4 using DvdFab?
Wait for feedbacks
Wait for feedbacks
Try asking over at the dvdfab forum.Vertigo86u2 wrote: ↑Thu Apr 16, 2020 7:21 amHi everyone
Wait for feedbacks
Vertigo86u2
Thank you MartyMcNuts
Yes i'll search on DVDFAB forum also but the question is if someone with an Android TV Sony has succeed to playback a dual layer DV mp4 muxed ( with DVDFAB or with mp4muxer also) with Plex app on such TV.
- Contact:
Just in case - MakeMKV 1.15.1 preserves DV in MKV - please see https://www.makemkv.com/forum/viewtopic ... 12&t=21937
I was also curious why some were using MakeMKV to use it later with TS muxes for Atmos tracks. AFAIK, MKV should be able to preserve the ATMOS/DTS-X with lossless audio and DV at this point, correct?mike admin wrote: ↑Thu Apr 16, 2020 10:41 amJust in case - MakeMKV 1.15.1 preserves DV in MKV - please see https://www.makemkv.com/forum/viewtopic ... 12&t=21937
It can but nothing will currently play the MKV's. So we're remuxing them with TSMuxer to TS so that we can play them on other devices like the SHIELD Pro 2019 in Plex. At least, that's what I'm doing.mulucy wrote: ↑Thu Apr 16, 2020 12:33 pmI was also curious why some were using MakeMKV to use it later with TS muxes for Atmos tracks. AFAIK, MKV should be able to preserve the ATMOS/DTS-X with lossless audio and DV at this point, correct?mike admin wrote: ↑Thu Apr 16, 2020 10:41 amJust in case - MakeMKV 1.15.1 preserves DV in MKV - please see https://www.makemkv.com/forum/viewtopic ... 12&t=21937
Yep, this is the current solution. However, now that 1.15.1 is out we're waiting for the other shoe to drop where certain software players (Plex etc) update their code to natively handle these files. Once that happens it will greatly simplify our DV UHD backup process.mulucy wrote: ↑Thu Apr 16, 2020 12:33 pmI was also curious why some were using MakeMKV to use it later with TS muxes for Atmos tracks. AFAIK, MKV should be able to preserve the ATMOS/DTS-X with lossless audio and DV at this point, correct?mike admin wrote: ↑Thu Apr 16, 2020 10:41 amJust in case - MakeMKV 1.15.1 preserves DV in MKV - please see https://www.makemkv.com/forum/viewtopic ... 12&t=21937
Hello my friends.
Excuse my poor English, I'm French
I have read all 144 pages and still have same problem : my TV play well .mp4 DV but not my .ts of the same source.
Source is Alita DV teaser demo.mp4 and my TV don't play it.
So, I've demuxed BL.hevc and EL.hevc then remuxed in .mp4 forced DV Profile 4 with mp4muxer and this one play fine on my tv. (EL : Dolby Vision, Version 1.0, dvhe.04.06, EL+RPU, SDR compatible / SMPTE ST 2086, HDR10 compatible)
I also tried with yusescope V3 rev1 tool then remuxed in .mp4 forced DV Profile 4 with mp4muxer and this one play fine too. (Dolby Vision, Version 1.0, dvhe.04.06, BL+EL+RPU, SDR compatible / SMPTE ST 2086, HDR10 compatible)
Works fine with forced DV Profile 5 too, but not in yusescope V3 rev1 tool -mode 2 : Black screen
But file .ts made with tsmuxer with the same BL and EL don't work on my TV. (Video format not supported)
I don't understand. I've tried lot of tsmuxer version (edited,04.06 fix, patched, nightly...)
I don't understand because I've a lot of LG DV demo .ts (dvhe.04.06 BL+EL+RPU) that work on my TV.
For .mp4 files only DV Profile 4 and 5 can work, not 7 or 8. Can't try Profile 6 don't have found the good mp4muxer for.
And for .ts files made with tsmuxer, none of them work, and I can't have dvhe 04.06 with dual layer, only 07.05.
If anyone know what's the problem and help please ?
Thank you a lot guys
Source Dual Layer .mp4 DV Profile 7 : doesn't work
Dual Layer MP4 Forced DV Profile 4 with mp4muxer : Works
Single Layer MP4 Forced DV Profile 4 with yusescope V3 rev1 tool mp4muxer : Works and DV Profile 5 works too.
Single Layer .ts Profile 4 (dvhe 04 06) : Doesn't work
Dual layer DV Profile 7 : Doesn't work, can't have DV Profile 4
LG DV demo .ts Profile 4 : Works
Général
Nom complet : E:\Alita Original.mp4
Format : MPEG-4
Profil du format : Base Media / Version 2
Identifiant du codec : mp42 (mp42/dby1/isom)
Taille du fichier : 277 Mio
Durée : 40s 97 ms
Débit global moyen : 57,9 Mb/s
Date d'encodage : UTC 2019-07-17 08:39:57
Date de marquage : UTC 2019-07-17 08:39:57
Vidéo #1
Format : HEVC
Profil du format : Main 10@L5.1@High
HDR format : SMPTE ST 2086, HDR10 compatible
Identifiant du codec : hev1
Identifiant du codec/Info : High Efficiency Video Coding
Durée : 40s 82 ms
Débit : 55,2 Mb/s
Largeur : 3 840 pixels
Hauteur : 2 160 pixels
Format à l'écran : 16/9
Type d'images/s : Constant
Images par seconde : 23,976 (24000/1001) Im/s
Espace de couleurs : YUV
Sous-échantillonnage de la chrominance : 4:2:0 (Type 2)
Profondeur des couleurs : 10 bits
Bits/(Pixel*Image) : 0.277
Taille du flux : 264 Mio (95%)
Default : Non
Gamme de couleurs : Limited
Coordonnées de chromaticité : BT.2020
Caractéristiques du transfert : PQ
Coefficients de la matrice : BT.2020 non-constant
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 443 cd/m2
Maximum Frame-Average Light Level : 47 cd/m2
Codec configuration box : hvcC
Vidéo #2
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.07.06, EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Identifiant du codec : dvhe
Identifiant du codec/Info : High Efficiency Video Coding with Dolby Vision
Durée : 40s 82 ms
Débit : 2 120 kb/s
Largeur : 1 920 pixels
Hauteur : 1 080 pixels
Bits/(Pixel*Image) : 0.043
Taille du flux : 10,1 Mio (4%)
Default : Non
Codec configuration box : hvcC+dvcC
Audio
Format : AC-3
Format/Info : Audio Coding 3
Nom commercial : Dolby Digital
Identifiant du codec : ac-3
Durée : 40s 97 ms
Type de débit : Constant
Débit : 640 kb/s
Canaux : 6 canaux
Channel layout : L R C LFE Ls Rs
Echantillonnage : 48,0 kHz
Images par seconde : 31,250 Im/s (1536 SPF)
Mode de compression : Avec perte
Taille du flux : 3,06 Mio (1%)
Langue : Français
Service kind : Complete Main
Default : Non
Nom complet : E:\DLP4.mp4
Format : MPEG-4
Taille du fichier : 274 Mio
Durée : 40s 82 ms
Débit global moyen : 57,3 Mb/s
Date d'encodage : UTC 2020-04-16 12:42:04
Date de marquage : UTC 2020-04-16 12:42:04
Vidéo #1
Format : HEVC
Durée : 40s 82 ms
Débit : 55,2 Mb/s
Taille du flux : 264 Mio (96%)
Default : Oui
Alternate group : 1
Vidéo #2
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.04.06, EL+RPU, SDR compatible / SMPTE ST 2086, HDR10 compatible
Durée : 40s 82 ms
Débit : 2 120 kb/s
Default : Non
Alternate group : 1
Général
Nom complet : E:\P4.mp4
Format : MPEG-4
Durée : 40s 82 ms
Date d'encodage : UTC 2020-04-16 08:25:14
Date de marquage : UTC 2020-04-16 08:25:14
Vidéo
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.04.06, BL+EL+RPU, SDR compatible / SMPTE ST 2086, HDR10 compatible
Durée : 40s 82 ms
Débit : 57,3 Mb/s
Bits/(Pixel*Image) : 0.288
Taille du flux : 274 Mio (100%)
Default : Oui
Alternate group : 1
Codec configuration box : hvcC+dvcC+hvcE
Général
Nom complet : E:\P4.ts
Format : MPEG-TS
Taille du fichier : 280 Mio
Durée : 39s 957 ms
Type de débit global : Variable
Débit global moyen : 58,6 Mb/s
Débit global maximum : 35,5 Mb/s
Vidéo
ID de menu : 1 (0x1)
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.04.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Identifiant du codec : 36
Durée : 40s 40 ms
Débit : 55,7 Mb/s
Bits/(Pixel*Image) : 0.280
Taille du flux : 266 Mio (95%)
Général
Nom complet : E:\P4DL.ts
Format : MPEG-TS
Durée : 39s 957 ms
Vidéo #1
Format : HEVC
Durée : 40s 40 ms
Vidéo #2
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.07.05, EL+RPU, 8 compatible / SMPTE ST 2086, HDR10 compatible
Durée : 40s 40 ms
Général
Nom complet : E:\LG Dolby Trailer 4K Demo.ts
Format : MPEG-TS
Taille du fichier : 308 Mio
Durée : 1 min 20s
Type de débit global : Constant
Débit global moyen : 31,9 Mb/s
Vidéo
ID de menu : 2 (0x2)
Format : HEVC
Profil du format : Main 10@L5@Main
Durée : 1 min 19s
Débit : 29,6 Mb/s
Bits/(Pixel*Image) : 0.149
Taille du flux : 282 Mio (92%)
Audio
Format : E-AC-3
Format/Info : Enhanced AC-3
Nom commercial : Dolby Digital Plus
Identifiant du codec : 135
Durée : 1 min 20s
Débit : 768 kb/s
Canaux : 6 canaux
Délai par rapport Vidéo : -948 ms
Taille du flux : 7,41 Mio (2%)
You will need single layer yeVertigo86u2 wrote: ↑Thu Apr 16, 2020 10:17 amThank you MartyMcNuts
DaMacFunkin
In MKV is it possible to retain ac3 core in Atmos for greater compatabillity?SamuriHL wrote: ↑Thu Apr 16, 2020 2:21 pmIt can but nothing will currently play the MKV's. So we're remuxing them with TSMuxer to TS so that we can play them on other devices like the SHIELD Pro 2019 in Plex. At least, that's what I'm doing.mulucy wrote: ↑Thu Apr 16, 2020 12:33 pmI was also curious why some were using MakeMKV to use it later with TS muxes for Atmos tracks. AFAIK, MKV should be able to preserve the ATMOS/DTS-X with lossless audio and DV at this point, correct?mike admin wrote: ↑Thu Apr 16, 2020 10:41 amJust in case - MakeMKV 1.15.1 preserves DV in MKV - please see https://www.makemkv.com/forum/viewtopic ... 12&t=21937
Mike said that's already being done. It's creating an interleaved thd/ac3 track in the MKV. It's just that at the moment tsmuxer doesn't recognize it when we try to remux, but, in the MKV, it's there.DaMacFunkin wrote: ↑Thu Apr 16, 2020 6:18 pm
deadchip12
Does anyone watch dolby vision remuxes on oled and notice some kind of distortion line running continously across the screen during dark scenes? It’s almost like this: https://youtu.be/eJmicmxGdkM (go to 0:29 mark) but way darker and noticeable in a pitch dark room. Yesterday I watched 1917 and this was very evident during dark scenes. I remember seeing the same issue in some other films as well. Is it caused by the remux, the oled or the film itself?
The OLED https://www.rtings.com/tv/discussions/E ... ode-odditydeadchip12 wrote: ↑Fri Apr 17, 2020 8:22 pmDoes anyone watch dolby vision remuxes on oled and notice some kind of distortion line running continously across the screen during dark scenes? It’s almost like this: https://youtu.be/eJmicmxGdkM (go to 0:29 mark) but way darker and noticeable in a pitch dark room. Yesterday I watched 1917 and this was very evident during dark scenes. I remember seeing the same issue in some other films as well. Is it caused by the remux, the oled or the film itself?
- Contact:
No, I was wrong, or rather I didn't mean it that way. If you extract both TrueHD plus eac3 core, you get two separate tracks in MKV. If TrueHD only - then you get TrueHD only (with Atmos metadata if it was there).
If you want to retain eac3 core, then you have to select it.
What I'm saying, that there is no need for tsmuxer to require eac3 core to begin with. In the worst case, if a 100% compatibility is required, one could always "create" eac3 core from TrueHD, with ffmpeg or any other tool. That core will not have Atmos metadata, but it is discarded by decoder anyway.
There is fundamental differecnce between DTS-HD and TrueHD.
In DTS, the HD layer is extension, you need to have core+hd extension to decode audio.
TrueHD is self-contained codec, eac3 is present on blu-ray only as a fallback. You can mux in a silent eac3 track or leave it empty -- providing you have setup for TrueHD, the player would discard eac3 stream and use TrueHD part only.
So, to preserve the full compatibility one just have to check both streams - truehd and eac3. As for re-encoding to m2ts, MakeMKV uses a tag called a "source id" (now picked up by mediainfo and other software). If two tracks in MKV file have the same source id, then it means that these tracks come from the same source track and have the same content in different encoding. There is nothing that prevents tsmuxer (or any other tool) to recognize two separate tracks this way and join them together. This is what I meant by tsmuxer limitation.
