Vertigo86u2
#2146 Post by Vertigo86u2 » Thu Apr 16, 2020 10:17 am
Thank you MartyMcNuts
Yes i'll search on DVDFAB forum also but the question is if someone with an Android TV Sony has succeed to playback a dual layer DV mp4 muxed ( with DVDFAB or with mp4muxer also) with Plex app on such TV.
#2147 Post by mike admin » Thu Apr 16, 2020 10:41 am
Just in case - MakeMKV 1.15.1 preserves DV in MKV - please see https://www.makemkv.com/forum/viewtopic ... 12&t=21937
mulucy
#2148 Post by mulucy » Thu Apr 16, 2020 12:33 pm
mike admin wrote: Thu Apr 16, 2020 10:41 am Just in case - MakeMKV 1.15.1 preserves DV in MKV - please see https://www.makemkv.com/forum/viewtopic ... 12&t=21937
I was also curious why some were using MakeMKV to use it later with TS muxes for Atmos tracks. AFAIK, MKV should be able to preserve the ATMOS/DTS-X with lossless audio and DV at this point, correct?
#2149 Post by SamuriHL » Thu Apr 16, 2020 2:21 pm
mulucy wrote: Thu Apr 16, 2020 12:33 pm
It can but nothing will currently play the MKV's. So we're remuxing them with TSMuxer to TS so that we can play them on other devices like the SHIELD Pro 2019 in Plex. At least, that's what I'm doing.
cipher
#2150 Post by cipher » Thu Apr 16, 2020 3:23 pm
Yep, this is the current solution. However, now that 1.15.1 is out we're waiting for the other shoe to drop where certain software players (Plex etc) update their code to natively handle these files. Once that happens it will greatly simplify our DV UHD backup process.
Hanto
#2151 Post by Hanto » Thu Apr 16, 2020 3:26 pm
Hello my friends.
Excuse my poor English, I'm French
I have read all 144 pages and still have same problem : my TV play well .mp4 DV but not my .ts of the same source.
Source is Alita DV teaser demo.mp4 and my TV don't play it.
So, I've demuxed BL.hevc and EL.hevc then remuxed in .mp4 forced DV Profile 4 with mp4muxer and this one play fine on my tv. (EL : Dolby Vision, Version 1.0, dvhe.04.06, EL+RPU, SDR compatible / SMPTE ST 2086, HDR10 compatible)
I also tried with yusescope V3 rev1 tool then remuxed in .mp4 forced DV Profile 4 with mp4muxer and this one play fine too. (Dolby Vision, Version 1.0, dvhe.04.06, BL+EL+RPU, SDR compatible / SMPTE ST 2086, HDR10 compatible)
Works fine with forced DV Profile 5 too, but not in yusescope V3 rev1 tool -mode 2 : Black screen
But file .ts made with tsmuxer with the same BL and EL don't work on my TV. (Video format not supported)
I don't understand. I've tried lot of tsmuxer version (edited,04.06 fix, patched, nightly...)
I don't understand because I've a lot of LG DV demo .ts (dvhe.04.06 BL+EL+RPU) that work on my TV.
For .mp4 files only DV Profile 4 and 5 can work, not 7 or 8. Can't try Profile 6 don't have found the good mp4muxer for.
And for .ts files made with tsmuxer, none of them work, and I can't have dvhe 04.06 with dual layer, only 07.05.
If anyone know what's the problem and help please ?
Thank you a lot guys
Source Dual Layer .mp4 DV Profile 7 : doesn't work
Général
Nom complet                              : E:\Alita Original.mp4
Profil du format                         : Base Media / Version 2
Identifiant du codec                     : mp42 (mp42/dby1/isom)
Taille du fichier                        : 277 Mio
Durée                                    : 40s 97 ms
Débit global moyen                       : 57,9 Mb/s
Date d'encodage                          : UTC 2019-07-17 08:39:57
Date de marquage                         : UTC 2019-07-17 08:39:57
Vidéo #1
Profil du format                         : Main 10@L5.1@High
HDR format                               : SMPTE ST 2086, HDR10 compatible
Identifiant du codec                     : hev1
Identifiant du codec/Info                : High Efficiency Video Coding
Durée                                    : 40s 82 ms
Débit                                    : 55,2 Mb/s
Largeur                                  : 3 840 pixels
Hauteur                                  : 2 160 pixels
Format à l'écran                         : 16/9
Type d'images/s                          : Constant
Images par seconde                       : 23,976 (24000/1001) Im/s
Espace de couleurs                       : YUV
Sous-échantillonnage de la chrominance   : 4:2:0 (Type 2)
Profondeur des couleurs                  : 10 bits
Bits/(Pixel*Image)                       : 0.277
Taille du flux                           : 264 Mio (95%)
Default                                  : Non
Gamme de couleurs                        : Limited
Coordonnées de chromaticité              : BT.2020
Caractéristiques du transfert            : PQ
Coefficients de la matrice               : BT.2020 non-constant
Maximum Content Light Level              : 443 cd/m2
Maximum Frame-Average Light Level        : 47 cd/m2
Codec configuration box                  : hvcC
Vidéo #2
HDR format                               : Dolby Vision, Version 1.0, dvhe.07.06, EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Identifiant du codec                     : dvhe
Identifiant du codec/Info                : High Efficiency Video Coding with Dolby Vision
Durée                                    : 40s 82 ms
Débit                                    : 2 120 kb/s
Largeur                                  : 1 920 pixels
Hauteur                                  : 1 080 pixels
Bits/(Pixel*Image)                       : 0.043
Taille du flux                           : 10,1 Mio (4%)
Default                                  : Non
Audio
Nom commercial                           : Dolby Digital
Identifiant du codec                     : ac-3
Durée                                    : 40s 97 ms
Type de débit                            : Constant
Débit                                    : 640 kb/s
Canaux                                   : 6 canaux
Echantillonnage                          : 48,0 kHz
Images par seconde                       : 31,250 Im/s (1536 SPF)
Mode de compression                      : Avec perte
Taille du flux                           : 3,06 Mio (1%)
Langue                                   : Français
Default                                  : Non
Dual Layer MP4 Forced DV Profile 4 with mp4muxer : Works
Nom complet                              : E:\DLP4.mp4
Taille du fichier                        : 274 Mio
Durée                                    : 40s 82 ms
Débit global moyen                       : 57,3 Mb/s
Date d'encodage                          : UTC 2020-04-16 12:42:04
Date de marquage                         : UTC 2020-04-16 12:42:04
Vidéo #1
Durée                                    : 40s 82 ms
Débit                                    : 55,2 Mb/s
Taille du flux                           : 264 Mio (96%)
Default                                  : Oui
Vidéo #2
HDR format                               : Dolby Vision, Version 1.0, dvhe.04.06, EL+RPU, SDR compatible / SMPTE ST 2086, HDR10 compatible
Durée                                    : 40s 82 ms
Débit                                    : 2 120 kb/s
Default                                  : Non
Single Layer MP4 Forced DV Profile 4 with yusescope V3 rev1 tool mp4muxer : Works and DV Profile 5 works too.
Général
Nom complet                              : E:\P4.mp4
Durée                                    : 40s 82 ms
Date d'encodage                          : UTC 2020-04-16 08:25:14
Date de marquage                         : UTC 2020-04-16 08:25:14
Vidéo
HDR format                               : Dolby Vision, Version 1.0, dvhe.04.06, BL+EL+RPU, SDR compatible / SMPTE ST 2086, HDR10 compatible
Durée                                    : 40s 82 ms
Débit                                    : 57,3 Mb/s
Bits/(Pixel*Image)                       : 0.288
Taille du flux                           : 274 Mio (100%)
Default                                  : Oui
Codec configuration box                  : hvcC+dvcC+hvcE
Single Layer .ts Profile 4 (dvhe 04 06) : Doesn't work
Général
Nom complet                              : E:\P4.ts
Taille du fichier                        : 280 Mio
Durée                                    : 39s 957 ms
Type de débit global                     : Variable
Débit global moyen                       : 58,6 Mb/s
Débit global maximum                     : 35,5 Mb/s
Vidéo
ID de menu                               : 1 (0x1)
HDR format                               : Dolby Vision, Version 1.0, dvhe.04.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Identifiant du codec                     : 36
Durée                                    : 40s 40 ms
Débit                                    : 55,7 Mb/s
Bits/(Pixel*Image)                       : 0.280
Taille du flux                           : 266 Mio (95%)
Dual layer DV Profile 7 : Doesn't work, can't have DV Profile 4
Général
Nom complet                              : E:\P4DL.ts
Durée                                    : 39s 957 ms
Vidéo #1
Durée                                    : 40s 40 ms
Vidéo #2
HDR format                               : Dolby Vision, Version 1.0, dvhe.07.05, EL+RPU, 8 compatible / SMPTE ST 2086, HDR10 compatible
Durée                                    : 40s 40 ms
LG DV demo .ts Profile 4 : Works
Général
Nom complet                              : E:\LG Dolby Trailer 4K Demo.ts
Taille du fichier                        : 308 Mio
Durée                                    : 1 min 20s
Type de débit global                     : Constant
Débit global moyen                       : 31,9 Mb/s
Vidéo
ID de menu                               : 2 (0x2)
Profil du format                         : Main 10@L5@Main
Durée                                    : 1 min 19s
Débit                                    : 29,6 Mb/s
Bits/(Pixel*Image)                       : 0.149
Taille du flux                           : 282 Mio (92%)
Audio
Format                                   : E-AC-3
Format/Info                              : Enhanced AC-3
Nom commercial                           : Dolby Digital Plus
Identifiant du codec                     : 135
Durée                                    : 1 min 20s
Débit                                    : 768 kb/s
Canaux                                   : 6 canaux
Délai par rapport Vidéo                  : -948 ms
Taille du flux                           : 7,41 Mio (2%)
box4m
#2152 Post by box4m » Thu Apr 16, 2020 3:49 pm
Vertigo86u2 wrote: Thu Apr 16, 2020 10:17 am Thank you MartyMcNuts
You will need single layer ye
DaMacFunkin
#2153 Post by DaMacFunkin » Thu Apr 16, 2020 6:18 pm
SamuriHL wrote: Thu Apr 16, 2020 2:21 pm
In MKV is it possible to retain ac3 core in Atmos for greater compatabillity?
#2154 Post by SamuriHL » Thu Apr 16, 2020 6:43 pm
DaMacFunkin wrote: Thu Apr 16, 2020 6:18 pm
Mike said that's already being done. It's creating an interleaved thd/ac3 track in the MKV. It's just that at the moment tsmuxer doesn't recognize it when we try to remux, but, in the MKV, it's there.
deadchip12
#2155 Post by deadchip12 » Fri Apr 17, 2020 8:22 pm
Does anyone watch dolby vision remuxes on oled and notice some kind of distortion line running continously across the screen during dark scenes? It’s almost like this: https://youtu.be/eJmicmxGdkM (go to 0:29 mark) but way darker and noticeable in a pitch dark room. Yesterday I watched 1917 and this was very evident during dark scenes. I remember seeing the same issue in some other films as well. Is it caused by the remux, the oled or the film itself?
#2156 Post by Billycar11 » Fri Apr 17, 2020 9:01 pm
deadchip12 wrote: Fri Apr 17, 2020 8:22 pm Does anyone watch dolby vision remuxes on oled and notice some kind of distortion line running continously across the screen during dark scenes? It’s almost like this: https://youtu.be/eJmicmxGdkM (go to 0:29 mark) but way darker and noticeable in a pitch dark room. Yesterday I watched 1917 and this was very evident during dark scenes. I remember seeing the same issue in some other films as well. Is it caused by the remux, the oled or the film itself?
The OLED https://www.rtings.com/tv/discussions/E ... ode-oddity
#2157 Post by mike admin » Fri Apr 17, 2020 9:30 pm
SamuriHL wrote: Thu Apr 16, 2020 6:43 pm Mike said that's already being done. It's creating an interleaved thd/ac3 track in the MKV. It's just that at the moment tsmuxer doesn't recognize it when we try to remux, but, in the MKV, it's there.
No, I was wrong, or rather I didn't mean it that way. If you extract both TrueHD plus eac3 core, you get two separate tracks in MKV. If TrueHD only - then you get TrueHD only (with Atmos metadata if it was there).
If you want to retain eac3 core, then you have to select it.
What I'm saying, that there is no need for tsmuxer to require eac3 core to begin with. In the worst case, if a 100% compatibility is required, one could always "create" eac3 core from TrueHD, with ffmpeg or any other tool. That core will not have Atmos metadata, but it is discarded by decoder anyway.
There is fundamental differecnce between DTS-HD and TrueHD.
In DTS, the HD layer is extension, you need to have core+hd extension to decode audio.
TrueHD is self-contained codec, eac3 is present on blu-ray only as a fallback. You can mux in a silent eac3 track or leave it empty -- providing you have setup for TrueHD, the player would discard eac3 stream and use TrueHD part only.
So, to preserve the full compatibility one just have to check both streams - truehd and eac3. As for re-encoding to m2ts, MakeMKV uses a tag called a "source id" (now picked up by mediainfo and other software). If two tracks in MKV file have the same source id, then it means that these tracks come from the same source track and have the same content in different encoding. There is nothing that prevents tsmuxer (or any other tool) to recognize two separate tracks this way and join them together. This is what I meant by tsmuxer limitation.
#2158 Post by SamuriHL » Fri Apr 17, 2020 9:59 pm
mike admin wrote: Fri Apr 17, 2020 9:30 pm
Ah, I got it now. Thanks for the detailed explanation. In my case I've just been creating a THD+AC3 track from the TrueHD track in the MKV and then adding that track into TSMuxer for output to TS. This has worked on every title I've tried so far which is a fair amount. But yes, in the beginning I was extracting the core AC3 as a separate track but I stopped doing that because it wasn't getting picked up anyway. Now I understand you're saying that the extra AC3 track COULD be picked up and interleaved for TS but isn't. That makes sense.
deadchip12
#2159 Post by deadchip12 » Sat Apr 18, 2020 2:55 am
Billycar11 wrote: Fri Apr 17, 2020 9:01 pm
Sorry but this is not the issue I’m talking about
Hanto
#2160 Post by Hanto » Sat Apr 18, 2020 8:41 am
Hanto wrote: Thu Apr 16, 2020 3:26 pm Hello my friends.
Général
Durée                                    : 40s 97 ms
Vidéo #1
Durée                                    : 40s 82 ms
Débit                                    : 55,2 Mb/s
Default                                  : Non
Vidéo #2
Durée                                    : 40s 82 ms
Débit                                    : 2 120 kb/s
Default                                  : Non
Audio
Durée                                    : 40s 97 ms
Débit                                    : 640 kb/s
Canaux                                   : 6 canaux
Langue                                   : Français
Default                                  : Non
Durée                                    : 40s 82 ms
Vidéo #1
Durée                                    : 40s 82 ms
Débit                                    : 55,2 Mb/s
Default                                  : Oui
Vidéo #2
Durée                                    : 40s 82 ms
Débit                                    : 2 120 kb/s
Default                                  : Non
Général
Durée                                    : 40s 82 ms
Vidéo
Durée                                    : 40s 82 ms
Débit                                    : 57,3 Mb/s
Default                                  : Oui
Général
Durée                                    : 39s 957 ms
Vidéo
Durée                                    : 40s 40 ms
Débit                                    : 55,7 Mb/s
Général
Durée                                    : 39s 957 ms
Vidéo #1
Durée                                    : 40s 40 ms
Vidéo #2
Durée                                    : 40s 40 ms
Général
Durée                                    : 1 min 20s
Vidéo
Durée                                    : 1 min 19s
Débit                                    : 29,6 Mb/s
Audio
Format                                   : E-AC-3
Durée                                    : 1 min 20s
Débit                                    : 768 kb/s
Canaux                                   : 6 canaux
I think I've found the problem but impossible to resolve.
I think the problem is TSMUXER, I've tried a lot of version and same problem evrytime :
This file .ts source works well on my TV :
Général
Format : MPEG-TS
Durée : 1 min 20s
Vidéo
Format : HEVC
Durée : 1 min 19s
Débit : 29,6 Mb/s
Audio
Format : E-AC-3
Durée : 1 min 20s
Débit : 768 kb/s
Canaux : 6 canaux
Channel layout : L R C LFE Ls Rs
Service kind : Complete Main
But when I remux this same file on TSMUXER juste for test, result doesn't work anymore.
New .ts file is smaller and many information are lost :
Général
Nom complet : E:\LG Dolby Trailer 4K Demo2.ts
Format : MPEG-TS
Taille du fichier : 247 Mio
Durée : 1 min 20s
Débit global moyen : 25,6 Mb/s
Vidéo
Format : HEVC
Durée : 1 min 19s
Débit : 23,6 Mb/s
Taille du flux : 224 Mio (91%)
Audio
Format : E-AC-3
Durée : 1 min 20s
Débit : 768 kb/s
Canaux : 6 canaux
Taille du flux : 7,41 Mio (3%)
I think is the same problem when I try to convert .mp4 files to .ts with tsmuxer.
If you know what is the problem and if somebody can help me please it would be most appreciate.
Thank you a lot
